Looking for tow mirrors!!!
Discussion in '1st Gen Tundras (2000-2006)' started by itscoreyc, Jul 12, 2020.
  1. Jul 28, 2020 at 3:28 PM
    #61
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Never mind. Figured it out. One door done
    Tundra2 likes this.
  2. Jul 28, 2020 at 3:45 PM
    #62
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looking forward to your updates!
  3. Jul 28, 2020 at 4:44 PM
    #63
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    I’m not sure about the Taco but I should have the info on the Tundra. Give me a bit and I’ll check my FSM.
  4. Jul 28, 2020 at 4:47 PM
    #64
    04TundraTRD
    Neil
    Lmao. My page updated after I wrote my last message. I’ll be looking forward to some pictures. Also, could you take measurements along all three sides of the base for reference. I’m curious to see how they compare to the ‘04 AC.
  5. Jul 28, 2020 at 6:00 PM
    #65
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Ah yes. I spaced about that. Will do. You mean the outside of the whole triangle or the little one that makes up the 3 studs?
  6. Jul 28, 2020 at 7:56 PM
    #66
    04TundraTRD
    Neil
    Both if possible but don’t pull them off if they’re already installed.
  7. Jul 28, 2020 at 9:36 PM
    #67
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Here are the new mirror base measurements.
    Beefnbread likes this.
  8. Jul 28, 2020 at 9:39 PM
    #68
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    So. Mirrors are wired correctly and as good as they are gonna get form wise. Still need to road test them tomorrow. Bummed I can’t get the top to suck in more but it appears they bow out a bit which kinda sucks so I may have to revisit these later. Wish the blind spot mirrors were able to move independently but these mirrors offer so much more of a view over the stock ones
    biebs96, Beefnbread, bmf4069 and 2 others like this.
  9. Jul 29, 2020 at 5:38 AM
    #69
    Honestly until you posted the zoomed in shot I didn't notice that part sticking out. You could always try to use a heat gun to form them back down, or maybe try to Fuze them.
    04TundraTRD and CodyP like this.
  10. Jul 29, 2020 at 9:31 AM
    #70
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Heat gun. Good idea. I’ll try that after I clamp them and use some fuze. Only worried about water getting in there and going into my door would be the main issue. Haven’t taken a test drive yet but hoping they don’t make any noise with wind at speed.
  11. Jul 29, 2020 at 12:47 PM
    #71
    04TundraTRD
    Neil
    I was thinking the same thing.
  12. Jun 6, 2021 at 8:30 AM
    #72
    Tundyfan
    Tundyfan New Member
    Doug
    2006 DC Salsa Red
    This is amazing. I'm really shocked that there has been zero third parties out there that have manufactured something for our trucks. I am hopeful with so many new people "discovering" the first gen Tundra, someone would make a tow mirror kit that works with all the electronics. Hell I'd pay $500 for a perfect fit kit.
    WestCoast Fl likes this.
  13. Jun 6, 2021 at 8:34 AM
    #73
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I have a friend that works with cnc machines and solidworks so I’m wondering if I could get him to make an adapter from 2nd gen tow mirrors to our 1st gen base plate.
    onesojourner and Tundyfan like this.
  14. Jun 9, 2021 at 8:02 AM
    #74
    TurdFerguson
    TurdFerguson New Member
    Waynesboro, Virginia
    2000 TUNDRA SR5 AC 4x4 V8
    2002 TUNDRA SR5 AC 4X4 V8 TRD
    What year was the Dodge donor truck? Those mirrors look great.
  15. Jun 9, 2021 at 8:10 AM
    #75
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    05-15 Tacoma aftermarket. I’m actually taking them off since they move quite a bit when folded in and move A LOT when extended and it’s making me sick. I have one limited heated pass mirror that I’ll raptor line white the chrome cover and then try and find a drivers side one as well. I’ll have to revisit these mirrors later. Unfortunately I trashed my oem mirrors so they are gone
  16. Jun 9, 2021 at 8:14 AM
    #76
    TurdFerguson
    Oh, I thought they were Dodge mirrors for some reason. Sorry they aren't working for you, it looked like quite a bit of work. They look badass tho.
    CodyP[QUOTED] likes this.
  17. Jun 9, 2021 at 8:52 AM
    #77
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Technically they are Dodge Ram style mirrors but these were aftermarket as I wanted a cheap route first. I do like how they look as well as the almost 200% improved more mirrored area
  18. Jun 9, 2021 at 10:46 AM
    #78
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    The ones that fit our trucks well are the 98-02 I believe, that's what's on my 01. Only need to drill 1 hole and they go on.
    CodyP likes this.
  19. Aug 31, 2021 at 10:04 AM
    #79
    daveeasa
    So the conventional wisdom so far is that the dodge mirrors (aftermarket ok?) may fit better on FGT than 2nd Gen Tacoma trail tow mirrors? In terms of lowering LOE to install?
  20. Aug 31, 2021 at 3:44 PM
    #80
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    I would say yes, but I've never dealt with the tacoma ones. The dodge ones were extremely easy to do, took under an hour.
    daveeasa likes this.
  21. Aug 31, 2021 at 4:01 PM
    #81
    daveeasa
    Thank you for all this info. I'm gonna bit the bullet and try. Just have to finish picking the exact ones to buy now, then it's time to :sawzall:
  22. Aug 31, 2021 at 6:25 PM
    #82
    Channeling @bmf4069
    Pics. Lots of pics. We like picsssssss.....
    bmf4069 likes this.
  23. Aug 31, 2021 at 7:17 PM
    #83
    daveeasa
    It will be a while. My FGT is at Speed Freak’s waiting in line for his special touch. Hasn’t moved in weeks. After my visit today to drop off a group 31 battery (which may be a tough fit) we realized the radiator should get swapped since he will pull it to do water pump and alternator. So the parts hunt continues.
    But yeah, I plan to follow this dodge mirror idea and see if maybe Cody just got unlucky assuming 2nd Gen Tacoma mirrors would fit well. I would have picked them over dodge myself without the advice here.
  24. Aug 31, 2021 at 8:20 PM
    #84
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I think the main issue is that the base is just too big. You could take a dremel and cut it down but I really don't think I could get it to fit as well as OEM and I didn't wanna deal with leaks so I gave up. Hopefully you have better luck. The other issue I had was the studs in the mirror were too short to work so I had to replace them with threaded rods and cut to size.
  25. Sep 1, 2021 at 5:06 AM
    #85
    Like, a lot.
    CodyP and shifty`[QUOTED] like this.
  26. Mar 6, 2022 at 7:13 AM
    #86
    WestCoast Fl
    WestCoast Fl New Member
    Mick
    2006 Tundra Double Cab
    Bilstien adjustable shocks XD series 17" wheels
    Any chance you have the part number to the ones you ordered
    04TundraTRD[QUOTED] likes this.
  27. Mar 7, 2022 at 10:17 AM
    #87
    04TundraTRD
    Neil
  28. Apr 2, 2022 at 7:42 PM
    #88
    TUNDRA_BOMB
    TUNDRA_BOMB New Member
    Juan
    2002 white tundra sr5
  29. Apr 3, 2022 at 7:27 AM
    #89
    04TundraTRD
    Neil
  30. Apr 3, 2022 at 7:29 AM
    #90
    04TundraTRD
    Neil
    Looks like maybe the base is different.
