Power Folding Mirrors- Boost Auto Parts
Discussion in '2.5 Gen Tundras (2014-2021)' started by Toshito, Jul 31, 2020.
  1. Jul 31, 2020 at 1:02 PM
    Toshito
    Toshito [OP] New Member
    2017 Red Tundra Limited
    Has Anyone in this Forum installed the Boost Auto Parts power folding Mirrors on their truck that didn't come with it?
    If so I know you had to add the switch to fold but anyone used the original switch from toyota? I'm wanting to add this mod but I want to use the original switch. If anyone has done this please share how it was wired to use the original switch. Thanks for the help.
  2. Jul 31, 2020 at 1:08 PM
    RobertD
    Robert
    DFW, Texas
    They are next on my list of mods! I'm a little confused by your question. Are you saying your tundra doesn't currently have powerfold as an option, you plan to add the powerfold harness from Boost, but you want to wire it into the Toyota OEM mirror switch that has the powerfold button on it? Ie no losing a blank to use the switch provided by Boost?
    I've been curious about this and was going to ask Boost. They obviously have an option for if you have powerfold as an option so I doubt it would be difficult to wire their harness to the Toyota switch.
    I'll definitely keep an eye on this to see what you find out.
  3. Jul 31, 2020 at 1:46 PM
    Toshito
    I do not have power fold mirrors or the switch. I would have to buy the switch online. The other issue I have is that I don't have a blank. I would have to cut somewhere to add the switch they send and that is what I don't want to do. The new switch comes with wires see link: Power Auto Rear Mirror Folding Switch with Wire Harness 84872-52040 for Toyota Vios Rav4 Camry Scion Lexus https://www.amazon.com/dp/B07Q572QBK/ref=cm_sw_r_em_apa_i_UkijFbG0NS9AR
  4. Jul 31, 2020 at 1:54 PM
    RobertD
    Robert
    DFW, Texas
    Ah, I'm planning to use the blank to the left of my tow/haul button but it would be nice to just update the existing mirror button. Maybe ask Boost? I've reach out before and they were pretty quick to respond. I bet they will tell that that after you purchase mirrors they will send a wire diagram to tie into the new button. I think you will still have to buy their harness but someone here might have a way around that.
  5. Jul 31, 2020 at 1:56 PM
    jamestada
    jamestada New Member
    James
    2020 Tundra TRD Sport 4x4 Magnetic Grey
    Fox 2.0 Front/Rear 18" Fuel Beast wrapped in Nitto Terra Grappler G2
    I bought this one: https://www.amazon.com/gp/product/B01KU4KXDO/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
    Just finished the install following the wiring from: https://www.tundratalk.net/threads/2014-sr5-platinum-power-fold-mirror-install.439441/
    cavalry bear likes this.
  6. Jul 31, 2020 at 6:29 PM
    Toshito
    I've seen this but this is installing the OEM mirrors that fold. Which mirrors did you installed? I'm wanting to install the boost auto parts Mirrors. Thanks for the help.
  7. Aug 1, 2020 at 8:24 AM
    jamestada
    James
    The boost part is designed to be plug and play feature to feature on your truck. So if you have the feature already it will work without modification. For features you don't have you have to write up to the harness like the post I shared shows.
    Depending on if the mirrors you want also have reverse lights, there would be an extra harness that needs to be connected to a harness on the passenger side kick panel. This feature doesn't exist with OEM i don't think.
    RobertD likes this.
  8. Aug 1, 2020 at 8:28 AM
    RobertD
    Robert
    DFW, Texas
    @jamestada thanks for the info! Based on everything thing I've read and from the videos, no Tundra's have the reverse light so you will have to wire that up if you want it.
    I did really like how detailed the Boost videos were. Makes the task of installing these mirrors less daunting
  9. Aug 1, 2020 at 8:35 AM
    Toshito
    Yes that is correct. The spot light to wire is the least of my worries, that is easy to wire. I'm just asking if anyone has installed the boost mirrors with the oem switch and originally you didn't have folding mirrors but using the wire harness they send you with the aftermarket switch that is like the OEM switch.
