Better Braking Brakes! Easy!!!
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Oct 18, 2018.
  1. Aug 2, 2020 at 12:08 PM
    #91
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I recently commented about how my braking off road is subpar. Someone mentioned to adjust the rear brakes, which involves jacking up the rear and fiddling around the drum brakes...
    Would making the adjustment in this thread make that job unnecessary or redundant?
  2. Aug 2, 2020 at 12:22 PM
    #92
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Fred
    Hand Protectors
    Since this threads genesis, I’ve re-built my entire braking system. I lowered the nuts to experiment with the new brakes, but ended up raising them back up to previous raised location with better performance.
  3. Aug 2, 2020 at 12:31 PM
    #93
    Fred
    Hand Protectors
    You can try raising the nuts a bit. Doesn’t require any jacking up. Another thing to do is make sure your parking brake is adjusted properly which is key in the self adjusting mechanism of the ‘Star Adjuster’. You can self adjust the ‘Star Adjuster’ through the little window on the drum backside.
    robabeatle[QUOTED] likes this.
  4. Aug 2, 2020 at 12:41 PM
    #94
    Fred
    Hand Protectors
    New Brakes went from WE13 to New WL13 Calipers with new pads. Rear drums were rebuilt using Toyota parts in the cylinders with new Toyota Shoes. Kept the original OEM Drums.
    Dannydirtyfingers and tvpierce like this.
  5. Jul 25, 2023 at 1:45 AM
    #95
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    Will the mounting bolts from the WE13 work on the 13WL calipers?
  6. Jul 25, 2023 at 2:33 AM
    #96
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Hey do y'all only have one clip on your front brakes? Cuz I have a clip on both of the slide pins. Zies one.
  7. Jul 25, 2023 at 3:22 AM
    #97
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'm running double springs. Just because...my ps pads came with new hardware & i had em.
  8. Jul 25, 2023 at 3:24 AM
    #98
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i'm pretty sure they use the same bracket, and you have to trim the dust shield a bit.
  9. Jul 25, 2023 at 5:48 AM
    #99
    FirstGenVol Brake Czar
    2002 AC
    I believe so. I don't recall having to buy new bolts.
