  1. Aug 12, 2020 at 5:28 PM
    #6871
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I was thinking of a wet sanding technique with super fine grit sand paper, or something. There are quite a few superficial scratches that I've been thinking about.
    I was planning on removing the gauge cluster again eventually.
    In the blue circles are the 194 LED backlights I installed who knows how long ago...
    Pink is all the indicator lights such as CEL, Low fuel light, etc... Still incandescent bulbs in those locations. If memory serves @empty_lord mentioned Neo-wedge products for these locations? I can't remember if the bulb is removable from the twist base in these areas. If so, I think it'd be a T5 LED?
    The one pink with a red arrow burned out a long time ago, and I never replaced it when I did the 194s. Having that one dim section of dash has been bugging me more, and more.
    In green are the shift lights. Not sure if there are any led aftermarket twist bulbs for that. I hope so, but want to have all parts on hand when the dash comes apart again. Any help here on these? I know PHM went OEM in this location for fitment purposes, but I never wanna tear the cluster out again after this. The buck stops here.
  2. Aug 12, 2020 at 5:41 PM
    #6872
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I think I'd go with a plastic polish on the lens over sand paper.
    The fuel light has to stay incandescent or it won't work. There's a chart in the FAQ with all the bulb numbers.
  3. Aug 12, 2020 at 5:44 PM
    #6873
    Professional Hand Model
    Fred
    Hand Protectors
    The 4 blue circled and the one pink with arrow I replaced with LED. The green area I just replaced the P and D with OEM. The others I left alone as they probably will never go out. If they do go out then just use incandescent to be on the safe side.
  4. Aug 12, 2020 at 5:49 PM
    #6874
    Fred
    Hand Protectors
    I just watched a youtubes and the guy was feather dusting his dash lens!:rofl:
    He used Chrome and Mag Polish on the lens with a conical buffer on an extension with his cordless drill.
    I have some and just used it the other day to polish my Aluminum Battery Hold Down Bracket. Never tried it on plastík.
    Tundra2 likes this.
  5. Aug 12, 2020 at 5:51 PM
    #6875
    Fred
    Hand Protectors
  6. Aug 12, 2020 at 5:53 PM
    #6876
    Damn you need to Novus that lens to get the scratches out. The dust is nothing compared to those damn scratches. Process to use it is basically this but you could probably get away with just using 600 wet, then 1200 wet, then doing the 3 Novus and 2 Novus steps.
    Tundra2[QUOTED] likes this.
  7. Aug 12, 2020 at 5:56 PM
    #6877
    Fred
    Hand Protectors
    You think he used his ice scraper on there?:rofl:
    GODZILLA, shifty`[QUOTED] and Tundra2 like this.
  8. Aug 12, 2020 at 5:57 PM
    #6878
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Acrylic finger nails
    I do drag shows on the side...
    :anonymous:
  9. Aug 12, 2020 at 5:59 PM
    #6879
    If I didn't know any better I'd swear he used steel wool to clean it, or even worse a Brillo pad :annoyed:
    But seriously, I get it. That's a scratch prone spot. And plastics/acrylics tend to get those weird 360° scratches everywhere, although I won't pretend to understand why. Every acrylic turntable lid I've ever seen has them. It's tedious to get them out, but it's a one-tie investment to buy several years of smooth plastic!
  10. Aug 12, 2020 at 6:01 PM
    #6880
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    never seen one leak. but it can happen.
  11. Aug 12, 2020 at 6:02 PM
    #6881
    empty_lord
    05 rollover special
    they should be toshiba type T bulbs. the switches in our trucks are neowedge.
    DO NOT CHANGE THE LOW FUEL LIGHT TO LED. the bulb acts as a resistor and the light will not function correctly with an LED
  12. Aug 12, 2020 at 6:11 PM
    #6882
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I remember seeing the Toshiba twist base now that you've jogged my memory, but I can't remember if the pink bulb(s) is "removable" from the base. Its been awhile since I've been in that section of the dash.
    10-4. I know my low fuel light worked as of last year when I ran her low to make sure. It was weird seeing it slowly come on, and off. Fading in/out.
  13. Aug 12, 2020 at 6:24 PM
    #6883
    empty_lord
    05 rollover special
    they can be removed but finding an LED that fits and doesnt hit the lense is the issue
  14. Aug 12, 2020 at 6:26 PM
    #6884
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hmm, I see. Maybe the push in base of an led could be trimmed down.
