Is this noise normal?
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Jul 9, 2020.
  1. Jul 9, 2020 at 6:09 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Hello all. I have this noise that I'm pretty sure wasnt here before. It happens around 45-50 mph and under throttle. My mechanic says its a normal "harmonic pulley front end noise" and to not worry about it. Could someone maybe the next time they are driving tell me if they hear it? Hit 45 mph and thats about when the torque converter locks up, or overdrive i cant tell. And then once it locks up press down on the throttle but not enough to downshift obviously. Please listen to this video with headphones on or else u wont hear it. I'm a very overthinking person who hyper focuses on shit so i just wanna know what yall think. Thanks. The reason i think it might be normal too is it happens right after the rpms shoot down and high torque low revs along with a lot of throttle. https://youtu.be/_YY4Qb75oNI
    e3phung likes this.
  2. Jul 9, 2020 at 6:37 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Can’t hear a thing without microphones. Might be the canniboids working on you. Maybe lay off the stuff for a while?:notsure:
  3. Jul 9, 2020 at 7:06 PM
    Pucks18
    Been clean for 8 months buckaroo. Use sum headphones! Lol
  4. Jul 9, 2020 at 7:48 PM
    shifty` Ten EV 12's so you know I raise hell
    Which sound is it, the one that sounds like the wub-wub-wub-wub someone might hear after huffing a balloon full of NO², or the sound of a military-grade chopper hovering overhead, or the sound of someone hyperventilating on a digeridoo?
  5. Jul 9, 2020 at 8:11 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I don't doubt you may be hearing something troublesome, i have OCD about my truck as well. :) In your vid its almost impossible to hear anything that may be a problem that could be diagnosed here in my opinion. Good luck with it though.
  6. Jul 9, 2020 at 10:49 PM
    Pucks18
    The wubwub. The other sounds is a pinion bearing
  7. Jul 10, 2020 at 3:28 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Dank drop!!
    bmf4069, Darkness and shifty` like this.
  8. Jul 10, 2020 at 5:01 AM
    Fred
    Hand Protectors
    Good on ya. It was raining last night here on the Island. Didn’t want to get wet going to the truck for the headphones. I’ll listen later today.
    Pucks18[QUOTED][OP] likes this.
  9. Jul 10, 2020 at 5:03 AM
    Fred
    Hand Protectors
    shifty`[QUOTED] likes this.
  10. Jul 10, 2020 at 5:04 AM
    Fred
    Hand Protectors
  11. Jul 10, 2020 at 7:29 AM
    Headphones are a must if you want to hear. It's mostly low frequencies. There's another IDM joke in there somewhere, I know. The wub-wub (wait for the drop!) sounds a lot like the exhaust drone of the '68 pickup I had, I swapped an LS1 into it with a 6spd MT.
    Also sounds like the exhaust drone I've heard from a number of vehicles using aftermarket exhaust. So I guess my next question is about your exhaust. It your setup from headers to tail pipe all stock?
  12. Jul 10, 2020 at 8:20 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    sounds kinda like and exhaust leak to me. Check your exhaust for leaks.
  13. Jul 10, 2020 at 9:02 AM
    Pucks18
    Its a magnaflow i installed 4 months ago
  14. Jul 10, 2020 at 9:03 AM
    Pucks18
    Headers are stock, its a magnaflow catback
  15. Jul 10, 2020 at 9:03 AM
    Pucks18
    I just wanted to make sure it wasnt a tranny or somethig BIG
  16. Jul 11, 2020 at 7:26 AM
    Fred
    Hand Protectors
    Just listened with headphones. The sound has that exhaust type reverberation. You have new exhaust. One plus one equals maybe its exhaust Resonance related.
    Pucks18[OP] likes this.
