  1. Sep 2, 2020 at 1:07 PM
    #7471
    This ties back into a specific conversation with @Ckat recently over here. You know, you were in it. Sounds almost like this is status-quo.
  2. Sep 2, 2020 at 1:08 PM
    #7472
    ktundra
    ktundra rust be damned
    Lex
    NJ
    06 Tundra DC Limited 4WD
    Bilstein 5100
    This is what I saw being used. He first tried a prybar, but no joy.
  3. Sep 2, 2020 at 1:24 PM
    #7473
    Professional Hand Model
    Fred
    Hand Protectors
    Good link. Thing is I don’t feel the extreme draw or change in power as described in that conversation. I can feel a slight difference in driving power, but not much. I do notice the dash change 4%, though.
  4. Sep 2, 2020 at 1:26 PM
    #7474
    I give him a 6.5. Could've been an 8 if he'd have ironed the gloves first.
    bmf4069 and FrenchToasty like this.
  5. Sep 2, 2020 at 1:35 PM
    #7475
    Fred
    Hand Protectors
    Any reccos on the pulley puller?
    How about the fan clutch puller? I want to replace this and understand there is a special tool for this job, as well.
  6. Sep 2, 2020 at 1:41 PM
    #7476
    Fred
    Hand Protectors
    Hamilton Beach makes an excellent Rice Steamer. Use CalRose Brand Rice. Make sure you rinse the grain 6 times before steaming the Rice. You will make Sensei proud.
    TX-TRD1stGEN likes this.
  7. Sep 2, 2020 at 2:01 PM
    #7477
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    That's where I'd start and experiment a little lower if you're needing more traction. Having a decent compressor will also be helpful to air things back up.
    NUDRAT[OP] and Darkness like this.
  8. Sep 2, 2020 at 2:18 PM
    #7478
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You'll have fun. Bring a snatch strap just in case.
    Pro tip: whenever you stop or park, try to do so with your front end aiming downhill. Easier to get going again without burying yourself.
    NUDRAT[OP], bmf4069 and Lil Steve like this.
  9. Sep 2, 2020 at 2:34 PM
    #7479
    Mmmmmm snatch strap.
  10. Sep 2, 2020 at 2:40 PM
    #7480
    ktundra
    Lex
    NJ
    Bilstein 5100
    Are you also looking to change the crankshaft and camshaft seals? I cringe having to shell out $100 for the install kit with the stacking rings:
  11. Sep 2, 2020 at 3:01 PM
    #7481
    Fred
    Hand Protectors
    Yes. I’ll be replacing both Cam Seals and the one Crank Seal. From the one youtubes vid I watched on this topic, the mechanic didn’t use a special tool for the install. Think he used a PVC type fitting and made sure he tapped it flush.
    To remove the seals, he had a Lisle Seal Puller (brand new for vid) but chucked it in lieu of using a large nail and pried them out. He looked to be a pro mechanic with a shop. The 4.7L was pulled out and on an engine holder device.
  12. Sep 2, 2020 at 3:03 PM
    #7482
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  13. Sep 2, 2020 at 3:20 PM
    #7483
    ktundra
    Lex
    NJ
    Bilstein 5100
    I was thinking of custom 3D printed sleeves that would be better than the PVC pipe, but I can't find any freely downloadable designs. I'd offer to print them up for free if anyone here can design them or grab free designs to download.
    Hmm, nail trick is interesting. I have that Lisle tool sitting in my Amazon cart.
  14. Sep 2, 2020 at 3:24 PM
    #7484
    Fred
    Hand Protectors
    Yeah. Something custom would work. I’ll need to watch that video again. It was Part 1 of 3 in a Series. Didn’t watch the others yet. I’m wondering if using the old seal as a backer combo’d up with the PVC fitting would work with pounding it in. For some reason, I don’t remember it being that difficult to install.
    ktundra[QUOTED] likes this.
  15. Sep 2, 2020 at 3:30 PM
    #7485
    ktundra
    Lex
    NJ
    Bilstein 5100
    I don't think it's hard to install the new seal, but you want to avoid ruining it or creating gaps if doesn't go in squarely. Those tools seem excessive. Even Timmy ended up hammering in the crank seal.
