On verge of buying 2015 5.7L 4x4 Tundra w/tow pkg BUT only 20 gal tank
Discussion in 'Towing & Hauling' started by JB1950, Sep 8, 2020.
  1. Sep 8, 2020 at 2:34 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Interesting. I haven’t heard that. CA is the most restrictive state and they’re located here. Either way, my neighbor got it down and loves it...until he has to fill up. Lol
  2. Sep 8, 2020 at 3:42 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    My seats are so hard that my ass is asleep anyway long before I run through the 26 gallons and I need to get out and walk a little.
    Otherwise I stop for almost nothing else!
    Clever Common Sense Design!
  3. Sep 8, 2020 at 3:50 PM
    TXTundra2722
    2015 Black Tundra
    How did you find your 38 gallon tank? I need to do this mod and if I can find one for about that price I'll pull the trigger on it too
  4. Sep 8, 2020 at 5:01 PM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I found it via online auto salvage yard searches. I waited until one showed up
    An hour away from me. I did other searching to locate a Tundra in a yard that might have one but the search by part got me one first.
  5. Sep 8, 2020 at 5:23 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    When towing I just throw 2 five gallon gas cans in the bed. I bungee them in place. Towing out in west Texas on the smaller tank is fun, you get to know ever gas stop along the way. Only needed to add gas out of a can, were on a deer lease in the middle of BFE and used the truck all weekend hauling feed to feeders most of the time in 4x4 low, so burned up a bunch of fuel that weekend.
  6. Sep 9, 2020 at 12:39 PM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    i Have been looking off and on for the last 6 months. Most seem to be priced $600-1000 which seems steep for a used tank. Hoping one will pop up close by that is priced right
  7. Sep 9, 2020 at 1:45 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Just a reminder
    more fuel
    more weight
    If you tow,it might matter
    Cpl_Punishment likes this.
  8. Sep 9, 2020 at 2:13 PM
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    I pulled Jayco that weighs around 7500-8000 lbs. with all my stuff in it. My 26 gal tank was good for about 150 miles. And as others mentioned, light came on early and I put 21 gals in. I had constant headwind and got just over 7 mpg. On the way back I got almost 9 mpg.
    TheBeast likes this.
  9. Sep 9, 2020 at 2:19 PM
    Cosmoblu
    Cosmoblu New Member
    2015 Tundra CrewMax TRD Pro Inferno Red
    Magnuson Supercharger Fuel Rims--Removed TRD Pro Rims added ARE Overland CAP Front Runner rack on cap Front Runner rack on cab Bed Rug Bed Slide RCI Aluminum Skid front and transmission
    I have a 2015 CM with a supercharger so I average 10 MPG virtually everywhere I drive. I took the rig up to Wyoming, Montana with Yellowstone in the loop and burned through 400 gallons of gas through my 26 Gallon tank, just over 4000 miles total. As I have gotten older I really do not mind the more frequent stops. I often found that many of our stops were not initiated by low fuel. The stretch, coffee refill, driver changes all became welcome as the drives stretched out. I also have an 05 Mercedes diesel that I get 38 plus with 21 gallon tank that you can go forever on, and I still stop often. No fuel, but stop at the rest areas to stretch.
    There are times when the powering through to a destination will make it a pain, but I if I am just touring and sight seeing, the stops don't bother me so much.
  10. Sep 9, 2020 at 2:28 PM
    TheBeast
    TheBeast The Beach
    you can always swap for the bigger oem tank later on. If the truck you found is the one you want.
