What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Jul 16, 2020 at 6:50 AM
    #1951
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    Mastercrafts are cool boats. Nice setup. I've heard good things about towing with the 5100's, like being able to control the load on the rear end better than stock suspension. When I upgrade I'll get 5100's all around and set the fronts on the middle setting. My boat isn't as heavy as your Mastercraft, but there is way more height and windage.
  2. Jul 16, 2020 at 12:47 PM
    #1952
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    20200716_131404.jpg Taking some heirlooms from Kansas City to South Carolina
  3. Jul 16, 2020 at 4:27 PM
    #1953
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    We pulled the same trailer 1200 miles 2 years ago when I had a 2011 Taco. Pulled good and I think the lower profile helped with wind resistance as my mpg was not as bad as I calculated. Then again, math is hard.
  4. Jul 16, 2020 at 4:36 PM
    #1954
    Nice MasterCraft! There's a few of us MasterCraft owners on here.
  5. Jul 16, 2020 at 4:42 PM
    #1955
    DaleDanTony
    DaleDanTony New Member
    14 SR5 CM
    lil' RV action! 2010 keystone hideout 25'
  6. Jul 19, 2020 at 1:49 PM
    #1956
    npeters7
    npeters7 New Member
    2020 Army Green TRD Pro
    Camping again this weekend. Ol’ General pulled it great again
    Mine is same thing as the blue Minnie above just in GA Bulldog Red. GO DAWGS!
  7. Jul 19, 2020 at 3:22 PM
    #1957
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Beautiful winnebago ! Love that gel skin ! .
    Bet you could really use a trans cooler on that 2020 hauling that big of a trailer ... May I direct you to this thread https://www.tundras.com/threads/2019-transmission-cooler.60550/
    GODZILLA likes this.
  8. Jul 19, 2020 at 3:23 PM
    #1958
    18" TRD Off Road Wheels
    Cpl_Punishment likes this.
  9. Jul 19, 2020 at 4:05 PM
    #1959
    npeters7
    npeters7 New Member
    Bought an ultra gauge to check trans temps but haven’t gotten it setup correctly yet.. anyone else use UltraGauge that’s has any tricks for trans temps to show
    looked at the trans cooler awhile back. If I get this UltraGauge to work and I see my temps rising high I will def be looking into them.
    jordoncloutier likes this.
  10. Jul 19, 2020 at 4:32 PM
    #1960
    jordoncloutier
    Jordon
    Alberta , Canada
    Definitely worth getting that ultra gauge hooked up , before I added a cooler on my 2019 I'd see 245 degree trans temps towing my trailer (smaller than yours ) and I'm in Canada where ambient temps aren't that crazy hot
  11. Jul 19, 2020 at 8:58 PM
    #1961
    Rabidllamas
    Phil
    WA
    http://ultra-gauge.com/ultragauge/support/UG-MX1.4-Supplement.pdf
    Think it is page 3. I have a 2019 and if I remember correctly I had to enter the pre 2016 Tundra codes to get my ultraguage Mx to read trans temps.
    WAtundra4x4 likes this.
  12. Jul 20, 2020 at 12:51 PM
    #1962
    Shetto24
    Shetto24 New Member
    First tow on the new setup. Great day on the water with Fams was had!
  13. Jul 20, 2020 at 1:33 PM
    #1963
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    2020 Silver Tundra Crewmax Limited 4x4
    How is it everyone’s transmissions are needing cooler? I live in Phoenix, AZ and I tow occasionally I’ve never had issues with vehicle temps getting out of control.
    Sp33dNut likes this.
  14. Jul 20, 2020 at 4:18 PM
    #1964
    npeters7
    npeters7 New Member
    Awesome. Got it working. Now for the 2 different temps. Do you have to create 2 different M gauges to view in the pan vs after torque converter?
    edit: got it figured out. Just now seen they are different in the rpos area. Thanks
  15. Jul 20, 2020 at 4:56 PM
    #1965
    jordoncloutier
    Jordon
    Alberta , Canada
    I'm not talking about engine temperature . Seeing how the tundras don't come with trans temp gauge , have you monitored trans temps with a Bluetooth app ?
  16. Jul 21, 2020 at 8:24 AM
    #1966
    SoFarKingFast
    SoFarKingFast New Member
    2019 Tundra 1794 Edition
    Rented a trailer, dry weight about 5500lbs, so probably 6500lbs total when we loaded it down. Didn't drive far, but definitely up a few large hills with no issues. Truck has stock 1794 (TRD?) suspension.
  17. Jul 21, 2020 at 8:28 AM
    #1967
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    Im pretty sure you have same suspension as me. You have the black shocks correct? If so those are the softest shocks. Put on there for comfort. If it was TRD Offroad shocks we would be blue and yellow, and sport I believe is red shocks.
    how far did you tow and what mpg you get? Also how much was rental?
    Leo's first likes this.