  10. Sep 22, 2020 at 7:30 PM
    RobertD
    Robert
    DFW, Texas
    Curious if you bought the Boost mirrors and if you found a way to wire them to the OEM style switch.
  11. Sep 22, 2020 at 7:38 PM
    jamestada
    James
    I ended up finding used Platinum mirrors on Craigslist for cheap. But either way, the truck side wiring will be the same. Mirror side wiring will depend on the mirror, but most use the same as OEM wiring - like the Boost or A1 mirrors... with the exception of the spotlights.
  12. Sep 22, 2020 at 7:43 PM
    Toshito
    Yes I did. By the way I recieved them today. I ordered with all the features available to my truck. I was able to add the original switch and made it work. Just finished installing like an hour ago. Works Beautifull and looks like original. I love it.
    RobertD[QUOTED] likes this.
  13. Sep 22, 2020 at 8:25 PM
    RobertD
    Robert
    DFW, Texas
    Awesome. I'll definitely get one of these switches when I order my mirrors. Thanks for the response!
  14. Sep 27, 2020 at 11:17 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    Just to clarify, when you ordered did you tell them you DID have folding mirrors or that you didn’t? I ordered and told them I didn’t have them, but would like to buy a switch to integrate as I won’t have a blank either.
    which switch assembly did you buy to replace oem?
  15. Sep 28, 2020 at 3:53 AM
    Toshito
    I told them I didn't have folding mirrors.
    I had to run the wires they sent me to make the folding mirrors work. The difference is I did not use the switch they sent me. I used this one:
    https://www.amazon.com/dp/B07Q572QBK/ref=cm_sw_r_cp_apa_fab_f.BCFbZGRAC8S
    RobertD likes this.
  16. Sep 28, 2020 at 8:34 AM
    runCMD
    runCMD BAMF Nerd
    thank you! just ordered it and it will arrive the day after my mirrors :)
    Beesta and RobertD like this.
  17. Oct 2, 2020 at 9:56 PM
    runCMD
    runCMD BAMF Nerd
    Well thanks to @Toshito texting and talking to me and sending me pictures and videos, I got it in with the oem style folding switch. Can’t thank him enough he’s such a nice guy. And the spotlights behind me are super bright. I opted to wire them up to the cargo light so I can turn them on whenever I want like when hooking the trailer up at night. Would never turn them on while driving, that’d be illegal....
    pic isn’t great because it’s night time :).
    Toshito[OP] likes this.
  18. Oct 3, 2020 at 1:32 AM
    RobertD
    Robert
    DFW, Texas
    runCMD likes this.
  19. Oct 3, 2020 at 7:47 PM
    Toshito
    RobertD likes this.
  20. Feb 2, 2021 at 9:17 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’ve been eyeballing either getting tow mirrors with power fold or trying to find platinum mirrors. I miss my old tow mirrors for visibility, so these have my interest piqued - plus they are available NOT CHROME (leaning toward the paintable covers).
    I want to run factory power fold switch but want to terminate everything as though it was factory as well (I’ve got the crimper and pins to do it). Obviously the reverse lights wouldn’t be able to because they aren’t a factory option, but that’s fine.
    You guys have had these Boost mirrors for a few months now - are you still liking them? They holding up well? Any shake? Electrical issues? Which level of reverse lights did you get? Switchback signals or not?
    thanks...
  21. Feb 2, 2021 at 9:24 PM
    runCMD
    runCMD BAMF Nerd
    LOVE them, minimal shake but nothing that bothers me. No electrical issues. I got the switchback signals. But probably would match to whatever your headlights are. I got the high beams and put them on an on demand switch, I use them for setting up camp with the RV, they are super bright. Much prefer them to the OEMs I have seen.
    RobertD and RainMan_PNW[QUOTED] like this.
  22. Feb 2, 2021 at 9:27 PM
    RobertD
    Robert
    DFW, Texas
    @RainMan_PNW I don't have the mirrors yet but I've had some coworkers have them on other vehicles (ford and GMC I believe) and they praised the quality. For the reverse light they said, if you just want the area next to the truck slightly illuminated go with the lower option. If you want illumination and to have it help with backup camera or to see my trailer, get the high output. As long as rear windows are tinted, they shouldn't blind passengers back there :rofl:
    Again I'm going off what I heard, but I'm planning to buy these once I am able. Look forward to hearing members input too
    RainMan_PNW likes this.
