Zone 5in lift questions
Discussion in 'Suspension' started by Rebel76, May 24, 2016.
  1. May 24, 2016 at 7:34 PM
    Rebel76
    Rebel76 [OP] New Member
    Peyton
    2016 Tundra
    I purchased some fuel throttle rims 20x10 neg 24 With toyo 35 by 12.5 r/t from a local shop. At the time being new to the truck world i did not know these wheels were going to rub my frame. I do not not have a $3600-5000 budget for a 7in lift at the moment.
    This local shop is telling me i can do a zone 5 inch lift with my billisten 5100 shocks they are saying they can raise my billisten 2 inches to make it a total of a 7inch lift. They Are raising the back with bds shackles. This shop is telling me that this will achieve a 7 inch lift saving me $1600..... What are your thoughts. This is the solution the shop suggested to my rubbing problem without spending $3600 on a full 7in bds lift. I am new to the lifted truck world do you think is this a bad idea?
  2. May 24, 2016 at 7:36 PM
    Rebel76
    Peyton
    2016 Tundra
    I am trying to not cut my frame
  3. May 24, 2016 at 8:01 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    Simple buy new wheels 18x9 with a +18mm offset with no lift and 35's with pretty much no rubbing.
    zcarpenter92 and Black Wolf like this.
  4. May 24, 2016 at 8:02 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Also it's a cab mount chop and it's very common mod to fit larger tires without lifting your truck sky high.
    Black Wolf likes this.
  5. May 24, 2016 at 8:05 PM
    Rebel76
    Peyton
    2016 Tundra
    I love the look of the wheels and tires i just need it not to rub.
  6. May 24, 2016 at 8:41 PM
    I've never been a real big fan of super lifted trucks. Looks cool as hell, but the ride can be real severe. Plus you have to be able to get in it. And your dog if you have one. Grandma's too.heh heh....@jlee is right, cab mount chop, maybe a ToyTec Boss setup = 35 incher with no problem. I'm going to 35"s when my current tires wear out. I have the chop plates. Need to get them welded in. Hopefully sooner than later. Check out this site some more. There are a lot a Tundras here with 35"s without massive lifts. Welcome from CO by the way.
    zcarpenter92 and T-Rex266 like this.
  7. May 25, 2016 at 6:00 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    This is simple... Either do it right (BDS lift) or buy new wheels. Don't go piecing lifts together to save a few bucks.
    T-Rex266 and Black Wolf like this.
  8. May 25, 2016 at 6:05 PM
    Totally correct. I have no doubt that you can get a decent "high" lift. Going to cost several grand easy. Don't go cheap for 5"+ lifts. Either bite the bullet or do what most "guys/gals" do here: Modest lift, enough lift to have those elusive 35" ers.
  9. May 25, 2016 at 7:56 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The zone 5" comes with lower shock mount extensions already. Extending the Bilsteins too might not give the best ride. A full length shock would be best.
    You really don't need a 7" lift for 35s. Most likely the cab mount chop will fix the rubbing.
  10. May 26, 2016 at 4:39 PM
    TheBeast
    TheBeast The Beach
    also depends on tires..some 35"s are actually 34"s
  11. May 26, 2016 at 5:37 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Buy once, cry once, just sayin
    toyofan87 and T-Rex266 like this.
  12. Sep 1, 2016 at 12:42 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    What are chop plates and where do you get them?
  13. Sep 1, 2016 at 1:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  14. Sep 1, 2016 at 5:31 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I've got 34.5's (295/70R18) with no chop now. 3.5" lift and +18mm offset wheels. Going to 35/12.50R18 next week, got some new tires on order with Labor Day discount right now. I'll probably have to CMC my truck for the slightly taller/wider tires next week :D
  15. Sep 1, 2016 at 8:09 PM
    Relentless.com. An approved vendor here. $25 shipped.
  16. Jul 24, 2020 at 11:45 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I have a 5” zone lift with 35X12.5X20 (24 offset) bilsteins 5100. Been thinking of going 8” as well. Extend the front only 1.5 not all the way. What would I need for the back spacers? @Rebel76
