2012 Tundra 5.7L V8 AC Issue
Discussion in '2nd Gen Tundras (2007-2013)' started by yamahasynth, Feb 15, 2019.
  1. Feb 15, 2019 at 5:04 PM
    yamahasynth
    yamahasynth [OP] New Member
    Hello all,
    I have a '12 Tundra 5.7L V8 that is having an a/c issue. The a/c light on the dash will blink and blow warm air. This started seemingly randomly during the middle of a 2 hour trip. I have googled and tried to remedy the issue but have come up short so far. I was trying to see if anyone had any better ideas or advice to give before I spend an arm and leg replacing parts. Below is what I've tried.
    1-A/C light flashed and blew warm. Whats happening is when the a/c is turned on, the compressor will spin and blow cold for about 3 seconds before shutting off.
    2- Replaced Mag Clutch Relay- same results
    3-Checked ground to compressor- Ground good
    4- Uncoupled all wire harnesses and re-coupled on compressor and from underneath the passenger-side dash
    5-Checked all Fuses- All good
    6-Vacuum Tested and Recharged system- Same results/ No leaks
    7- Jumped the Mag Clutch Relay- COLD AIR! A/c light is still flashing
    8- Replaced Mag Clutch Relay again- back to short cycle/ flashing
    9- Emptied system- No flashing lights but I'm too afraid to run the system for too long
    From what I can gather it could be the clutch speed sensor or the compressor lock sensor (maybe they are the same thing?? idk...) , both of which are located inside the compressor requiring a complete replacement. If this is true, why would the light not blink when the system was empty?
    If I do have to replace the compressor, would I also need to replace the parallel condenser as to not shorten the life of the compressor? Thanks for any help.
  2. Jun 27, 2020 at 9:59 AM
    rocks860
    rocks860 New Member
    I am having same problem. What did you find as a culprit?
  3. Jul 3, 2020 at 10:28 AM
    SMS56
    SMS56 New Member
    Same problem here as well. Compressor and clutch replaced. With the mag Clutch relay removed i get about 9.5 volts from the terminals thats supposed to engage the relay, only for about 3 seconds after ac button is depressed. Not sure what would cause that low voltage. Relay doesnt engage nor does compressor. I can jump the other 2 terminals with the relay removed and it works fine. With jumper installed and ac blowing cold i can hit the ac button to turn off the flashing and turn back on. Light stays solid.
  4. Jul 3, 2020 at 11:03 AM
    TemujinNomad
    TemujinNomad New Member
  5. Jul 3, 2020 at 11:56 AM
    SMS56
    SMS56 New Member
    Relay was first thing I replaced. Never engages unless you jump the relay terminals. What i dont get is how everything works normal when jumper is installed but 9.5 volts wont engage the relay to engage clutch. I know its a 12 volt relay and im not sure what voltage im supposed to be getting but id assume 9.5 would engage the relay. If it is indeed low i need to find the source. Need to verify the correct voltage at this point before proceeding any further if someone could help verifying that. That is the voltage im reading the first 3 to 5 seconds after turning on the a/c with the relay removed. Not sure if i would get that reading if the cover were removed from the relay so i could check with a meter while installed.
  6. Jul 3, 2020 at 1:07 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Just a thought
    Maybe the AC button/controller is bad?
  7. Oct 11, 2020 at 4:35 PM
    NTROUBLEWXOE
    NTROUBLEWXOE New Member
    ZACK
    2012 CREW SC
    Any results with this problem? My 2012 CM 47k miles is doing the same thing. Cannot find the problem and very reluctant to let someone else work on it for me.
  8. Oct 11, 2020 at 5:22 PM
    rocks860
    rocks860 New Member
    I did two things, and I wish I had tested each at a time.
    I Replaced the compressor and same symptoms appeared.
    O did not know how much oil was in it, so I had to remove it and check.
    I bought the compressor from eBay and it said that it comes with 4oz of oil and only needed 2.
    When I checked it had around 2, but at the same time I removed the control panel and cleaned it.
    Put it back together and worked great.
    So I am not sure If the issue was the control panel or not, since I did not do anything else with the new compressor I just I installed.
  9. Oct 11, 2020 at 8:04 PM
    NTROUBLEWXOE
    ZACK
    2012 CREW SC
    Thanks for the reply. I will try the control panel. Everything on the compressor checks ok, the clutch and the speed sensor.
    Ilgie likes this.
  10. Jul 1, 2021 at 2:02 PM
    Ilgie
    Ilgie New Member
    British Columbia
    08 DC Limited 5.7 4x4
    What was the outcome of cleaning the control panel? I’m currently going through the same issue with my truck. I just replaced the A/C compressor, turns on for a few seconds then clicks off and light flashes.
    My mechanic did have to use the relay from the tow package for the A/C system as p/o had removed it for some reason?? Would love this to be as simple as giving the control panel a deep clean…
  11. Jul 1, 2021 at 6:58 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Pressure switches can fail. If forcing the compressor to run magically makes your AC work, that's where I would look.
  12. Jul 4, 2021 at 8:18 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    I didn’t watch the video above, but I had a flashing ac light problem on my 4Runner- make sure you use the correct oem relay. It looks the same, but isn’t the same as others.
  13. May 26, 2024 at 6:56 AM
    1stundra
    1stundra New Member
    2012 Tundra 5.7
    I've been having the same issue ever since I got it out the shop years ago due to a deteriated wire that sent power to the number 5 injector. My truck was running in limp mode. 2 other shops told me I had a dead cylinder or a burnt valve. Turned out to be a wire without any rodent chew or cuts to coating that had deteriated. Took them a long time to figure it out. Months during first part of covid. Particularly took long because everyone in the shop kept catching covid.
    I'm afraid there is another deteriated wire or something like that for the ac. I see a lot if posts in forums that the problem isn't found and I'm willing to bet it's from bad wiring. As the mechanic said a coated wire should last forever literally. He said I don't want to tell you what to do buy you might want to trade it in. That was about 70,000 miles ago. Still running strong just no ac. I ran 2 wires to the relay box and put a toggle switch inside the truck as a temp fix. Manually cycling the ac is getting old but it's better than no ac in south Louisiana.
    Does anyone know if both the high level and low level switches are under the hood or is one inside the dash? That's one of the main things I want to check.
    I think I'm going to try and figure it out this year. I'm going to pull the dash soon and check for rodent chew.
