Early 1st Gen (2000-2003) Tundra Frame Replacement FAQ
Discussion in '1st Gen Tundras (2000-2006)' started by lsaami, Oct 5, 2019.
  1. Jul 13, 2020 at 8:27 PM
    lsaami
    lsaami [OP] Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Possible candidate. I went to Luther Brookdale in Brooklyn Center. They did me right on the frame replacement.
    check Toyota.com/recall to see if the recall is still open, but make sure before you bring it in that it actually has holes in the crossmember.
  2. Jul 14, 2020 at 8:01 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    It is NOT on the Toyota.com/recall site. Does that mean I am outta luck?
  3. Jul 14, 2020 at 11:02 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Snapped some pics of my cross member.
  4. Jul 14, 2020 at 12:57 PM
    lsaami
    Minnesota
    Maybe, unless you can sweet-talk the dealer somehow. Honestly, that looks pretty decent anyways. If they don't do anything for you, strip it down, paint it, keep it fluid-filmed, and enjoy it. it'll be fine.
  5. Jul 14, 2020 at 12:59 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Wire wheel frame, por15 treatment, then rustoleum bedliner?
  6. Jul 14, 2020 at 1:07 PM
    lsaami
    Minnesota
    Don't do the Bedliner. A few rock chips to break the seal and it will trap moisture and make it worse.
    The rest of it is a great idea.
  7. Jul 14, 2020 at 4:29 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    What kind of paint?
  8. Jul 28, 2020 at 2:07 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    Got approved for frame replacement.
  9. Aug 2, 2020 at 11:51 AM
    theleeb
    theleeb New Member
    Tom
    Upper Marlboro, MD
    2002 Red Tundra Access-cab SR5 4x4 4.7L
    Glad I found this thread. My 2004 SR5 - bought it this past December - has rust all along the frame....so far have not seen holes but I want to get it to a dealer to do a thorough inspection.
    I see that 2004 is not a covered year for the rust issue :( I followed the advice here and registered at the Toyota Owner site and saw the service record below.
    I see "Limited Service Campaign" - so 2004 was apparently covered by this? Looks like the owner moved forward with the service. But as I mentioned, there is rust everywhere. Perhaps there LSC is intended to be a one-time service?
  10. Aug 2, 2020 at 12:13 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Correct, the LSC was a one time either frame coating or replacement and has now expired for all 1st gen trucks.
    Removing the rust and painting is what lies in your future.
    lsaami[OP] and theleeb[QUOTED] like this.
  11. Aug 2, 2020 at 2:04 PM
    theleeb
    theleeb New Member
    Tom
    Upper Marlboro, MD
    Yeah and that's a project. There are a couple of independent rust treatment services in this area....one that provides Zeibart products and another that does rust conversion / undercoating / rustproofiing using Noxudol products. Also noted the SafeTCap reference by a poster. We'll see what the inspection report says and figure it out from there.
  12. Sep 1, 2020 at 11:20 PM
    Pipingpro
    Pipingpro New Member
    2001 Toyota Tundra 4x4
    Hey shootemintheface , how did you get yours replaced? Mine had the cross member coating but yesterday my top shock mount rusted off and flew out the back hitting another car. Could have killed someone. My truck looks great except for the fact it is about ready to break in half. Can't sell it, the dealer won't help. and Toyota is useless. I thought I would buy another Tundra but not even an option based on what I have been dealing with. If anyone has some tips and tricks to get them to fix this, I am all ears.
  13. Sep 14, 2020 at 9:10 AM
    shootemintheface
    If you or someone before you took it in for the recall and they sprayed it then that's it. It did not meet the requirement. The info is in the thread. Honestly I'm surprised toyota is still even doing the frame replacements. Gonna cost them 10-15k truck was only around 30k new. And it's almost 2x fair market value. Two other ppl I know had theirs replaced a few months back. Was in the truck the other day. Drove like a new truck.
    lsaami[OP] likes this.
  14. Oct 23, 2020 at 8:26 PM
    jesemd
    jesemd New Member
    So, just confirming I am completely hosed with this in the Toyota service records:
    3/2015
    DRIVEABILITY CONCERN ~|~PLEASE INSPECT FRAME. C/S HAS HOLS IN FRAME ~|~PERFORMED INSPECTION FRAME IS PERFORATED ~|~NO REPAIRS MADE
    customer pay
    3/2015
    MISC REPAIRS ~|~CHECK FRAME RECALL ~|~
    customer pay
    5/2012
    CHECK FOR RECALL ~|~B0D FRAME RUST RECALL ~|~B0D FRAME RUST RECALL FOUND SMALL RUST HOLE ON L/REAR FRAME LESS THAN 10MM DOES NOT APPLY FOR FRAME REPLACEMENT AT THIS TIME ~|~COMPLETED UNDERCOATED FRAME ASSEMBLY
    T00-CORROS RES KIT 00289T00KTDS
    PLUG, HOLE 9095001824
    warranty pay
    5/2010
    CAMPAIGN ~|~PERFORM AOF LSC-AOF RECALL INSPECTED FRAME FOR RUST PERFORATION NONE FOUND ~|~ ~|~COMPLETED
    warranty pay
  15. Oct 24, 2020 at 6:15 AM
    lsaami
    Minnesota
    Fraid so my friend. I’d look at gibbing a fab shop nearby and paying them to install these.
    https://www.autorust.com/safe-t-cap-kits/
    N84434, speedtre and Kongap like this.
