U bolt flip kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by so_juanderful, Jul 11, 2020.
  1. Jul 11, 2020 at 6:27 PM
    so_juanderful
    so_juanderful [OP] New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
  2. Jul 11, 2020 at 9:33 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Any purpose to them?
  3. Jul 12, 2020 at 1:55 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Less likely to get hung up on rocks and stuff
    ATV25 and HulkSmurf14 like this.
  4. Jul 12, 2020 at 2:48 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    Makes sense thanks
  5. Jul 12, 2020 at 4:50 AM
    timsp8
    NY
    I’ve seen some trucks on here with u bolts flipped. Don’t remember who it was. I thought it was to lower the truck or something.
  6. Jul 12, 2020 at 4:43 PM
    Ry24000
    Ry24000 New Member
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    I like that! could be useful in off road situations. Who makes it?
  7. Jul 12, 2020 at 4:46 PM
    empty_lord
    05 rollover special
    Archive garage makes it fit first gens. Not sure second or 3rd
  8. Jul 12, 2020 at 5:43 PM
    so_juanderful
    Honolulu, HI
    I provided link under photo
  9. Jul 12, 2020 at 5:44 PM
    so_juanderful
    Honolulu, HI
    ATV25 and empty_lord[QUOTED] like this.
  10. Jul 12, 2020 at 6:39 PM
    rochmpr
    rochmpr New Member
    Krister
    Walnut Grove, CA
    2020 CrewMax
    Lifted, sliders, 35 X 12.5's, Evo Corse and more stuff coming
    U-boat flip kitsch have been around in the old Hilux and Taco builds for rock crawling for over 20 years. They give additional clearance on the trails and less things to get damaged. Although, the price for the kit above is steep based off those old kits. I will probably have some fabbed one day, super easy to design and build
  11. Jul 16, 2020 at 5:40 PM
    jm403
    jm403 New Member
    El Cajon, CA
    14’ 4x4 SR5
    Total Chaos upper arms, spindle gusset, diff drop, shackles, rear bump stop kit, bed stiffiners, deaver leafs (soa), archive u bolt flip, tc spec adjustable king 2.5’s, BajaDesigns squadron fog lights and 40” s8 on Sdhq behind the grill mount, BFGoodrich Ko2 285/75/17 on Method grid wheels
    (2014 tundra) After clipping a rock with the stock U bolt configuration, which caused my axle to shift. I installed one of these kits along with a set of deaver leaf springs (11 leaf pack, SOA) and Total Chaos shackles. I already had the Total Chaos bump stop kit and the archive offroad flip kit top Plate Provides room for my bump stop to land. Archive offroad has great customer service and a quality product, even provided the torque spec for install.
    Skew12 and so_juanderful[OP] like this.
  12. Jul 16, 2020 at 5:45 PM
    jm403
    jm403 New Member
    El Cajon, CA
    14’ 4x4 SR5
  13. Jul 16, 2020 at 6:12 PM
    so_juanderful
    Honolulu, HI
    Awesome, the exact response I was waiting for! I have King 2.5s on the way along with Deaver U748s. Contemplating on getting the Total Chaos bump stop kit along with the King bump stops. Nice setup, and thanks for your input.
    jm403[QUOTED] likes this.
  14. May 27, 2021 at 7:35 PM
    Honz
    Honz New Member
    Black 2020 Pro CM
    Decked system Garmin Mini with Dongar Technologies adapter Nitto Exo Grappler 285/70R18 OEM Power Tailgate Lock OEM Black Door Sill Protector Center Console Organizer
    Just about to install some SumoSprings in the back and it got me thinking. Since I have to take the U bolts off anyways why not flip them at the same time? Has anyone here done a U bolt flip using Sumo springs? Not sure how the SumoSprings baseplate would work….
  15. May 27, 2021 at 7:45 PM
    2mchfun
    You would just need to fab up your own plates, I have the yellow Sumo springs on my truck. Great addition!
  16. Oct 28, 2023 at 8:59 AM
    ID_IFD_3431
    ID_IFD_3431 New Member
    Resurrecting this thread!
    I've got a 2020 TRD pro, and I'm looking to run airbags and cradles in the rear with a u-bolt flip. Does anyone know a u bolt flip kit that will work with cradles?
  17. Jun 20, 2024 at 1:14 PM
    Andhon
    Andhon 2014 Platinum MGM CM
    Andy
    2014 Tundra Platinum MGM CM
    In case anyone is still wondering
  18. Jun 20, 2024 at 1:24 PM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Not arguing with you, but durobumps response is a absolute lie. Running a u bolt flip kit is not going to crush the axle tube. If that was the case the the weakest point on the tube would be where the spring perch is welded onto the axle.
    redrdr67 likes this.
  19. Jun 20, 2024 at 2:52 PM
    redrdr67
    redrdr67 New Member
    2007 White Tundra RCSB 2wd
    Strange response for sure. Have had a no name flip kit on my '07 since about 2012 and have not had any sort of issues resembling that response. There must be several thousand second gen + owners who have installed u bolt flip kits.
  20. Jun 20, 2024 at 2:55 PM
    CrunchTimeHD
    Louis
    Easton Pa
    What you have isn't a u bolt flip kit. It's a spring under lowering kit. Your u bolts are still facing downward like factory the flip kit the u bolt faces up and the nut is on the top not the bottom.
  21. Jun 20, 2024 at 3:02 PM
    redrdr67
    redrdr67 New Member
    I hear you and understand your statement. Regardless, that statement is still strange as it states "the axle tube can easily be crushed and the u bolts come loose"
  22. Jun 20, 2024 at 3:08 PM
    CrunchTimeHD
    Louis
    Easton Pa
    Gotcha mis understanding on my end of what you were trying to say.
  23. Jun 20, 2024 at 3:53 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Not a u bolt flip kit. Plus your rear is spring under vs spring over. I didn’t realize 2nd gen was spring under and 2.5 was spring over. Interesting.
  24. Jun 20, 2024 at 4:31 PM
    CrunchTimeHD
    Louis
    Easton Pa
    2nd gens weren't spring under. He installed a spring under to lower the truck.
  25. Jun 20, 2024 at 4:37 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Lol @ fitting 3rd gen
  26. Jun 20, 2024 at 7:08 PM
    RobertD
    Robert
    DFW, Texas
    In 2020 the the 2014+ were called 3rd gens until the 2022 was released. When they refreshed the 2nd gen in 2014 everyone started calling that the 3rd gen.
    They weren't talking about your model truck in 2020, it didn't exist.
  27. Jul 10, 2024 at 4:28 PM
    Andhon
    Andy
    Interesting, I wonder why they dont want to make a kit for the tundras then :/ The only company that makes ubolt flip kits is Archive Garage