  18. Jul 21, 2020 at 8:38 AM
    #1968
    SoFarKingFast
    I have the blue TRD shocks. Went about 200mi and got 8 mpg (at 75mph). Climbed about 1500' though, so it was a decent hill on the way out.
    Going to rent a 28' trailer next time (about 1000lbs more) and see how it does. This was 24'.
  19. Jul 21, 2020 at 8:47 AM
    #1969
    Oof. 28 feet and 7500 lbs is a lot of travel trailer for a half ton. Different story on a flat trailer. You're braver than I am. I'll be shooting for the 20 footer or less range. :rofl:
  20. Jul 21, 2020 at 8:58 AM
    #1970
    SoFarKingFast
    Ya, not bad advice...just don't want to have to lose the Tundra! Three kids under 4 in a 24' was tough though.
  21. Jul 21, 2020 at 9:01 AM
    #1971
    I only have one "kid" and she has 4 legs and poops outside, so.....
  22. Jul 21, 2020 at 10:20 AM
    #1972
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    Nice! Ya that’s what I’m gonna do. I have a few different people in my area that rent their TT on outdoorsy.com. I’m gonna rent them over the course of a year and see what fits my families needs best before I spend the money to buy.
  23. Jul 21, 2020 at 10:33 AM
    #1973
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My parents in law got an 18 footer for the two of them and my father in law said it's the biggest trailer he'd want to tow. My parents got a 24 footer for our family of 5 and it worked well for us until we were old enough to sleep in the tent. We do leave it parked at our lake lot year round but my dad has lots of experience towing and wouldn't balk at a larger trailer, provided he had a vehicle to tow it with.
    I'd like something around 24 feet and 4500 lbs dry but my wife has a lot of strict specifications that she's unwilling to compromise on, including: has to have a slide, has to have a couch, can't have a Murphy bed, can't feel small or cramped...
    Also, she's not even willing to learn to drive the truck, let alone tow a trailer. So we'll see if that results in me selling the Tundra and getting a one ton.
    BravoDeltaRomeo and Y0TA PR0 like this.
  24. Jul 21, 2020 at 10:38 AM
    #1974
    You just gotta get her to compromise a bit. If she wants a slide, then it needs to be 5 feet shorter. Slides add tons of weight and need extra maintenance. Also extra intrusion point for water and vermin.
    Have you looked into the R-pod line up? Everything they make would be fine on 99% of half tons, and the are solid quality from what I have researched. They are a bit more expensive than some other trailers the same size, but I am ok with that if the quality is there.
  25. Jul 21, 2020 at 10:41 AM
    #1975
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    Hey man my wife is same way!! I found what she is willing to compromise on. It’s the Grand Design Imagine 22RBE. They have different models to accommodate larger families. They are nice I have floor plan below.
  26. Jul 21, 2020 at 10:43 AM
    #1976
    Olson
    Olson New Member
    Eric
    Queen Creek,AZ
    I also looked at RPOD only thing I don’t like is single axle jostles around a lot and stuff inside rattles around and falls. I used my in-laws geopro and it was great but the speakers inside rattled and one fell and was hanging by wires. I just didn’t like that bed is hard to make and if you over indulge in alcohol and go to bed whomever sleeps furthest forward in bed is constantly crawling over other person to go to bathroom. Lol
  27. Jul 21, 2020 at 10:59 AM
    #1977
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'll make sure Rpod is on my list to check out but, like Eric says, tandem axle seems more stable and I was told would also have a lower tongue weight.
    +1 on vermin coming in through the slide, which is especially a concern since I'd like to leave it at the lake over winter.
    Grand Design is also on my list to check out though we're looking for one with bunks.
  28. Jul 21, 2020 at 11:06 AM
    #1978
    Azblue
    The Dirty T ( ^_^)_且
    Doesn't have to be that short. Mine is 23', has 2 slides and is about 4900 dry.
  29. Jul 21, 2020 at 11:13 AM
    #1979
    I know the trucks will haul more than that, and you could even push up larger. Because TT have that high tippy profile that catches wind I always shoot for smaller, but as long as you are within the payload and towing limits then it just boils down to preference. I like to enjoy my drive, and with all my CDL driving I have learned what I do and don't like. Had a TT with a slide, and it wasn't worth the work to me. I also don't plan to spend tons of time in the camper. I wanna be outside enjoying wherever I've gone. As long as the kitchen is sufficient and I have a good place to sleep then I am a happy camper. Punny. :laughing:
  30. Jul 21, 2020 at 11:18 AM
    #1980
    Azblue
    Agreed about not pushing it. I like to keep my max at no more than around 70% of rated capacity. If I cram mine to the max , water, etc. It's at around 7200. Close to 70-75% and about as heavy as I would go without bumping up to a 3/4 ton. I cringe when I see guys posting that they tow 11,000 and the Tundra "Pulls it great"