  16. Nov 13, 2020 at 2:40 PM
    chubber82
    chubber82 New Member
    2003 Tundra xtra cab
    Has anyone had success getting a frame replaced AFTER 2010 for areas that rusted out (in GREEN) after 2010? I have some serious rust issues now that i think Toyota missed (on purpose) and now they are saying they won't replace the frame. I have a 2003 xtra cab that is otherwise in great shape, only 90K miles.
  17. Nov 13, 2020 at 4:49 PM
    lsaami
    Minnesota
    Do you have any proof? if not, I'm afraid you're out of luck.
  18. Jan 11, 2021 at 3:12 PM
    bob4dogs
    bob4dogs New Member
    bob
    06 4 door tundra trd
    none
    from the information TMC told me 'your vehicle was part of the recall" however the original lease holder did not send back the 'post card' to get his frame exchanged and as the second owner we cannot help you i need a class action anybody out there?
  19. Jan 11, 2021 at 4:02 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Your truck was never recalled for the frame, if the service adviser told you that it was incorrect.
    06 was covered under the LSC which expired at least 3 years ago. Had nothing to do with which owner reported it.
    lsaami[OP] and speedtre like this.
  20. Jan 13, 2021 at 6:55 PM
    #50
    Mantaroc
    Mantaroc New Member
    Randy
    2003 Std Cab Tundra
    non e
    I have a 2003 Tundra where the frame is rusted through so bad the frame holding the front steering stabilizer is broken off. Can I still get this fixed through the recall? The truck has only 87,000 miles.2003 frame rust.jpg See pict.
  21. Jan 14, 2021 at 2:54 AM
    #51
    Festerw
    Festerw New Member
    04 Tundra DC
    Only if the rear cross members are rotted. Check the first post in this thread, the areas in red are what qualify under the recall.
  22. Jan 14, 2021 at 3:54 AM
    #52
    FirstGenVol Brake Czar
    2002 AC
    You can see where someone tried to cover up all that rust with spray paint.
  23. Feb 24, 2021 at 11:55 PM
    #53
    shootemintheface
    On the firewall above that spot is a drain that drips condensation from the heater core? That also contributes to the corrosion. The driver side spot of the stabilizer bar is no where as bad as passenger side usually. i don't know if the Sequoia have the same drain position I highly suggest running some tubing there and have it drip below the frame. I don't know if there ever was such a thing on the original. It would be wise to do so to help the new frame last longer. Chances are your rear cross member is just as bad may let you qualify for a new frame. Take your truck in and let the dealership do the inspection, worst thing they could say is no.
  24. Mar 2, 2021 at 2:47 PM
    #54
    GTT
    GTT New Member
    Does anyone know for certain whether the recall areas (the crossmember or the "red" areas of the SSC bulletin) stay covered for the life of the vehicle? Mine got the coating so is no longer eligible for frame replacement in the "green" areas, but it's beginning to rust heavy in the red areas from the first recall (vs the special service campaign)
  25. Mar 2, 2021 at 6:57 PM
    #55
    lsaami
    Minnesota
    If you got the coating, that is deemed a suitable repair and the recall is closed.
  26. Mar 8, 2021 at 10:21 AM
    #56
    Bad Beagle
    Bad Beagle New Member
    2003 Tundra 4.7 extended cab4x4
    Leveling kit
    Took my 03 into dealership 1-11-21 in MUNCIE IN for airbag recall. Service tech advised of frame inspection,found rust. " by law we cannot let you have your truck untill frame replaced". Shocked me speechless. They going to replace frame to the tune of 12,000. As of now they cannot provide me with a repair date. Really burnt my butt. I am 2 months into my complaint process. Big run around.
    Loosethoughts and speedtre like this.
  27. Mar 8, 2021 at 10:47 AM
    #57
    speedtre
    speedtre New Member
    Inland Northwest
    Did they issue a loaner car to you?
  28. Mar 8, 2021 at 11:55 AM
    #58
    Bad Beagle
    Leveling kit
    Yes, originally they were obligated to loan me or provide me with a car. That was unacceptable so we negotiated to a 2020 Dodge Laramie 4x4 from Enterprise rentals. They pay for it all. That truck is very nice but a big wussy. I truly miss my 03 Tundra 4x4. That truck is a little beast. Almost undestructible I thought.
  29. Mar 8, 2021 at 11:58 AM
    #59
    speedtre
    speedtre New Member
    Inland Northwest
    Well, maybe a PITA, but in the long run a good deal for you. If I was you I would be putting together a parts cache of stuff you want them to put on when they swap the frame. Essentially anything that has to be taken off and put back on should be a free labor charge if you provide the part. Guaranteed you will also get a list of parts that must be replaced at your cost that the rust has ruined when it's disconnected for the frame replacement and the recall won't cover it....be ready for that.
  30. Mar 8, 2021 at 12:03 PM
    #60
    Bad Beagle
    Leveling kit
    The service advisor at dealership mentioned a 150% over book value option. I have not found that information on any of my research. I seriously tried to deal with the dealership. They shoved me off onto the Toyota corporation. when I get around I will show some numbers and websites that they give me. Both 800 numbers are a joke
