19-20 Discussion on Missing Ambient Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, Aug 22, 2020.
  1. Aug 31, 2020 at 7:25 AM
    #61
    Ruggybuggy
    Ruggybuggy [OP] Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You have to remember that what we do in the "backyard" and throwing a cooler together is not something Toyota can do. Designers and engineers have to be involved and then testing to make sure that its sound. A simple add on takes time and huge dollars. If it can be removed to save money and complexity it would be especially if there is no adverse effects on the normal operation of the truck.
    I was one of those that was planning to buy the new 2020 Tundra when it came out. 2020 rolled around and nothing. Because of the delays in bring out the new Tundra I got suspicious thinking they may be having issues. I decided I didn't want to take a chance on the first model year so purchased the the old reliable design. As far as inside info Toyota doesn't tell their techs anything. The info I got on the New Tundra that was suppose to be out in 2020 was from the dealer principle. He came back from one of the regional dealer meeting to tell me the new Tundra was coming out in 2020.
    BravoDeltaRomeo and SomeGuy4 like this.
  2. Aug 31, 2020 at 7:33 AM
    #62
    Greg Marmalard
    Greg Marmalard New Member
    2019 Tundra TRD Off Road Double Cab
    They are not reinventing the wheel!
    The same transmission has used external cooler before! It's rock solid technology!
    To adapt your quote: "Designers and engineers have to be involved and then testing to make sure that its sound. A simple REMOVAL OF A PART takes time and huge dollars." They must have spent a good amount of money to make sure it gets at least through standard warranty period...
    All things considered you stay with tried an true technology and don't mess with what works..
    Obviously ATF coolers are a weak spot in Toyota engineers book. From pink milkshakes to combining with AC condenser to removal...meanwhile the rest of the industry uses a tried and true external cooler.....
    I've yet to read of an issue with external coolers...perhaps I missed them but since the Tundra TRD OFF ROAD is conceivably designed for OFF ROAD use not to mention towing....a robust ATF cooler de rigueur!
  3. Aug 31, 2020 at 8:18 AM
    #63
    Bammer
    Monroe, CT
    Were you talking to someone? Or did you leave a message?
  4. Aug 31, 2020 at 8:25 AM
    #64
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Yay!! Its back!
    betotundra likes this.
  5. Aug 31, 2020 at 8:55 AM
    #65
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And what was their response?
    BravoDeltaRomeo likes this.
  6. Aug 31, 2020 at 8:58 AM
    #66
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toyota would never had changed anything if they could have left it alone but because of regulations that forced the use of R1234YF the ambient cooler had to be removed.
  7. Aug 31, 2020 at 11:26 AM
    #67
    Bammer
    Monroe, CT
    I've seen 243° with an empty trailer going up a long hill. So wtf????
  8. Aug 31, 2020 at 11:42 AM
    #68
    timsp8
    NY
    Remember, Roy G. just answers emails. He isn’t the engineer that removed the cooler. Not sure what manual he got 221 from, but others on here said that wasn’t the upper limit. Light doesn’t even come on until 302. I’ve seen over 221 with mine with cooler pulling a load up a long hill.
    BravoDeltaRomeo and Bammer like this.
  9. Aug 31, 2020 at 11:59 AM
    #69
    AZBoatHauler
    So.Arizona
    My question is this - under what circumstance would the transmission operate at 68*F? That makes no sense.
  10. Aug 31, 2020 at 3:28 PM
    #70
    timsp8
    NY
    If that’s correct, then every tundra is overheating. Even ones with coolers. And that would be more reason for them to not have removed the cooler.
    Thanks for posting the email. But I don’t put a lot of faith in Roy’s answer.
  11. Aug 31, 2020 at 3:30 PM
    #71
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Fussion app readings for the pan and TC are correct. I've compared them using Techstream.
    rebmo and SomeGuy4 like this.
  12. Sep 1, 2020 at 3:20 AM
    #72
    Bammer
    Monroe, CT
    Well the truck is going in today for a steering issue , so I will inquire and see what they say. I hate getting caught up in hype, speculation and unsubstantiated facts , but I keep my vehicles a long time and put on some mileage. So it might be a worthy investment???
    SomeGuy4 likes this.
  13. Sep 1, 2020 at 6:18 AM
    #73
    Bammer
    Monroe, CT
    Service writer was clueless, as was the assistant service manager. The question was put to me, "why would you need to add to what is already there"? My response, why wouldn't you want to book a thousand dollar service?? :frusty:
    jetfishn and SomeGuy4 like this.
  14. Sep 1, 2020 at 6:36 AM
    #74
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Lol at the 68-221f operating range.
    Mine never had a trailer connected to it and easily exceeded that.
