Load sensing valve complete assembly and brake lines needed.
Discussion in '1st Gen Tundras (2000-2006)' started by MrLimoAK, Jul 5, 2020.
  1. Jul 5, 2020 at 11:45 PM
    MrLimoAK
    MrLimoAK [OP] New Member
    Greg
    2004 4.7L SR5 Std Cab
    First of all I live 400 miles out of town and I'm off of the North American road system so sourcing parts is a challenge. So here goes thanks for reading. I'm thinking of taking on a neglected 04 Tundra SR5 4.7L 8 Cyl that I'm told ran up until the fuel pump went out that's currently the easiest fix I'm facing.
    VIN: 5TBKT44114S442372 Series: VCK40L, UCK40L if that helps anyone.
    So the Master Cylinder is missing I can source and replace that easy enough. The owner said some other brake part was scavenged off the vehicle. I have figured out someone has completely removed the Brake Proportioning Valve. To make matters worse cut all three brake lines that connect to it :-(.
    I have been doing some detective work but I can't get a clear picture of exactly what parts I need to order.
    Can someone assist me with the part numbers of the two brake lines that go forward from the Proportioning Valve and their part respective part numbers.
    And from the Proportioning Valve to the rear brakes. Air freight is expensive so I need the right parts the first time.
    And I'm looking for potentially a complete unbolt from the frame of a the Proportioning valve including bracket & bolts from the Frame -> Bracket -> Valve -> Rod -> Mount -> Axel. Hopefully with all the bolts etc. I have no local source so it would really help to have all the associated hardware nuts, bolts etc. etc.
    Greg
    Bethel, AK (400 Miles West of Anchorage)
  2. Jul 6, 2020 at 6:05 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
  3. Jul 6, 2020 at 6:28 AM
    Bethel? You are off the beaten path! As mentioned @Roman can help with parts/part #'s. Yotayard in Denver is a good source for used parts. Knowledgeable folks. Check out their site at www.yotayard.com
  4. Jul 6, 2020 at 6:41 AM
    Professional Hand Model
    Fred
    Hand Protectors
  5. Jul 6, 2020 at 6:44 AM
    Fred
    Hand Protectors
  6. Jul 6, 2020 at 6:48 AM
    Fred
    Hand Protectors
  7. Jul 6, 2020 at 6:54 AM
    Fred
    Hand Protectors
    Those diagrams should get you close enough to figure it out. I’d call your closest Stealer, so if you do have to drive there for the one part you forgot...
  8. Jul 6, 2020 at 2:22 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    If you see which parts you want from those images, just point them out and I can look up the part numbers and link you to them.
  9. Jun 27, 2025 at 9:34 AM
    Jbigg
    Jbigg New Member
    Silver 2006 Tundra 4x4 SR5 V8
    Hi, my truck has a bit of rust from its Midwest days and I’m replacing the brake lines, I need the valve box thing in the rear that 2 lines come into from the front of the truck and 2 lines go to the rear brakes. The part # is 47190B in the diagram above. This part has been a headache to find.
  10. Jun 27, 2025 at 9:39 AM
    bfunke
    bfunke Tundra Curmudgeon
    Where are you located? Might try a wrecking yard.
  11. Jun 27, 2025 at 9:48 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome. Read and learn how to use the EPC in this thread. It will teach you how to find any part number you want and or need. HOWTO: Use the Toyota Parts system to find & order parts | Toyota Tundra Forum
  12. Jun 28, 2025 at 6:07 PM
    I'm all about teaching someone to fish, but you seem like you may be a drive-by poster, only here for this, and maybe gone tomorrow, so here. You didn't bother to give us a cab type (potentially big mistake) but if your 2006 is an access cab or regular cab, this would be your part number. Note the index (PNC) jibes, as pulled from the part diagram (2nd image). Don't make the stupid mistake of buying your auto parts on scAmazon or fleaBay, you can pick up genuine OEM from most local dealers using the Toyota Parts system at a nice discount using https://autoparts.toyota.com
