Shackles - Question??
Discussion in 'Suspension' started by Ry24000, Jul 2, 2020.
  1. Jul 2, 2020 at 1:40 PM
    Ry24000
    Ry24000 [OP] New Member
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    IMG_20200630_180556042.jpg IMG_20200626_183537234.jpg This is a picture of after market shackles installed on my Tundra. Its the shackle to frame connection. What do you see? Is this acceptable?
  2. Jul 2, 2020 at 2:25 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    did the installer put in new bushings ?
  3. Jul 2, 2020 at 2:36 PM
    Ry24000
    Carson, WA
    I'm the installer. Yes they are new bushings.
  4. Jul 2, 2020 at 2:37 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks like new green bushings and your questioning if it’s ok they aren’t pushed all the way in. Don’t remember when I had shackles. I assume so but someone that has them will have to weigh in.
    Xcumminsguy likes this.
  5. Jul 2, 2020 at 2:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is the bolt long enough?
  6. Jul 2, 2020 at 2:43 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Link to kit installed so we can get a Better idea of what you put in there?
  7. Jul 2, 2020 at 2:44 PM
    ckkone
    ckkone New Member
    SLC, UT
    What does the bushing look like on the leaf spring itself? That upper bushing is already a poly bushing, looks like those green ones are meant to go in the spring not the frame? Either way there is a sleeve inside those bushings so if everything is torqued to spec then its probably meant to be that way, maybe to provide a space for grease between the bushings?
  8. Jul 2, 2020 at 2:47 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    To me , it looks like the spacing is too wide and those green spacers? need to compact towards the frame a bit. - I could be wrong-
  9. Jul 2, 2020 at 2:55 PM
    Kanobi13
    Kanobi13 New Member
    What company made them?
    SC_TRD likes this.
  10. Jul 2, 2020 at 5:44 PM
    Ry24000
    Carson, WA
    They are greaseable shackles, so no sleeve. Just a pin with a shoulder. The shoulders are tight up against the shackle on both sides! I am going to measure the gap with a washer and a feeler guage. Just by looking at the gap I estimate 3/16". Doesn't seem right to me!?
  11. Jul 2, 2020 at 5:50 PM
    Ry24000
    Carson, WA
    I don't think your wrong. The bushing flange does fit up to the frame when the shackle shifts. If that makes sense. I think the pin shoulders could be a little closer together.
  12. Jul 2, 2020 at 5:52 PM
    Ry24000
    Carson, WA
    I think too long
  13. Aug 27, 2020 at 5:37 PM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    @Ry24000 did you get this settled w/ Ironman?
  14. Aug 27, 2020 at 6:15 PM
    Ry24000
    Carson, WA
    I
    They say it's ok and the design. I feel it's a little sloppy. I'll lift the truck and get some feeler guages in there to get accurate measurements and shim it. A winter project.
    TRDblvd[QUOTED] likes this.
  15. Jan 4, 2024 at 3:32 AM
    Bluutundra
    Bluutundra New Member
    Oregon
    2008 Naut. Bl Tundra Limited
    -295/70r18 on KMC’s -Ironman Foam Cell Pro Struts & Rear Shocks 3.5inch lift -Rear air bags
    How did this install end up? and how are you liking the durability of the Ironmans after a couple of years? I have the FCP Stage 1 on order for my 08’
  16. Jan 9, 2024 at 12:08 PM
    Ry24000
    Carson, WA
    I never have done anything about it. Moved then family troubles and new house projects got in the way. The rig runs good though
    Bluutundra likes this.