    SomeGuy4 and Ruggybuggy[OP] like this.
  15. Sep 1, 2020 at 7:30 AM
    #75
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    That 68-221 sounds like the trouble code parameters mentioned in the other now locked Transmission Cooler Missing thread that the original poster was taking as the operating temps.
  16. Sep 1, 2020 at 7:31 AM
    #76
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Most service writers are clueless. It's a job nobody wants and most don't last to long in the position.
  17. Sep 1, 2020 at 10:03 AM
    #77
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Read post #75 above... it looks like this info came straight from Toyota Customer Service.
  18. Sep 1, 2020 at 10:18 AM
    #78
    Clemsonman14
    I understand it came from Toyota rep. I think he got the information from the same place @Ruggybuggy pulled this information about a trouble code.
    A couple of posters in multiple threads have misinterpreted this code for the normal operating temps when it obviously isn’t. I don’t think it is coincidence that the temperatures for the trouble code as well as the reps response are the same. It seems like a misinterpretation on the reps part
    https://www.tundras.com/threads/2019-2020-transmission-cooler-missing.72484/#post-1861105
    GODZILLA and AZBoatHauler like this.
  19. Sep 1, 2020 at 10:21 AM
    #79
    timsp8
    NY
    And that code just refers to a defective sensor. Nothing indicative of temp fluid I believe.
  20. Sep 1, 2020 at 10:40 AM
    #80
    Clemsonman14
    Exactly. Pretty much everyone has had trans temps over 221 at some point more than likely if they don’t have the cooler so there’s no way that’s the top operating temp for normal
  21. Sep 1, 2020 at 10:48 AM
    #81
    timsp8
    NY
    And if it was then that’s when the overheat light would come on. But it comes on at 302, 81 degrees higher.
  22. Sep 1, 2020 at 10:51 AM
    #82
    Bammer
    Monroe, CT
    Toyota Customer Experience Center, WTF is that??? Cut and dry disclaimer about modifying and or using non Yota parts, where he go those numbers from is anybody's guess.
    Clemsonman14 and Cpl_Punishment like this.
  23. Sep 1, 2020 at 2:20 PM
    #83
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Ill bet that 221 temp is based on the 18 and older trucks WITH a cooler... since mine wont even get near 200 after adding the cooler.
    Toyota probably changed the warning light trigger and "normal operating temperature" window on the 19/20 trucks.
  24. Sep 1, 2020 at 7:32 PM
    #84
    betotundra
    betotundra Toyota for Life
    hagrid[QUOTED] likes this.
  25. Sep 1, 2020 at 7:38 PM
    #85
    Once your ScanGuage is updated, you can see your tire pressures as well. I need to update mine.
  26. Sep 1, 2020 at 8:13 PM
    #86
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Speaking of which, I received a brand new ScanGaugeII back from them today! The buttons are different. Can't wait to play with it this weekend - too much going on with work right now.
  27. Sep 1, 2020 at 10:03 PM
    #87
    I wonder if I would get a new one back if I sent mine in. Snap a pic of it when you get a chance.
  28. Sep 1, 2020 at 10:27 PM
    #88
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Do you take the temp at the same place as Toyota engineers? Do you use a mean or median average? How many data points?
    I just got through conducting a noise test on a hydrostatic drive system. Lol I didn't just take a db meter and take one data point. I spent weeks designing the test. I took a total of 942 readings for one set of conditions. My conditions consisted of temp, rpm, ambient noise, oil viscosity, type of oil, etc.
    I ran 27 different conditions of 942 db readings. I can guarantee you my tests don't hold a candle to Toyota's test parameters. We simply cannot do things on the scale they do.
    My point is you have one data point. They have millions.
    Cpl_Punishment, hagrid and Bammer like this.
  29. Sep 2, 2020 at 3:59 AM
    #89
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    You should've come out my way and sampled my BX23S roaming aboot the yard cutting grass.
    The result of your testing would = f'ing loud.
    GODZILLA, FUSE86 and Cpl_Punishment like this.
  30. Sep 2, 2020 at 4:04 AM
    #90
    timsp8
    NY
    All I said is I’ve seen over 221 and didn’t get an overheat light. Why don’t you go to the lift threads and tell those people how wrong they are for messing with Toyota’s “millions” of data points by changing their suspension? Or those who switch their lights to LEDs? Hell, I added an A.R.E. cap. I guess thats wrong cause Toyota didn’t add it at the factory and I didn’t test the new aerodynamics with millions of data points.
    Your posts have added nothing to this discussion. If people want to add a cooler with their money, good for them. They’ll deal with the consequences. I don’t get why you care so much. And we get it. You’re an engineer. You like to point that out in every post. But you could be a train engineer for all we know.
