OEM Radio Swap
Discussion in 'Audio & Video' started by LTD_Toy, Mar 12, 2016.
  1. Mar 12, 2016 at 4:22 PM
    LTD_Toy
    LTD_Toy [OP] New Member
    California
    2011 Tundra Limited
    Hello, I just bought a 2011 Tundra Limited and I already have a few things I want to do. I was hoping get feedback.
    Has anyone swapped a standard deck with a OEM unit with navigation and a backup camera? Is it possible or to much work?
    GNTundra likes this.
  2. Mar 12, 2016 at 4:31 PM
    Red Freighter
    Red Freighter Red Freighter
    Fred
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Welcome. So easy. Less than ten minutes. You will get a lot of help here. Are you sure you have a limited? First of all do you have JBL or Non JBL.
  3. Mar 12, 2016 at 4:35 PM
    LTD_Toy
    California
    2011 Tundra Limited
    So it is already factory wired to drop the new parts in?
  4. Mar 12, 2016 at 4:40 PM
    LTD_Toy
    California
    2011 Tundra Limited
    Yes it is a limited and it has the JBL system
  5. Mar 12, 2016 at 4:47 PM
    Red Freighter
    Fred
    Oregon City
    Can anybody come up with a part number? These are very expensive from Toyota you will probable what to shop for a used one.
  6. Mar 12, 2016 at 4:54 PM
    Red Freighter
    Fred
    Oregon City
    Yes all the plugs should match perfectly. Your tail gate probable has the wires in it for the back up camera. This should be a fun and easy mod. I don't have any experience with the gps antenna.
  7. Mar 12, 2016 at 5:33 PM
    My buddy just did it the other week. Hooked right up- zero issues
  8. Mar 12, 2016 at 6:11 PM
    LTD_Toy
    California
    2011 Tundra Limited
    Sweet!!! Thank you
    It will be a great addition.
    Thank you
  9. Mar 2, 2017 at 12:55 PM
    Toyotas Rule
    Toyotas Rule New Member
    Nate
    LTD_Toy Did you install the new deck with nav and back-up? If so, what kind of deck did you install and where did you buy it?
    I am looking to do the same thing that you were and hope I can find a Toyota JBL OEM deck.
    Thanks
  10. Mar 2, 2017 at 2:19 PM
    Red Freighter
    Fred
    Oregon City
    I ended up buying a top of the line Jensen from a shop I would not recommend.
  11. May 12, 2017 at 9:57 PM
    Beryllium
    Beryllium New Member
    Hey all,
    I have a base version I've been upgrading. The stock radio is next. I assume that means I am the non JBL. What does that mean for me? I won't have the right hookups and harnesses waiting for me?
  12. May 12, 2017 at 11:31 PM
    Red Freighter
    Fred
    Oregon City
    You can get a a non Jbl navigation system and it will be plug & play. My old stereo sounded like crap I don't know if the non JBL with navigation sounds any better. I bought a non JBL navigation 86120-oc360 that fits 04/2009 to 09/2011 for $400 and the antenna plug was not a match so I didn't use it.
  13. May 13, 2017 at 12:04 AM
    Red Freighter
    Fred
    Oregon City
    If you want it it yours for $400.
  14. Nov 18, 2017 at 1:25 PM
    WV tundra dude
    WV tundra dude New Member
    2014 Toyota Tundra
    I have a 2014 Toyota Tundra with a non jbl radio. There radio keeps trying to boots but just keeping rebooting. The backup cam works great. My question is how do I swap out radio for another Toyota radio. I have read where you cannot just trade out radios because its connected to the computer system and thus the radio will partially work. Things like satellite and navigation will not work.
    Can anyone help me out with the truth or procedure.
  15. Mar 30, 2018 at 10:43 AM
    shase12
    shase12 New Member
    Adrian
    2008 Gold Tundra Base Model crew max
    headlights
    Hi I have a base model 2008 tundra and I bought the jbl head unit the harness is not the same how could I get it to work? or do I have to buy the whole entire harness from a jbl equipped tundra?
  16. Jan 12, 2019 at 2:33 PM
    Alaf302
    Alaf302 New Member
    Anthony
    Hi did you get an answer on jbl wiring harness for your 2008 tundra