  16. Sep 2, 2020 at 3:51 PM
    #7486
    I used a pvc coupling on my rear axle seals. They work good. As for using the old seal, it might be hard trying to get it, the new seal, a coupling, and a hammer all lined up with only two (golden) hands in that tight space. Unless you're pulling the radiator too.....
  17. Sep 2, 2020 at 4:21 PM
    #7487
    Fred
    Hand Protectors
    Yeah. I’ll be pulling the Radiator. Just watched the (updated) video of the one I described watching above. Starting to feel nauseous about this. :puke:
  18. Sep 2, 2020 at 5:09 PM
    #7488
    ktundra
    Lex
    NJ
    Bilstein 5100
    You got this! I’ve committed to do this at spring 2021, lol.
  19. Sep 2, 2020 at 5:55 PM
    #7489
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I think my Avalon still looks better. But the airflow on the corolla is amazing[​IMG]
  20. Sep 2, 2020 at 9:23 PM
    #7490
    I have faith in you. I imagine itll take you a bit longer, seeing how every not and bolt will need to be thoroughly cleaned and labeled before being replaced. Much feather dusting will be done.
  21. Sep 2, 2020 at 9:36 PM
    #7491
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    He will strictly rinse his parts in Tahitian rain and blow them dry with a genuine Caribbean sea breeze, then carefully apply a few dabs of imported coconut oil imported from Oceana to prevent rust.
  22. Sep 2, 2020 at 9:40 PM
    #7492
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Had a good laugh at this
  23. Sep 2, 2020 at 9:40 PM
    #7493
    That’s a lot of importing!!! I like it!!
  24. Sep 3, 2020 at 4:34 AM
    #7494
    Whoa whoa whoa, PHM doesn't import. He locally sources. Whirled peas and what not.
  25. Sep 3, 2020 at 4:36 AM
    #7495
    ktundra
    Lex
    NJ
    Bilstein 5100
    This must be the video you are referring to. He used a nail punch to puncture the large rubber flappy part of the camshaft seal and pull it out. I didn't realize our V8's seals don't resemble typical camshaft/crankshaft seals. I suppose you can use a spring hook to do that.
    To install the seals, he just used some special yota seal compound and used his hands to push them in, lol.
    I also saw that he used a special harmonic balancer / pulley tool to extract the crankshaft wheel. "usually a brass hammer with light tapping will get it out, but this one is stuck"
  26. Sep 3, 2020 at 4:48 AM
    #7496
    Fred
    Hand Protectors
    Yep. Thats the vid. Looks straight forward on the Seals remove/install. The punch/pry worked really nice versus the Special Puller that he had flopping around.
  27. Sep 3, 2020 at 4:55 AM
    #7497
    Fred
    Hand Protectors
    I really like your idea of the coconut oil from Oceana, but thinking a cold pressing of Organic Olive Oil from Italia might be in order. This would balance out the Globull Weighting Distribution from equidistant parts of the Wurrld. :rofl:
  28. Sep 3, 2020 at 5:05 AM
    #7498
    ktundra
    Lex
    NJ
    Bilstein 5100
    Looks like this will do the trick?
  29. Sep 3, 2020 at 5:10 AM
    #7499
    Been thinking about my truck not starting last week and I really think Seafoam had something to do with it. I had just poured seafoam in the gas tank and 6oz in the crankcase. Reading online some people feel it's risky to pour it into an old engine because it can free up large carbon deposits which can then do things they shouldn't do. The fact that my truck has never done anything like that before or after makes me think that was the issue. I may stick to just using Seafoam in the gas tank occasionally.
  30. Sep 3, 2020 at 5:46 AM
    #7500
    ngl, this is the exact generation of Camry my now-wife had in green when we met, and it's the car that turned me into a Toyo-fan. That car was damn near unbreakable, absurdly reliable and so cheap to maintain it was silly.
    NUDRAT[OP], bmf4069, Pucks18 and 2 others like this.