  15. Aug 12, 2020 at 6:27 PM
    #6885
    empty_lord
    05 rollover special
    might finally found myself a mk2 MR2. utah $2000.. someones going to look at it and check for rust and collision damage. so fingers crossed its a good one..
    n/a manual with a bad 2nd gear syncro (doesnt matter its getting a Scion TC 6 speed manual with a toyota sienna 3.5l
  16. Aug 12, 2020 at 7:01 PM
    #6886
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    My friends dad works at TRD as a dyno opperator and I went over to fix his computer. As payment I got a free trd hoodie c:08086A79-4F0B-4AA8-865F-DD5E3196D1B9.jpg
  17. Aug 12, 2020 at 7:03 PM
    #6887
    jImmegart
    Jonah
    California
    I have always wanted a mr2. Alot of clapped out ones over here, nothing relatively stock. Mighty car mods did some videos with one they bought and seems like and interesting car to work on
    Darkness and empty_lord[QUOTED] like this.
  18. Aug 12, 2020 at 7:15 PM
    #6888
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Why V6 instead of turbo 4?
    I know this is against the laws of the universe but a Chevy 6.2 isn’t that far off in weight and size compared to the V6
  19. Aug 12, 2020 at 7:23 PM
    #6889
    empty_lord
    05 rollover special
    Soooo.
    Is he adopting?
  20. Aug 12, 2020 at 7:26 PM
    #6890
    empty_lord
    05 rollover special
    The Toyota 3.5l happens to be a fair bit lighter than the stock turbo motor, bolts in mostly with only one custom mount required, wiring is not a big deal with only 40ish wires to make everything including cruise control work, with exhaust work a stock 3.5 out of a siennna with the oil cooler can push 300hp to the wheels with the e153 transmission reliably on a track for hours at full 7500rpm, with cams and springs stock bottom end will make power well over 8000rpm reliably.
    And I have a 3.5 sitting at the lockup with 16k miles that needs a rebuild because water got into it. So 400-450whp n/a I’d easily achieved bumping it up to 3.7l and 12.5:1 compression with 93 octane gas.
    shifty`, GODZILLA, bmf4069 and 3 others like this.
  21. Aug 12, 2020 at 7:34 PM
    #6891
    Hooptytrix
    Dirty South
    That all makes sense but the last part is a done deal. You have the motor all ready, that’s all you had to say :rofl:
    You may have to start a build thread, I’m interested in seeing this happen. What are your plans for the computer? I know toyo computers are a pain and very difficult to hack.
  22. Aug 12, 2020 at 11:57 PM
    #6892
    empty_lord
    05 rollover special
    toyota sienna ECUs have been cracked and can be used with no issues even with a built motor all i need is different injectors and it'll run fine
    Darkness and Hooptytrix[QUOTED] like this.
  23. Aug 12, 2020 at 11:57 PM
    #6893
    empty_lord
    05 rollover special
    and i'll have a build thread. it'll be a while.. i just want an MR2 before theyre too expensive to actually get my hands on
    NUDRAT[OP] and Hooptytrix like this.
  24. Aug 13, 2020 at 12:42 AM
    #6894
    empty_lord
    05 rollover special
  25. Aug 13, 2020 at 4:41 AM
    #6895
    Hooptytrix
    Dirty South
  26. Aug 13, 2020 at 4:45 AM
    #6896
    Fred
    Hand Protectors
    Wallace Wurrld Price Games. Both are the exact spec and both sold at their store.
    mcharfauros and Hooptytrix like this.
  27. Aug 13, 2020 at 4:48 AM
    #6897
    Fred
    Hand Protectors
    guuurll! We need to get you a new nail file.
    bmf4069, GODZILLA and Hooptytrix like this.
  28. Aug 13, 2020 at 4:49 AM
    #6898
    Hooptytrix
    Dirty South
    @empty_lord
    Thought I should look in my area to see if there’s any for sale not an mr2 but it’s small and rwd, classic
    bmf4069 likes this.
  29. Aug 13, 2020 at 5:01 AM
    #6899
    Fred
    Hand Protectors
    That was some amazing amount of gnarly oil you caught up in those ‘catch can’ pictures you put up the other day. How many miles since you last drained it till those pictures you just put up?
  30. Aug 13, 2020 at 5:06 AM
    #6900
    Fred
    Hand Protectors
    You could try. Best thing is just buy the OEM bulb for P and D. Its a tight fit (she said).
    Hows that Fog Switch Bulb Project going?