  23. Feb 3, 2021 at 4:20 PM
    Toshito
    are you still liking them? Love the new mirrors.
    They holding up well? No complaints.
    Any shake? Just a bit but nothing that bothers me, besides you don't drive looking at the mirrors all the time.
    Electrical issues? No issues yet.
    Which level of reverse lights did you get? High output.
    Switchback signals or not? Yes I got switchback.
    About this: I want to run factory power fold switch but want to terminate everything as though it was factory as well (I’ve got the crimper and pins to do it).
    Very easy to run the switch. Just buy this and easy to install.
    $18 Power Auto Rear Mirror Folding Switch with Wire Harness 84872-52040 for Toyota Vios Rav4 Camry Scion Lexus
    You just have to unpin 2 wires and repin and you all set. That is what I did and it worked beautiful. Hit me up when you ready and I can Help.
    RainMan_PNW and RobertD[QUOTED] like this.
  24. Feb 3, 2021 at 4:22 PM
    RobertD
    Robert
    DFW, Texas
    Sweet! My plan was to pin it up to that switch. Glad to know they are working well for you!
    Toshito[QUOTED][OP] likes this.
  25. Feb 3, 2021 at 8:02 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Thanks. I’m kicking around the idea of doing the KTJO illuminated switch for it, but not sure I want to add that to the price tag of this mod. Also not sure they even have one in blue in stock any more.
  26. Sep 19, 2021 at 11:21 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
    @Toshito, Thank your for your help wiring my factory switch to the Boost Auto power fold mirrors. Worked out great. My Tundra is a second gen so the OEM plug and harness is a little different. Mine came wired for power fold mirrors but the switch didn't have the corresponding pins. In the pic below, the two wires on the right hand side of the plug (purple and tan right next to each other) run the OEM power fold.
    In the pic below, the power fold optioned switch is the one on the left and the lame switch is on the right. You can see the lame one is missing the power fold pins even the the harness plug has them. I suppose I could have chased those two wires down and plugged them into the mirrors at the door, but it was far easier to splice at the switch.
    The Boost Auto switch plug has black, red, blue and yellow wires. The blue and yellow wires are the fold controlling wires.
    All you need to do is spice the blue into the purple of the OEM plug and the yellow into the tan and you are set. I just left the red and black wires of the Boost Auto unconnected.
    ....and after 20 mins of horsing around, I have a functioning OEM style power fold switch.
  27. May 2, 2022 at 8:58 PM
    Stac104
    Stac104 New Member
    2012 Grey Tundra RW
    Azimuth, how did you get power to the mirrors for the power fold to work when splicing into the button/control you added? My 2012 is the same setup and factory wiring. I am attempting to run two female molex connectors from each mirror harness for the fold and retract ports. I also ordered the new mirror control button but am struggling with how to connect those wires (two from each mirror harness) to the factory harness for the fold and retract. I tried to T tap them together by splicing each corresponding + and - from each mirror to the tan and purple wires, but it keeps blowing a 7.5 A fuse under the dash.
  28. May 2, 2022 at 9:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You're pushing two power sources to the same accessory (mirrors). Ideally you want the power going to the switch to power your mirrors but you've still got power from the Boost harness as well. Disconnect the Boost power and try it.
  29. Jul 21, 2024 at 12:07 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Installing my Boost Auto mirrors with power fold upgrade. It appears that the plug for the power fold harness does not exist on the mirrors they sent me. I do not have this plug circled in red:
    Here is a pic of the PS mirror they sent me with the entire harness spread out. The red arrow is pointing to the ends of the power fold switch harness. These are supposed to plug in at the mirror. Am I missing something here?
  30. Jul 21, 2024 at 12:17 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What is all this?
    Seems like that's where your harness would terminate vs that weird box. I didn't have that with my mirrors.
