Wood grain
Discussion in '1st Gen Tundras (2000-2006)' started by 912, Aug 17, 2020.
  1. Sep 6, 2020 at 6:41 AM
    912
    912 [OP] @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    That's pretty wild! Never seen it before. Is it hydrodipped?
    Stuck in the '00s likes this.
  2. Sep 6, 2020 at 6:34 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    I like it!
    Too bad I like woodgrain more.
  3. Sep 7, 2020 at 11:52 AM
    NWPirate
    Zach
    WA
    That is pretty wild, here my wife's 04 limited Sequoia. Wasn't a fan of it at first but it's grown on me.
    artsr2002, bmf4069, bokch0y and 3 others like this.
  4. Sep 10, 2020 at 1:58 PM
    912
    2005 DC 4x4
    Swapped over my bezel yesterday. The switches are tricky but pretty manageable if you take your time. The toughest part is circled. I think it really helped that all the parts were 85 degrees here in Florida, so nothing broke.
    6093294D-1A4D-46BE-88FE-031B32F53C08.jpg B334292D-78D4-4B77-8B2D-54F7D827E72C.jpg AD6A7871-39CB-490E-95A4-BFF9445CC90B.jpg 7D79D57F-8F4B-492D-8A00-7F2DBE23AEB3.jpg 8E1D310B-A3C1-460A-A012-9501580A06A9.jpg 3A12AB4F-769C-4167-870B-4D0217A1DBFD.jpg
    shifty`, ktundra, bmf4069 and 2 others like this.
  5. Sep 10, 2020 at 4:47 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Hey, If you dont mind a change of subject.
    I noticed your headunit.
    I am doing mine soon. Had decided on a sony since that seemed to look more oem. Flat black to match the dash. Instead of the high gloss black on other brands.
    But from your pic that panasonic does not look as aftermarket as I thought they would. Blends in better than I thought. Do you like it so far?
    912[OP] likes this.
  6. Sep 10, 2020 at 5:17 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Cool beans!
    912[OP] likes this.
  7. Sep 11, 2020 at 3:32 AM
    912
    2005 DC 4x4
    It’s a pioneer and I like it a lot so far. Paid $345 through crutchfield. I read a lot of reviews and watched a lot of YouTube videos and this one seemed the be the leader in this price point. I also appreciate the OEM look rather than a flashy aftermarket look. The only thing I would really consider is wireless AA/CarPlay. Next time I’d pay the extra money for that feature bc I’ve quickly leaned how much I hate cables being out in the open in my truck. But units with wireless AA/CP start around $650.
    https://www.crutchfield.com/p_130DM2660/Pioneer-DMH-2660NEX.html
    here are a few pics before the wood swap:
    C04B56E9-BFD6-4B46-B322-AF513019FC90.jpg FE03236C-969D-4D96-8A2F-3346026D233B.jpg
  8. Sep 14, 2020 at 6:25 AM
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    @912 That looks great! I'd like to swap my wood grain out, but the black wouldn't match the beige interior.
    What are USB outlets / switches are you using to modify the two rectangular factory switch locations? They look like a simple swapout, but I'm sure they aren't plug and play.
    912[QUOTED][OP] likes this.
  9. Sep 14, 2020 at 10:54 AM
    Mine is black with beige interior. It looks perfectly normal. Go for it!
    Tundra2, 912[OP] and ktundra[QUOTED] like this.
  10. Sep 14, 2020 at 11:44 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
    Black and Tan!
    bmf4069[QUOTED] likes this.
  11. Sep 14, 2020 at 12:28 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Wood grain for the win!
    912[OP] and ktundra like this.
  12. Sep 14, 2020 at 1:30 PM
    These bastards here are the real shits! For the record, I half-sheared off a couple of the protruberances there and the button still snapped together and held. But there must be a good way to separate those SOBs easily!
  13. Sep 14, 2020 at 11:27 PM
    912
    2005 DC 4x4
    one of these: https://smile.amazon.com/gp/product/B01EN5E3X2/ref=ppx_yo_dt_b_asin_title_o06_s04?ie=UTF8&psc=1
    and one of these: https://smile.amazon.com/gp/product/B013W8LQ7C/ref=ppx_yo_dt_b_asin_title_o06_s03?ie=UTF8&psc=1
    Cheap, but they get the job done and fit the switch space
  14. Sep 15, 2020 at 4:03 AM
    ktundra
    Lex
    NJ
    Bilstein 5100
  15. Sep 15, 2020 at 7:25 AM
    035VZFE
    035VZFE Restored a Tundra top to bottom
    James
    Vero Beach, Florida
    2009 Passat B6 2.0 Turbo
    ECS Tuning DV Spacer ECS Tuning Turbo Muffler Delete ECS Tuning Luft-Technik CAI System A-Spec 60mm Charge Pipe Straight piped from resonator back, stock cat and downpipe
    TFL; I like :)
  16. Sep 15, 2020 at 2:44 PM
    912
    2005 DC 4x4
    just be careful, they're definitely cheap. When I first pugged a USB cord into the voltmeter one, it pushed the back of the switch off and i had to take it a part all over again. So just make sure to fiddle with them and reinforce as needed before you go to use them ;)
    ktundra[QUOTED], shifty` and bmf4069 like this.
  17. Jan 21, 2024 at 9:53 AM
    chlorophil
    chlorophil New Member
    Reno, NV
    2004 Green Tundra DC 4x4
    Hate to bump this from the past but is there a difference in size for the bezel with the ac controls? also for the window controls. 00-02 and 03-06?
  18. Jan 21, 2024 at 9:58 AM
    daveeasa
    Several versions of this thing. Same exterior dimensions. Newer ones have a wider radio opening. There are kits to reduce that to double din size. But the primary reason to match your existing one is button layout. Hazards, 4wd, passenger airbag, and low gear are all different across years and trims.
    I believe the window switches on the driver door are all the same size as well but less confident on the versions there.
    chlorophil[QUOTED] likes this.
  19. Jan 21, 2024 at 10:25 AM
    Older units also have a hazard button. The '05-'06 with the 5AT transmissions had to add the "SHIFT L" button in the center dash too. Earlier years had a lockout provision in the center dash for the passenger seatbelt also, whereas later years had a sensor in the seat, I guess.
  20. Jan 21, 2024 at 10:28 AM
    #50
    daveeasa
    Airbag. Not seatbelt. Mine has it.
    Hazard comes in black or red based on year / trim. The red is fun. I think they can be swapped but never tried.
    shifty`[QUOTED] likes this.
  21. Jan 21, 2024 at 10:33 AM
    #51
    Yes, typo, sorry, brain no function today. Cannot think. Have the dumb.
    daveeasa[QUOTED] likes this.
  22. Jan 21, 2024 at 2:08 PM
    #52
    bfunke
    bfunke Tundra Curmudgeon
    Yes the older FGTs have a smaller opening for the radio. Also noticed the pioneer headunit above is now $100 more expensive…ugh, like everything these days.
