  1. Aug 10, 2020 at 3:27 PM
    #6781
    Professional Hand Model
    Fred
    Hand Protectors
    Pull the little rubber off. Mine turned orange red and shot out more light.
  2. Aug 10, 2020 at 3:27 PM
    #6782
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Now you've got the swamp brain like the rest of us!
  3. Aug 10, 2020 at 3:29 PM
    #6783
    Fred
    Hand Protectors
    Ya. Thats what people think about really good looking people. They are so really really good looking nobody believes them. Then one day they finally understand.
  4. Aug 10, 2020 at 3:34 PM
    #6784
    Fred
    Hand Protectors
    I’m going to mess with that drivers door switch light tonight. Maybe. Brew up some solder in a copper cup and dip my LED prongs down in there and then glue it over to the circuit board. Danger?
  5. Aug 10, 2020 at 3:49 PM
    #6785
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How I did mine was thus.
    Remove the three small Phillips head screws from white board on the back, and then pry up gently on the WB. There are pins in the white board that go straight up into connectors on the circuit board.
    After the back of the board was exposed I carefully heated up the solder on the old green led, and then pulled each pin up/out of the board individually.
    My new leds had long pins, and I bent them into approximately the same width as holes in the board. Stuck them through as far as I could get them to go, and again carefully soldered the new light in.
    Once it was attached I cut the extra off the back side of the board, and had to file just a little bit of solder from my work down so the WB would fit.
    Mine were polarity sensitive. This is how I put it in, and it worked.
    I had to solder it in twice because I put it in "backwards" the first time. Was nerve wracking for me, but I got it done.
    I have no pictures of the back of the board. As long as you're careful you should be fine. I have an extra switch if you mess yours up.
  6. Aug 10, 2020 at 5:06 PM
    #6786
    Fred
    Hand Protectors
    Went out and did a quick removal of things based on your prior post way back. I even took the mirror switch assy apart and regreased the slider in there. No pics as I was in tight sphincter mode due to the sensitive components.
    Cleaned up the slider copper for the pass side window control. It had some corrosion (maybe why its been sticky?). Electric greased it. Blew out the dust off the assys with some canned air I found at a garage sale. Went out and plugged things up to make sure I didn’t mangle anything. Everything still works! Bulb still works, but dim.
    Plan is cut the existing LED and leave the prongs as long as possible. Sister the new bulb T-5 Prongs right up to the old ones using the ‘dip and go’ method.
    Tomorrow is solder day. A good plumber always told me to never sweat after sundown.
    Tundra2[QUOTED] and FrenchToasty like this.
  7. Aug 10, 2020 at 5:07 PM
    #6787
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Bad news.
    it hailed golf balls last night and the old girl took a beating...
  8. Aug 10, 2020 at 6:33 PM
    #6788
    You know, solder wick is a thing, and it works really, really damn well. I cannot recommend enough for you to buy some of it and also buy a desoldering pump. Between these two, you'll not have any more sweaty moments.
    Furthermore, and I hope I'm not telling you something you already know, but look up "pre-tinning" on YouTube, and read this comic. I know, it's a comic. But it covers some of the most critical points (other than pre-tinning, which is absolutely critical to learn for both wires and working w/PCBs) which will help you if nobody ever taught you how to properly solder.
    That sucks. I'm so grateful my truck has a roof over its head. My old one wouldn't fit in the garage and I had no choice but to park it under an old oak tree on the street. Between the acorns falling from 40-50ft up and the garbage the oak scale infection would piss out I was washing it every two weeks and would see one or two new dents every week. :(
  9. Aug 10, 2020 at 6:37 PM
    #6789
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I wasn't aware of the solder wick, but my weller solder desoldering pump came in a few days ago. Seems to be quality.
    I've never heard it called "pre-tinning" and always heard it called "tinned." Sounds like the same thing.
    Gave that comic a quick browse before break was over. Looks like good info on there. I'll need to read more in-depth later on.
    Thank you for the education!​
  10. Aug 10, 2020 at 6:46 PM
    #6790
    It's F'ing awesome. Lay it over anything you want to remove solder from, then lay the iron on top of it so the wick is sandwiched in between and POOF 90% or more of the solder is sucked up. Video example.
    Don't get me wrong the plunger is great and everything but not always the most elegant solution.
    Tundra2[QUOTED] likes this.
  11. Aug 10, 2020 at 6:53 PM
    #6791
    Thank you for explaining that, I have one, haha but I don’t think I was using it properly.
    We have this bad ass electronics store; that blows radio shack(when they were good) out of the water. The “bigger city” Phoenix, I have searched and not found a place like this. It’s a mix of Mauser/digikey/random airplane surplus!
    If you know what your looking for it’s great and they usually have oddball stuff for decent prices. Most of the clerks and pretty knowledgeable as well. Huge isle of molex plugs, 2-15 pin, weatherpack connectors, a 60’ wall of switches!!!!!! It’s sooo sick.
    shifty`[QUOTED] and Tundra2 like this.
  12. Aug 10, 2020 at 7:02 PM
    #6792
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Dude that sucks. I dodged the hail today.
    lsaami[QUOTED] and Tundra2 like this.
