Middle vents don’t blow any air
Discussion in '1st Gen Tundras (2000-2006)' started by Hanks06dblcab, Jul 7, 2020.
  1. Jul 7, 2020 at 4:34 PM
    Hanks06dblcab
    Hanks06dblcab [OP] New Member
    Henry
    2006 Tundra SR5 Double Cab
    06 dbl cab. Middle vents blow at maybe 1% compared to side vents. You can barely feel anything coming out. Windshield vents and rear vents all blow fine. Doesn’t matter which setting it’s on. Any thoughts?
  2. Jul 7, 2020 at 6:31 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Can u hear the blend door moving at all? I’d say blend door actuator. Not sure if Tundras are vacuum or cable, but your cable might be messed up.
    Hanks06dblcab[OP] likes this.
  3. Jul 7, 2020 at 7:00 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    In my 02 the vent piping behind the dash is fitted in pieces. Maybe the piping that goes to those vents came undone and air is blowing around in the back of the dash.
    :notsure:
    hammeron and Hanks06dblcab[OP] like this.
  4. Jul 7, 2020 at 7:03 PM
    Hanks06dblcab
    Henry
    Not sure what I’m even listening for, for the blend door actuator. I’ll do some more research. I’ve had the truck for three days.
  5. Jul 7, 2020 at 8:28 PM
    Hanks06dblcab
    Henry
    I did remove the black center piece with vents and tried turning the air on, still nothing. Gotta be disconnected somewhere further down. Or the blend door actuator/vacuum/cable. One step at a time.
    robabeatle likes this.
  6. Jul 7, 2020 at 8:57 PM
    I'm pretty sure all the tundras are vaccum operated. You'll hear kinda like a thunk when changing the vent knob. That's the actuator.
  7. Jul 13, 2020 at 8:51 AM
    Hanks06dblcab
    Henry
    After further inspection, turning the knob doesnt change the vent setting. It always blows from the side vents and dash. Does that point to blend door actuator?
  8. Jul 14, 2020 at 1:55 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  9. Jul 14, 2020 at 4:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Make sure your cables are hooked up and the slides lubed.
  10. Jul 20, 2020 at 6:21 PM
    Hanks06dblcab
    Henry
    I think this is the problem. If everything is connected and lubed, is it the blend door actuator motor itself?
  11. Jul 21, 2020 at 7:58 AM
    Hanks06dblcab
    Henry
    So there is not even a cable hooked up at all. Trying to locate its origin point and assuming it runs directly to the vent control switch. If it isnt there, where can I get the parts for it? Any thoughts?
  12. Jul 25, 2020 at 6:47 PM
    Hanks06dblcab
    Henry
    Update: cable was there but not connected to actuator or to the vent control switch. Hooked the cable back up at both locations and now have air from all vents except defrost. Will not switch over to defrost at all. Thoughts?
  13. Jul 26, 2020 at 6:22 AM
    Maybe it has a separate cable which is also disconnected?
  14. Jul 27, 2020 at 11:07 AM
    Will not switch how? Like, physically won't go there, or goes but doesn't switch?
  15. Jul 27, 2020 at 11:48 AM
    Hanks06dblcab
    Henry
    The knob turns, but doesn’t change the vent selection.
  16. Jul 27, 2020 at 1:48 PM
    Fred
    Hand Protectors
    Maybe the Dial Mojo was off a few degrees when the cable was rehooked. Mojo might need a reset?
  17. Jul 27, 2020 at 3:46 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Could you move to defrost before you reattached the cable for the center vents?
  18. Jul 28, 2020 at 4:03 PM
    Hanks06dblcab
    Henry
    No. It was just always on. Side vents and defrost.
