Tpms light staying on
Discussion in '1st Gen Tundras (2000-2006)' started by Fieldnstreamer, Aug 11, 2020.
  1. Aug 11, 2020 at 7:09 PM
    Fieldnstreamer
    Fieldnstreamer [OP] Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    So I was driving my 06 dc from northern cal back home to TN and as I climbed in elevation my tpms light came on so I pulled over and checked all tire pressures including the spare and they were all about 32-34 and I thought maybe the elevation and pressure caused the sensor to trip. So when I got home today I filled them all up to about 40psi including the spare and the light is still on sitting here in the driveway. Any ideas why it’s staying on?
  2. Aug 11, 2020 at 7:33 PM
    shifty` Ten EV 12's so you know I raise hell
    Did you push the non-descript button on the dash just under the steering wheel to reset it while the truck is on?
    Pushing and holding the button IIRC just tells the computer to save the current TPM pressure, and if it gets 10psi lower than that, trip the light again.
    Fieldnstreamer[OP] likes this.
  3. Aug 11, 2020 at 7:44 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If you have the original sensors, I've read that the sensors only last 10 years or so.
    They may need to be replaced...
    The lithium ion batteries inside TPMS sensors may last anywhere from five to 10 years.
    Five to six years is a more typical lifespan for older TPMS sensors.
    TPMS sensors don’t broadcast a continuous signal but only broadcast when the vehicle is in motion.
    Even then, the signal is intermittent to conserve battery.
    https://www.mattcastruccihonda.com/blog/how-long-do-the-batteries-in-my-hondas-tpms-sensors-last/
  4. Aug 11, 2020 at 8:02 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  5. Aug 12, 2020 at 3:53 AM
    glowblue
    glowblue From time to time
    VA
    ^This. Most likely 1 or more sensors are not communicating with the TPMS ECU. Check the other threads on how to fix or disable.
  6. Aug 12, 2020 at 10:19 AM
    Fieldnstreamer
    Sam
    East Tn
    Yes I pushed it and also held it but it stays on.
  7. Aug 12, 2020 at 11:47 AM
    NWTundra06
    NWTundra06 New Member
    06 Tundra AC TRD
    It took several visits to the tire shop AFTER having all 5 sensors replaced to get my tpms working right. They ended up replacing all 5 sensors a second time to get it workin.
  8. Aug 12, 2020 at 11:48 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Likely one or more have gone bad....probably looking at a replacement or to just deal with the light.
  9. Aug 12, 2020 at 12:00 PM
    I'm more impressed you drove from CA to TN. :hattip:
  10. Aug 12, 2020 at 12:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Did you check the spare?
    Oh I can’t read. 90% chance you have a dead sensor
  11. Aug 12, 2020 at 12:19 PM
    glowblue
    VA
    Most tire shops will scan your sensors and diagnose the issue for free. It’s the fix that’ll cost you (replace one or more sensors).
  12. Aug 12, 2020 at 6:33 PM
    Fieldnstreamer
    Sam
    East Tn
    As if it was anything but a thing for the truck? Lol easy peezy lemon squeezey
    Yea I'm thinking so. It just randomly came on while I was going down i80 near Reno Nevada
