Best tire size for 2016 Tundra TRD PRO with CB Kit
Discussion in 'Wheels & Tires' started by titanryan, Jan 6, 2020.
  1. Jan 6, 2020 at 9:56 PM
    titanryan
    titanryan [OP] New Member
    Nashville, TN
    2016 TRD Pro
    Hi…..I am new to forum. I just purchased the Coachbuilder TRD Pro Kit for my 2016 Tundra TRD Pro. I also purchased the Bora 1.25” wheel spacers, as I am staying with my OEM Pro rims for now. The final decision is tire size. I am going with BFG KO2’s, so I am down to a 35x12.50 or 305/65. I have seen a couple Pro’s here in Nashville with the Kit and 35x12.50’s. I think they look great, and David says they will fit just fine. I would just like some input from anyone who has the same kit and tires for some feedback on clearance, etc. before I pull the trigger in the next couple days. Thanks!
  2. Jan 7, 2020 at 1:29 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Do u wanna do a cab mount chop? Then 35s If not then 305s
  3. Jan 7, 2020 at 9:44 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    Thanks for the link to your build......very nice setup. I am actually adding the LED headlights now as well. I am still mystified as to why they put the halogen lights in the TRD Pro back then, but I am upgrading finally.
    I have no problem doing a cab mount chop if necessary. Thanks for the input.
  4. Jan 8, 2020 at 5:24 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Aloha and welcome to Tundras.com, please check this thread out....
    https://www.tundras.com/threads/the-coachbuilder-trd-pro.23416/#post-563225
    there is a lot of good information and people here on the forum, and just a tip or piece of advice on the top right of the page under "You Inbox Alerts" you will see a search tab, think of it as google within the forum and you will find almost anything you are looking for especially wheel/tire sizes, and please don't take this as negative I am merely here to help and pass along info/advice. Also if you want people to respond really quickly post pics of your truck.
  5. Jan 8, 2020 at 9:39 AM
    xtyfighterx
    Ty
    North Idaho
    I’d go 35s personally. And no problem yes the stocks halogens were horrible the new LED sport lights are pretty dam good very happy with those.
  6. Jan 9, 2020 at 10:15 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    Thank you for the thread recommendation and response. I did find that thread at one point, so I appreciate you pointing it back out. I read back through it......Awesome info.
    LogCabins likes this.
  7. Jan 14, 2020 at 7:25 AM
    titanryan
    Nashville, TN
    2016 TRD Pro
    I put everything on this weekend.....kit, tires, lights. It rides great, looks great and no rubbing. The only issue I can notice is the driver side seems to be lower than the passenger side? I measured it out, and it confirmed my suspicion. I will search the site as well, as it seems like I saw a thread discussing that. It appears to be about an inch difference?
  8. Jan 14, 2020 at 7:30 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Yes that's the dreaded Toyota "Lean" from the fuel tank..battery...etc, that is on the drivers side of the truck.
  9. Jan 14, 2020 at 7:31 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Post some pics...would love to see your new setup! :D
    tbutler likes this.
  10. Jan 14, 2020 at 6:15 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    Wow....close to 1 inch even on a TRD Pro? I did not feel like I noticed it before I put the kit on? CB Kit is so simple....just shim right on top of strut without changing anything.
    I will post some picks shortly.....right now, this dang 1" difference is driving me crazy.
  11. Jan 14, 2020 at 6:24 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Did you remove the shocks completely when you did this? The Pro shocks are specific L to R for exactly that "lean". Could they have gotten switched?
    Other option is put one shim on the left, and two on the right.
    I have the same setup and I'm dead level with full 3"lift.
  12. Jan 14, 2020 at 6:38 PM
    LogCabins
    'Merica
    2017 TRD Pro
    I “believe” as I’m not 100 sure that the shims are 1 per side, as in a solid piece unlike before when he would send 4 shims total so you could do 2 on the driver and 1 on the passenger
  13. Jan 14, 2020 at 6:42 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Correct
    The PRO kit is 1 shim per side.
    Just thinking of options for leveling for the OP
    LogCabins[QUOTED] likes this.
  14. Jan 14, 2020 at 6:46 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    The shop did tell me that they did not completely remove the shocks. Is there an easy way to confirm this myself...meaning make sure they were not switched? I was thinking the same thing, but I felt like I was insulting them by asking. I am going by the Dealer tomorrow for a review. 1" is just too much for me. Could add another shim on driver side or replace shocks that are adjustable I guess (but hate to waste money).
  15. Jan 14, 2020 at 7:02 PM
    LogCabins
    'Merica
    2017 TRD Pro
    Yeah something seems off.....and I think @Toyotoholic might be on to something with whoever did the install switched them side to side, but if the shop says they didn’t remove them...I’m baffled as well
    Toyotoholic likes this.
  16. Jan 20, 2020 at 9:48 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    This is what it looks like from the front right now.
  17. Jan 20, 2020 at 10:23 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    Toyota Dealership is telling me the Driver side strut has been adjusted up (base or perch ring of the coilover spring moved up). The mechanic (who does lots of lifts on new Tundras there) is telling me that this has actually caused there to be less tension and therefore sag or something? Anyways, I plan to question him directly for further explanation...not computing for me. While I am learning, I am not a novice on truck suspensions. I can tell you the higher passenger side is certainly different when I look at that same base/perch. I also looked under 3 TRD Pros on the lot, and both sides were identical (unlike mine). However, I looked at my old brochure from 2016, and the picture of the strut /coilover is identical to mine (appears to be "adjusted up") I have not adjusted mine, so I have to think my TRD Pro came that way. Still confused.....see attached pictures with comparison if you care to opine.
  18. Jan 21, 2020 at 4:52 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Check the part numbers on your shocks. They are different coil overs with one going on the Left Front and the other Right Front.
    Have you called David? Something is fishy
    D946E5EB-419C-4380-A936-616D7689F8AB.jpg A756B33E-1643-4998-A7FA-8D49C2F1D8CA.jpg
  19. Jul 7, 2020 at 10:44 PM
    titanryan
    Nashville, TN
    2016 TRD Pro
    Sorry for such a late response. I ended up replacing the driver side coilover spring at the dealership after a lengthy inspection and discussion. This did remove most of the lean I was experiencing...at least put it within the "acceptable" spec. It was about an inch off when I first put the kit on, but it is now within .25 inches or less per their measurements with the new coilover.
