  1. Jul 1, 2020 at 7:28 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    14 hours one way! I think the drive is worth it for sure. I was looking online to try and determine what gear ratio I will have to do a conversion to and the 2005 double cab has the mismatched ratios on each site I looked at.
    Check this one out. I'm pretty sure the ratios are supposed to match as well.
    https://www.driverside.com/specs/toyota-tundra-2005-4544-10660-0?style_id=29142
    It's under axle ratio on the Advanced technical data.
  2. Jul 1, 2020 at 8:10 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Peek-a-boo...
    bmf4069 likes this.
  3. Jul 1, 2020 at 8:52 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    If your trying to make space you could sell me your OR fab skid plate ;D
    Darkness[QUOTED] likes this.
  4. Jul 1, 2020 at 9:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm gonna think about that, I didnt want to sell, then I did, now I'm just indifferent. Let me think if over. :cool:
  5. Jul 1, 2020 at 9:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i'll buy the beetle to save ya space.
    my mother has always loved the old beetles. be a nice birthday gift! lol
  6. Jul 1, 2020 at 9:34 PM
    jImmegart
    Jonah
    California
    Ya think it over, Ill be here ready! :spending:
  7. Jul 1, 2020 at 9:38 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Haha! So many people want these cars.
    jImmegart and empty_lord[QUOTED] like this.
  8. Jul 1, 2020 at 9:48 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Do you have a 2 wheel drive? If you have a 4 wheel drive that carrier bearing should be the sealed one.20200618_121835.jpg
  9. Jul 1, 2020 at 9:49 PM
    empty_lord
    05 rollover special
    i run the unsealed... fits fine... just little less bearing protection.. but meh.
    MS22[QUOTED] likes this.
  10. Jul 2, 2020 at 5:09 AM
    Haha! Mine showed up yesterday.
    lsaami[QUOTED] likes this.
  11. Jul 2, 2020 at 5:34 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Ohms tested the OLD injectors. All were within spec reading about 13.9 (+/-.2).
    NEW injectors package cover states the 12 hole injectors test at 13.
    NUDRAT likes this.
  12. Jul 2, 2020 at 5:37 AM
    speedtre
    speedtre New Member
    Inland Northwest
    You are in FL right? That is some legit logic. We are in Ga but thinking about moving to a state that gets a fair amount of snow, so I don't think that would be a good idea, but if we end up staying here in GA I might consider this as it makes perfect sense. :thumbsup:
    imDementeD[QUOTED] likes this.
  13. Jul 2, 2020 at 5:43 AM
    Fred
    Hand Protectors
    OLD MAF Ohms Test results in a fail. Should be reading Spec at 2.19-2.67. Look at the dirt/burnt prongs. Even with cleaning they still stay like this.
    NUDRAT and theblurry1 like this.
  14. Jul 2, 2020 at 5:49 AM
    I know you like protecting your money makers, but does it ever take away from your sensory or tactile use when trying to work on the truck?
  15. Jul 2, 2020 at 5:51 AM
    Fred
    Hand Protectors
    So far everything replaced in Engine Performance over the last 2 years has been out of Ohm Spec (ignition coils, o2 Sensors, MAF) except the Fuel Injectors. Haven’t flow tested those so we’ll never know Post-mortem Spec.
    FYI: No CEL (check engine lights) for any of these deficiencies. Yes my CEL works.
    theblurry1 likes this.
  16. Jul 2, 2020 at 5:52 AM
    speedtre
    speedtre New Member
    Inland Northwest
    That site is wrong...the axle ratios have to match. The odd thing is your truck is listed as a 3.92 and the DCs as a 3.91...which seems weird, so you may need to swap at least one of the gears anyway...or take the opportunity to do 4.10 or 4.56....this is the official 2005 tundra brochure...
    http://www.russauto.com/ncinv/modelinfo/brochures/05Tundra.pdf
    bmf4069 and YardBird like this.
  17. Jul 2, 2020 at 5:53 AM
    Fred
    Hand Protectors
    These are Nitrile Gloves. They form fit and are the best gloves I’ve ever used in terms of Tactile Sensory. I use them to gently pick up Ants off the sidewalk so people don’t step on them.
    seth419, NUDRAT, bassman417 and 6 others like this.
  18. Jul 2, 2020 at 6:05 AM
    Nitrile coated right? Next time your at big box, look for gorilla grip or gorilla gloves, much thinner woven material, then covered by another thin nitrile layer I believe. You’ll discover sensei moves you never knew you had before!
    I wear the XL silverback edition
  19. Jul 2, 2020 at 6:07 AM
    Fred
    Hand Protectors
    I have a secret book of moves I’ve yet unleashed here on this site. Might write about them in a book called Hand Jives by PHM.
    NUDRAT, bmf4069, FirstGenVol and 2 others like this.
  20. Jul 2, 2020 at 6:09 AM
    Who will play you in the blockbuster? Hahah
    bmf4069 and Darkness like this.
  21. Jul 2, 2020 at 6:10 AM
    Fred
    Hand Protectors
    My truck is 4wd and TuRD ‘Off Road Spec’ and came factory without a sealed unit. The VIN Spec even suggested the unsealed one when I put in New One. I wonder whats up with this?
  22. Jul 2, 2020 at 6:13 AM
    Fred
    Hand Protectors
    Not sure, but I’ve been scouting this site for potential models. So far @FirstGenVol has the nicest hands. When I say that, I mean he keeps things manicured nicely. They are small hands, though, so for that he gets one demerit.
  23. Jul 2, 2020 at 6:29 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Yes sir, 2WD. Thanks for looking out!
  24. Jul 2, 2020 at 6:37 AM
    Is there even any doubt?
    There is no way I could live up to those standards. I was too embarrassed to wear gloves in front of Noah so my hands are ruined now.:annoyed:
    Tundra2, bmf4069, Darkness and 3 others like this.
  25. Jul 2, 2020 at 6:46 AM
    Yes. @rock climber he's got a good suggestion. I would do that seal while you're in there. It's worth the $13.
    Did you go with an OEM blower motor or aftermarket? This might be the last summer for mine.
  26. Jul 2, 2020 at 6:51 AM
    Bulldog_tundra
    USA
    2006 Double Cab
    I went with the TYC brand, I think it was $31 on Amazon. I’ve always used them for non-critical replacement parts and haven’t been let down so far - we’ll see how long this one lasts.
  27. Jul 2, 2020 at 8:14 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I just replaced mine with OEM so much nicer now that it doesn't sound like little mice are running though it, the squeak was obnoxious!
  28. Jul 2, 2020 at 8:26 AM
    How much was the OEM unit?
  29. Jul 2, 2020 at 8:31 AM
    Casper421
    In the woods
    06 DC
  30. Jul 2, 2020 at 8:33 AM
    No, I ended up buying that Smittybilt unit. It seems well built for the money! Why, did you find a good deal?