  13. Aug 10, 2020 at 8:00 PM
    #6793
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm hoping for more white light, and less green, yellow, red, blue, purple obtuse, rubber goose, green moose, guava juice, giant snake, birthday cake, large fries, chocolate shake
  14. Aug 11, 2020 at 4:21 AM
    #6794
    Man, going back to work after 5 days off is rough. I've got a page and a half of threads to read through as well. I see the turd gens have invaded a few threads, so I'm back on watch now. Rest easy knowing the protector of the realms is back from drunken lake time, and is looking over 1st gen land, shooing away the monstrosities known as 2nd/3rd gens.
    Darkness, shifty`, NUDRAT[OP] and 5 others like this.
  15. Aug 11, 2020 at 4:24 AM
    #6795
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    elliot's?
  16. Aug 11, 2020 at 4:45 AM
    #6796
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  17. Aug 11, 2020 at 5:05 AM
    #6797
    The best
    robabeatle[QUOTED] and Tundra2 like this.
  18. Aug 11, 2020 at 5:20 AM
    #6798
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  19. Aug 11, 2020 at 5:28 AM
    #6799
    lsaami
    lsaami Let ‘er buck
    Minnesota
    yup, it’s a bummer. We’ll see if the insurance totals it out or not. Probably not going to fix it since the cab is so rotted out. I’ve put enough money into this thing. I’d buy it back from insurance if it’s totaled though.
  20. Aug 11, 2020 at 5:39 AM
    #6800
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    That sucks. Be prepared to dispute value with your insurance, any recently completed repairs and upgrades as well as local ads for trucks of similar year,make, model and condition. You have to squeeze them for every cent. Do you think you will buy another 1st gen? If you find something here in SE Florida, I live 3 minutes from ft Lauderdale airport and there is a spare room by the pool.
    bmf4069, NUDRAT[OP] and TX-TRD1stGEN like this.
  21. Aug 11, 2020 at 5:52 AM
    #6801
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Did some local investigating while I was out looking for another item: the rare corona-na-na...
    NUDRAT[OP] likes this.
  22. Aug 11, 2020 at 5:55 AM
    #6802
    It does exist!
  23. Aug 11, 2020 at 5:58 AM
    #6803
    You have "full" coverage? That's good. Be ready to haggle.
    This is a good reminder for this,
    https://www.tundras.com/threads/psa-insurance-with-truck-modifications.50856/
  24. Aug 11, 2020 at 6:26 AM
    #6804
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Looking at buying a Rav 4 for my teenage daughter.
    I know some people on here have em.
    Are there any years/motors I should avoid?
    Anyone looking to sell one?
  25. Aug 11, 2020 at 6:38 AM
    #6805
    I don’t know what gen, but my mom had a 2010 I think. And it’s been a great car for her. I think it has the 2.7 4cyl. I’ve driven it on road trips and it’s great, it’s not a go gart like a little civic is, but a larger koopa troopa kart, it zips around pretty good and has a decent amount of room! I think my mom is over 150k with no real issues other than regular Maintenance.
  26. Aug 11, 2020 at 6:40 AM
    #6806
    Empty Lord might know if they are known to have any issues. Our 2012 has been a very good vehicle. The rear main seal leaked at one point but stopped over a year ago now. If you get a 3rd gen(2007-2013) they offered those in the V6 which is supposedly really impressive in such a small vehicle. Honestly though, the 4cyl has been fine for our needs. We've gotten as high as 29mpg on road trips and usually average 24 city. Ours has the transmission dip stick which I like, but it's only a 4 speed auto. I think they have a sealed transmission starting with the 4th gen.
    In 125K miles I've done 1 brake job, and 1 radiator hose. Other than that all I've done is change the oil and transmission fluid.
    Not looking to sell. :cool:
  27. Aug 11, 2020 at 6:46 AM
    #6807
    empty_lord
    05 rollover special
    2.4l burns oil. The 2.5s can burn oil. The V6 was by far the most reliable rav4.
  28. Aug 11, 2020 at 7:00 AM
    #6808
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    I LOVE the V6 in the 2007-2012ish model years. I had one as a rental car for a week. Talk about a "sleeper." While Fast is a relative term, when you jump in a small SUV you have certain expectations. This V6 exceeded mine, Very quick, fun to drive. Rated for something like 270 HP...
  29. Aug 11, 2020 at 7:59 AM
    #6809
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Per @Festerw's, and @bmf4069's recco.
    I'd been shopping around online for a SLA battery. Was browsing today while out on small shopping extravaganza. Saw a relatively small SLA in the clearance bin. $10 later...
    Coming together! Diodes on order, and other goodies should be here eventually.
    Other goodies include the supa sweet-ness Toy OEM "filther" from the local wacko-mart.
    Turkey baster for slow draw power steering change. I don't think I have appropriate help here for the full drain/fill that was reccomended awhile back.
    bmf4069, shifty` and Festerw like this.
  30. Aug 11, 2020 at 8:03 AM
    #6810
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looking back at my broad brand filter post...
    Is the filter "element" a paper filter for the turd-gens? Or the rexus?
