  1. Jul 18, 2020 at 1:32 PM
    18" TRD Off Road Wheels
    That is the most Canadian mod to date. :canada: Looks good, too.
    Cosmoblu, Baja Mike and BoxersBrew like this.
  2. Jul 18, 2020 at 1:37 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Nice job with the red accents and that hockey stick shift knob is the cherry on top!
    ep3Jee, BoxersBrew and GODZILLA like this.
  3. Jul 18, 2020 at 2:39 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Yeah I think the CB +1 advertise .625 lift which would be perfect as I have about 1/2” of front lift left in my Toytecs and that would g leave about 1/2” of forward rake. So when towing should be about level.
  4. Jul 18, 2020 at 2:51 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Kind of both. This site has a plethora of DIY write-ups/resources that I have used along with just general experience.
    This project is just a daisy-chain of LED’s hooked up to together. That I will later connect to a switch in the dash... this afternoon. I am just taking my time with it though.
    I have the box all wired-up and now am routing the wiring in the truck...
    You are welcome to PM me if you have any questions.
  5. Jul 18, 2020 at 2:58 PM
    Dceclipse
    Dceclipse New Member
    NORCAL
    B70BB30C-DC90-4960-BA87-4529F51D59E8.jpg 8AC9DAAF-796B-4507-A5BC-080AABC9097E.jpg Finished installing an OEM Black housing lights....
    Fotnot, Mountun Goat, Ostrich and 4 others like this.
  6. Jul 18, 2020 at 3:10 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Went a little nuts with my new can of plastidip.
    Pictures of the front of the truck with the new tow hooks don't look so good. I think it's the lighting. I'll try again when the lighting is better.
  7. Jul 18, 2020 at 3:21 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    Installed the Helmholtz resonator on my Dirt Deeds 10” system. I drove without it for a couple of months and the drone wasn’t bad at all but it was there. Completely gone now! I have to admit I was somewhat skeptical but am so happy I installed it now.
    WFD473, 100LL, equin and 3 others like this.
  8. Jul 18, 2020 at 3:43 PM
    BobHuck
    BobHuck New Member
    2020 Tundra SR Doublecab 4x4
    Got the truck about a month ago. I've been busy with work and I was finally able to schedule an appointment to get the running boards installed that I ordered. I went with OEM Stealth boards in black.
    Cosmoblu, Fotnot, WILLINH and 7 others like this.
  9. Jul 18, 2020 at 3:45 PM
    NikNoid
    NikNoid New Member
    I put White Knuckle Rock Sliders on my 2018 DC today. Well mostly. I still have nine holes to drill.
    I'm wiped! What a workout!
    jewsNbrews likes this.
  10. Jul 18, 2020 at 3:45 PM
    Rely01
    Rely01 Window Shopping
    Eli
    SW Arkansas
    2016 Silver Sky SR5 CM
    What size thread is the shifter?
    Lowgybear likes this.
  11. Jul 18, 2020 at 3:55 PM
    Lowgybear
    Lowgybear It takes an iron will
    Ysai
    San Antonio Texas
    2018 TSS OFF ROAD Tundra
    Are those OEM halogen lights? I didn't know they made black housings for those. I thought it was just the new 2019 LEDs that had the black housing option
  12. Jul 18, 2020 at 3:58 PM
    From Roman's Ultimate OEM thread
  13. Jul 18, 2020 at 4:28 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    I feel your pain brother Sandlapper.
    I did the same thing couple of weeks ago but it wasn't a forest service road. I learned a long time ago when the Forest Service closes a road they do it with intent. Up here in the Sumter forest I had to come out a horse trail years ago because there was no turning around.
    Cthulhu[QUOTED] likes this.
  14. Jul 18, 2020 at 4:56 PM
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    8mm x 1.25
    BuckeyeChuck and Rely01[QUOTED] like this.
  15. Jul 18, 2020 at 5:02 PM
    Rely01
    Eli
    SW Arkansas
    Over the course of the last
    Many thanks!
  16. Jul 18, 2020 at 5:06 PM
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    My passenger weather tech came with a grip underneath. Does not slide.
  17. Jul 18, 2020 at 5:19 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Took a pic cause it's been a minute.
  18. Jul 18, 2020 at 5:21 PM
    Rely01
    Eli
    SW Arkansas
    It's been a few weeks in the works, but I finally got around to doing some easy/diy stuff to my truck. When I first got the truck, it had all the badges, stickers, etc, fender flares, and factory running boards. I was never a fan of any of these, and finally pulled the trigger on deleting all of them. I just decided to make time to do it. Also added tie downs in the bed. The two sets that come in there are nowhere near enough and never in the right spot it seems. Big thanks to @harrydunn for the help with that. And finally, deleted some chrome from the tail pipe.
    Before:
    After:
    Also added tie downs to the bed bolts. Just did the one at first to see how I like it. I've went back and done the others since.
    I added the same hooks into the threaded holes in the side of the bed as well. I don't intend on putting too much pull on them until I get a better system set up, but this gets me out of a bind.
    And changed the factory exhaust tip out for a black one. After cutting the tail pipe back (explained in another post), the chrome tip was shining out from the wheel well. This has fixed that wonderfully.
    That was a lot, but thanks for reading:hattip:
  19. Jul 18, 2020 at 5:40 PM
    okie404
    okie404 New Member
    Got me one of these gizmos...
    Fotnot, Y0TA PR0, GAknight and 7 others like this.
  20. Jul 18, 2020 at 5:40 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Just finished washing her. First time since I got the new wheels.
    Fotnot, GAknight, Ostrich and 5 others like this.
  21. Jul 18, 2020 at 5:42 PM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    Washed her up. Really impressed with some of the shine supply and Adams products I’ve picked up recently.[​IMG]
  22. Jul 18, 2020 at 6:34 PM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    Picking these up tomorrow, craig's list buy $340
  23. Jul 18, 2020 at 6:51 PM
    Cthulhu
    LOL yeah next time I see ROAD CLOSED signs even though they’re pushed aside, gonna think twice! :rofl:
    GODZILLA likes this.
  24. Jul 18, 2020 at 9:12 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Touché :hattip:.
    WFD473 and GODZILLA like this.
  25. Jul 18, 2020 at 9:56 PM
    Lugnuts2020
    Lugnuts2020 New Member
    2018 crew max
    Installed diode dynamic fogs. Very impressed. 200 bucks but so much brighter than the Oem LED ones.
  26. Jul 18, 2020 at 10:06 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Got the LineX in!
  27. Jul 19, 2020 at 9:18 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    While doing maintenance on the camper, i added 1 more shim to the WDH. That brought the front down an 1/8" and raised the rear 3/16". The front is now the same height measurement to the fenders with or without the trailer. The rear is down 1" now with the trailer. Had to borrow my dad's 3/4" socket set and my great grandfathers crescent wrench to loosen the hitch bolts
  28. Jul 19, 2020 at 11:17 AM
    kwebre
    kwebre New Member
    2020 Blck Tundra
  29. Jul 19, 2020 at 11:30 AM
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    Finally installed my 6” dumped dirty deeds exhaust...been sitting too long in the garage. Work, school n side business are to blame.
    What a difference, really “pops the cork” on the V8. Good rumble on start up, not raspy and minimal drone.
    Most of all... no “whup whup whup” on freeway.
    Dunno why I didn’t do it sooner, start to finish took about 1 hr by myself.
  30. Jul 19, 2020 at 11:39 AM
    Azbackcountry
    Azbackcountry New Member
    Doug
    Arizona
    19’ DC SR5 4x4
    Does the un-holey mount by chance fit with the AJT vent rings ?
    Thanks !
