What size torx for bed tie down?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ron_Pro, Jul 24, 2020.
  1. Jul 24, 2020 at 7:21 PM
    Ron_Pro
    Ron_Pro [OP] New Member
    California
    2020 Tundra TRD Pro CrewMax
    What size torx will I need for the bed tie down? Thanks in advance!
    jewsNbrews likes this.
  2. Jul 24, 2020 at 7:34 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I believe it's a T30
  3. Jul 24, 2020 at 7:42 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Flat head screwdriver works just as well.
    vise grip if more torque needed
    Gabrielo93 and jewsNbrews like this.
  4. Jul 24, 2020 at 7:47 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Bammer, jewsNbrews, 1lowlife and 5 others like this.
  5. Jul 24, 2020 at 7:51 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    jewsNbrews and Ely010606 like this.
  6. Jul 24, 2020 at 7:53 PM
    mountainpete
    Bammer, jewsNbrews and Ely010606 like this.
  7. Jul 24, 2020 at 8:00 PM
    Ron_Pro
    California
    Thanks!
  8. Jul 24, 2020 at 8:09 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Try both methods and give us your feedback.
  9. Jul 24, 2020 at 8:12 PM
    mountainpete
    jewsNbrews, Ely010606 and TILLY like this.
  10. Jul 24, 2020 at 8:17 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    It might work, but why suggest something when the exact tool this fastener was meant for is easily available?
  11. Jul 24, 2020 at 8:22 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    @Ron_Pro do you have the right tool easily available?
  12. Jul 24, 2020 at 8:56 PM
    Ron_Pro
    California
    So I just realized I had a T30 stashed deep in my tool box. It’s a tad smaller, but I was able to make it work. I didn’t try the screwdriver method since I was able to get it off with the T30. I’m sure the screwdriver method would have worked as well. I was just lucky to find that T30.
    I appreciate everyone’s responses. Thank you.
  13. Jul 24, 2020 at 9:13 PM
    mountainpete
    The best part of this thread: the correct tool is a T40. (T30 is for the taillight bolts).
    jewsNbrews and 1lowlife like this.
  14. Jul 24, 2020 at 9:18 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    When I got my Line x sprayed they took them off and sprayed the area but I had to take them back off to paint them black as they looked bad left white. Looks better now.
  15. Jul 24, 2020 at 9:20 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Yw
  16. Jul 24, 2020 at 9:23 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    @jewsNbrews
  17. Jul 24, 2020 at 9:27 PM
    TILLY
    Massachusetts
    You should probably quit while you're ahead.
  18. Jul 24, 2020 at 9:32 PM
    Ron_Pro
    California
    I agree. T40 would be the correct size, since the T30 was a tad smaller. However, the T30 worked and I was able to get it off just fine. Thanks!
  19. Jul 24, 2020 at 9:37 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    It was a guess hahaha. Couldn't remember. Had to do it with total chaos bed stiffeners. That was a while ago
    chugs[QUOTED] likes this.
  20. Jul 24, 2020 at 9:51 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
  21. Sep 15, 2020 at 2:32 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    Had to do this because I tried using a t30 instead of the t40 and stripped the bolt in the process.
