Long-travel kits list
Discussion in 'Long Travel Suspension' started by Spvrtan, Mar 5, 2018.
  1. Jul 28, 2020 at 11:17 AM
    #211
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Why didn't you tell me this before?!?!?!? lol
  2. Jul 28, 2020 at 11:19 AM
    #212
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Desired intent may be for effects of sway bar on-road long travel.
  3. Jul 28, 2020 at 11:20 AM
    #213
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    If someone wanted it to handle well on the road, then why spend a bunch of money on a long travel kit???
    831Tun and joonbug like this.
  4. Jul 28, 2020 at 11:23 AM
    #214
    chugs
    chugs New Member
    Ciao
    Central Cali
  5. Jul 28, 2020 at 11:33 AM
    #215
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Alex says this 3 times a month. Pay attention!!!
    831Tun, osidepunker and Sunnier like this.
  6. Jul 28, 2020 at 4:01 PM
    #216
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    The ground clearance has proven to be a non-issue. No one I’ve wheeled with who runs Camburgs kit has had an issue going anywhere everyone else went.
    Hahaha @joonbug True, Alex also points out the uni-balls on Camburg kits aren’t stainless.
  7. Jul 28, 2020 at 4:05 PM
    #217
    osidepunker
    Alex
    2013 Tundra DC 4x4
    MT trucks aren't an issue either. It's not about if you can or can't. It's about how easy you want to make it on yourself
    joonbug likes this.
  8. Jul 28, 2020 at 4:10 PM
    #218
    Vizsla
    Vizsla pretend2send
    I have the TC kit with 3.0 3 tube 12” bypass shocks. Have to modify the kit for the 3.0 shocks. Works really well, motion ratio is almost perfect, but not enough travel to match LT front. Going to push the shock mounts through the bed and run 14” shocks.5384A3D6-BAE5-47E4-81A0-A3F1BB4F52ED.jpg
    JDimaggio4x2, 831Tun, jc153 and 3 others like this.
  9. Jul 28, 2020 at 4:43 PM
    #219
    GravityGear
    Aurora, CO
    No canti?
    831Tun likes this.
  10. Jul 28, 2020 at 6:04 PM
    #220
    chugs
    chugs New Member
    Ciao
    Central Cali
    Do you have it bumped to prevent it from bottoming out when approaching full compression?
    831Tun likes this.
  11. Jul 29, 2020 at 6:54 AM
    #221
    jc153
    San Diego
    True, you could also run smaller tires and probably be fine but...
    My only point was Camburg’s kit is proven and works. Anyone who runs it has a good setup.
    If when doing my LT research I was able to get Camburg’s kit for a “hookup” price it would have been an easy decision.
    WSDMetal, 831Tun and joonbug like this.
  12. Jul 29, 2020 at 11:59 AM
    #222
    osidepunker
    Alex
    2013 Tundra DC 4x4
    He asked for opinions on the camburg kit. I gave him my opinion; the ground clearance sucks
    Much better options out there in my opinion
  13. Jul 29, 2020 at 12:02 PM
    #223
    GravityGear
    Aurora, CO
    Wouldn't this be the case for any fabricated box style lower or is the Camburg extra fat?
    WSDMetal and 831Tun like this.
  14. Jul 29, 2020 at 12:11 PM
    #224
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Camburg is extra fat and hangs extra low due to the oversized uniball they use (which also gets rusted because it's not ss steel)
    TC boxed, Mazzula boxed, LSK boxed, Dirt King boxed, all of those have better ground clearance. And TC tubed has the best ground clearance of all the kits
  15. Jul 29, 2020 at 1:07 PM
    #225
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    How much travel you getting out of the kit?
  16. Jul 29, 2020 at 3:54 PM
    #226
    jc153
    San Diego
    Yes we both gave opinions. I didn’t say Camburg was the best option, just that it was a quality kit and I would have run it for the right price.
    I don’t think we’re disagreeing here are we?
  17. Jul 29, 2020 at 4:10 PM
    #227
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I disagree with you that its a "quality kit"
    The uniballs are oversized. They cause the pivot point to be a lot lower than other kits which makes the ground clearance terrible.
    The uniballs are made from a subpar material, they will rust quickly.
    The boxed design is much bigger than it needs to be; making them very thick and further reducing the ground clearance.
    I wouldn't put that kit on my truck if I found it for $1
    chugs, 831Tun and joonbug like this.
  18. Jul 29, 2020 at 5:57 PM
    #228
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :rofl: Sounds like we're gonna need a fire and a bottle of bourbon to hash this out.
    GodlessPro, KevinK, joonbug and 3 others like this.
  19. Jul 29, 2020 at 6:30 PM
    #229
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
  20. Jul 29, 2020 at 7:21 PM
    #230
    Sunnier
    Sunny
    San Diego, CA
    Haha! Guys looking in here, wondering about a deal on Camburg, may score a great deal on a used set... Hmmn, Andy? @Challenger1 :boink::bananadead:
  21. Jul 29, 2020 at 8:13 PM
    #231
    jc153
    San Diego
    Well we’re going to have to agree to disagree brother.
    I understand your points but they weren’t deal breakers for me. The adjustable heim UCA’s are what sealed the deal for me with TC when i was LT shopping.
    I do like the Camburg LCA heim attachments at the frame though.
  22. Jul 29, 2020 at 8:15 PM
    #232
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Why?
  23. Jul 30, 2020 at 12:05 AM
    #233
    Challenger1
    Andy
    lol
    Not worried. I’m enjoying my Camburg Long Travel.
    I didn’t have any issues with ground clearance and having a blast running with my setup.
    jc153 and Sunnier[QUOTED] like this.
  24. Jul 30, 2020 at 12:09 AM
    #234
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I got the Camburg kit and while I agree they're bulky as fuck (because Camburg never intended them to be used on rocks), they do have a slope to the face of the arms that help them slide over rocks as long as you don't care about gouging them to hell. I haven't gotten stock on my lowers yet. I dropped almost the full weight of the truck on one arm in this video and they're just fine..
    https://www.instagram.com/p/CBrnMPJgwf-/
    I do wish I had gone with LSK sometimes though. The Camburg kit is just easier to work with for now.
    JDimaggio4x2 and chugs like this.
  25. Jul 30, 2020 at 5:50 AM
    #235
    jc153
    San Diego
    I like how they solid mount just like my TC uca’s. No Unnecessary flex and no potential noise from poly bushings.
  26. Jul 30, 2020 at 6:08 AM
    #236
    Sunnier
    Sunny
    San Diego, CA
    Ooh, that noise tho-!
    chugs and jc153[QUOTED] like this.
  27. Jul 30, 2020 at 11:08 AM
    #237
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Flex is a good thing. Everyone gets wrapped around the axle trying to make everything solid. Just like shackles.
    You need a little flex so you don't snap something on a hard hit
    chugs likes this.
  28. Jul 30, 2020 at 11:10 AM
    #238
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Everyone is snapping CVs on the LSK kit. I know of at least 3 incidents. Including one that happened last weekend
    Sunnier, vq35721 and 831Tun like this.
  29. Jul 30, 2020 at 11:14 AM
    #239
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    True story, I've personally witnessed 2 of the incidents.
  30. Jul 30, 2020 at 11:20 AM
    #240
    GravityGear
    Aurora, CO
    RCVs?
    TG705 likes this.
