295/70/18 tire thread
Discussion in 'Wheels & Tires' started by Longtimecoming07, Sep 3, 2020.
  1. Sep 3, 2020 at 6:59 PM
    Longtimecoming07
    Longtimecoming07 [OP] New Member
    Rick
    2012 Toyota Tundra
    9824F9D5-C9CB-4558-99D5-8F4572929283.jpg F9E15A09-EFDB-476F-900B-7A1DEA725A12.jpg I’m running a 295/70/18 on trd wheels with 3 inch lift on the front. Is anybody running that size with less than a 3 inch lift in the front?
    Tundra805, CoachJ and Charliefoxtrot like this.
  2. Sep 3, 2020 at 7:02 PM
    Blueknights75
    Ron
    Clayton, NC
    8445E999-0C3B-4506-9A54-91F38A2682A2.jpg Yes...I am running 295 Ridge Grapplers with 5100s on top setting on front which is less than 3”.
    Y0TA PR0, Tundra805, CoachJ and 2 others like this.
  3. Sep 3, 2020 at 8:19 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If you keep the factory +60 offset on your wheels they fit pretty well... Once you start trying to get a little poke is when shit goes to hell. I'm leveled. I added 1" spacers after getting my 295/70R18 installed and had to trim a lot of plastic and push the inner bumper liner forward. I just got new wheels with a +18 offset and will be doing more work...
  4. Sep 4, 2020 at 4:56 AM
    Longtimecoming07
    Rick
    2012 Toyota Tundra
    I’m trying to get a lower Stance. I’m going to order the demello hammerhead bumper I’m hoping with that I can get a little lower. I saw on a thread that somebody used a head gun on the rear of the front fender and pushed it back just a bit so I might try that when I get the bumper in.
  5. Sep 4, 2020 at 5:31 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    UPDATE:2024 I GOT ME SOME 35X12.5 (required some cutting lol)
    295/70R18 nittos: 3/2 on my rig20200317_160937.jpglove the rake with a 3/2 lift
  6. Sep 4, 2020 at 6:54 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    5100 top setting on Sequoia 2.3"
    5100 bottom setting with 2" spacer on Tundra 2.8'
  7. Sep 4, 2020 at 8:17 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Toytec Boss kit set at 3/1.5. 18x9 Method NV +25 offset. 295/70/18 Toyo AT2 Extreme.
  8. Sep 4, 2020 at 8:27 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
  9. Sep 4, 2020 at 8:56 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    295/70/18 with Bilstien 6112 @ 1.9” in front and stock rear. Wheels are SCS Ray10's which are 9x18 +25 offset.
  10. Sep 6, 2020 at 8:44 AM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    Love the look. I have the exact same truck, just got the Ray10's , ordering the Bilstiens this week and wanted to run 295/70/18 but I am worried about rubbing,cutting etc. I don't really have a shop around me that specializes in 4x4, more general mechanics who wouldn't be comfortable in chopping, cutting any metal. Did you have to do any trimming/cutting to get the 295's to fit ?
  11. Sep 6, 2020 at 11:28 AM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    Thanks. It wasn’t bad at all to get rid of rubbing issues. Here’s what I had to do:
    https://www.tundras.com/threads/how-i-fit-295-70-18-with-scs-ray10s-on-leveled-tundra.57245/
  12. Sep 6, 2020 at 11:34 AM
    tundrasportinMA
    Western Mass
  13. Sep 8, 2020 at 3:58 PM
    MAN N BLK
    MAN N BLK New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    295/70 18 Courser CXT. 6112s at middle setting.
  14. Sep 9, 2020 at 10:27 AM
    Lobodog1
    Lobodog1 New Member
    6112's at 2.5+ 1 DS shim in front and 5100's with 1.5 shackles in back.
    Dick Cepek trail country exp 295/70/18
  15. Sep 9, 2020 at 10:32 AM
    MAN N BLK
    Rickie
    In time
    DBC5F859-3CB1-4CEE-A60F-1CC390783424.jpgCouldn’t get pic to load last time. But here she is.
  16. Sep 9, 2020 at 12:06 PM
    PermaFrostTRD
    Northern NY
    Awesome truck. Are you running any wheel spacers to fit those on the stock wheels?
  17. Sep 9, 2020 at 12:27 PM
    MAN N BLK
    Rickie
    In time
    No spacers. Just removed small flaps on front of wheel well. Occasionally rubs on front inner fender.
    PermaFrostTRD likes this.
  18. Sep 9, 2020 at 1:48 PM
    Sanguiniux
    Sanguiniux New Member
    2016 Tundra SR5 double cab
    2 inch level on front.
    Put a 2 inch leveling kit on. Rocking 275/65/18. Want to goto 295/70/18. Here’s the stock tires with level kit on. I should be able to handle 1 1/2 higher and 1/2 wider with this size right?
    Silverghost likes this.
  19. Sep 9, 2020 at 2:09 PM
    MAN N BLK
    Rickie
    In time
    Yes you’ll have room. Id plan on taking small flaps off like I did and most do anyway.
  20. Sep 9, 2020 at 2:13 PM
    MAN N BLK
    Rickie
    In time
    I noticed today when pulling my utility trailer that my shifting with tow/haul on is all crazy after going up in tire size. Trailer weighs about 1000 lbs empty. Doesn’t do it in tow/haul without trailer.
  21. Sep 9, 2020 at 2:14 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Do you have a speedometer calibrator?
  22. Sep 9, 2020 at 3:40 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    295/70/18 with Bilstein 6112 @ 1.9” in +1 coach builder shim each side (Front). Rear = 1.5" CB shackle. Wheels = SCS Ray10's (9x18 +25 offset).
  23. Sep 9, 2020 at 3:46 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Love the Red with the Gunmetal Ray 10's.....Awesome look
  24. Sep 9, 2020 at 3:52 PM
    MAN N BLK
    Rickie
    In time
    No calibrator for speedo
  25. Sep 9, 2020 at 3:55 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That might be part of your problem. I was running around 5 mph off of GPS speed after I put my tires on. And I've heard it can mess with shift points too.
  26. Sep 19, 2020 at 11:10 AM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Here is mine:
  27. Sep 19, 2020 at 12:51 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    Imo, the best tire size for your truck. Keeps it fast and agile, and lighter than 35s. A lot of 34s are 34.25 inches, and mostly all 35s are like 34.99. Not much of a difference. And they’re skinnier, which is always a benefit. 15CC89DC-A330-444E-83C4-1642190F8A86.jpg38E3608D-6CDB-438E-A963-DB35E09FAB8B.jpg
  28. Sep 19, 2020 at 1:14 PM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Running the same kit. Cement crew baby!
    300BLK likes this.
  29. Sep 20, 2020 at 3:42 PM
    Sanguiniux
    I am think of adding 1.5” hub centric spacers on the wheel to add some space and to make the look “beefier”, any luck or experience with wheel spacers?
    MAN N BLK[QUOTED] likes this.
  30. Sep 20, 2020 at 3:48 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I've seen the thread on "Stock TRD PRO with 295/70/r18" some aren't using wheel spacers some are because the dire is very close to the UCA. My question is I've got 6112 at 1.9" which puts me close to PRO height and I'm on factory wheels, could I go 295/70 and be ok? Currently running 275/70 and want more fill in the whell well.
    AlaskanAssassin likes this.
