Oil pan drain slighty formed ?
Discussion in '1st Gen Tundras (2000-2006)' started by SRM18TRD, Aug 9, 2020.
  1. Aug 9, 2020 at 6:28 PM
    SRM18TRD
    SRM18TRD [OP] New Member
    18 TundraTRDOR
    Stock
    Thoughts on this...I picked up this 05 dbl cab with 125k a few months ago. I noticed the oil pan is slightly deformed from p/o over torquing. Are these spot welds holding the plate inside the pan robust enough that this shouldn’t be an issue? Will never see force like that again. Thanks
  2. Aug 9, 2020 at 6:31 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The threads will rip out well before the welds on the plate fail. I wouldnt worry too much
    MrAristo, SRM18TRD[OP] and N84434 like this.
