3/4 ton
Discussion in 'General Tundra Discussion' started by Basskrazee, Jun 26, 2018.
  1. Jun 29, 2020 at 2:29 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Ten lug nuts, I would say just by that it is a 1 ton truck.
  2. Jun 29, 2020 at 3:49 PM
    I can see where these numbers might get a little confusing, and in reality don't mean actual weight. For instance, I will use my truck since I have all the numbers right in front of me. My single rear wheel 1 ton has a capacity of 3808 lbs with my chosen options. If I had not had so many options, the truck would take over 4000 lbs in the bed. That would be 1.5-2 ton truck right? Not exactly. My rear axle weight rating is 7050 lbs.
    7050-3808=3242 lbs. This is about right what my rear axle weight is unloaded. The truck front axle weight rating is 5600. My front axle weight empty is around 4500 lbs. This would make sense due to my truck weighing in at ~7750 lbs empty (4500+3242=7742 lbs). Gross vehicle weight rating is 11500 lbs for my model truck.
    In reality, I can't just put 3808 lbs in the bed of my truck. Here is why:
    Gross vehicle weight rating is 11500 lbs.
    Gross vehicle empty weight is 7750 lbs
    11500-7750=3758lbs so I came up a little short than my posted 3808 lbs capacity. Most likely, some of that weight would in fact transfer to the front axle, which I do have a spare 1100 lbs. This is also the reason gooseneck hitches mounting points are a few inches in front of the rear axle to transfer the weight.
    Following all the weight ratings can be a struggle. You can be good on one part and over on another. So frustrating.
    Your rear axle rating is 4000 lbs, and I would be willing to bet if you pulled on a CAT scale empty, the rear axle weight of your truck would be around 2600-2700 lbs. Add in the 1300 lb capacity and you have around 4000 lb axle weight rating. Does this make sense to you?
    This is what needs to be checked when hauling/towing:
    Gross vehicle weight rating GVWR
    Gross combined weight rating GCWR
    Gross axle weight rating (front and rear)
    Tongue weight/capacity rating
    Tire weight rating- the P metric craptastic tires that come on 1/2 tons these days actually exceed any capacity the truck is rated for. When (if ever) you have a 3/4 or 1 ton you really need to pay attention to load index ratings as well. Just the other day a Tundras member showed me he had LR E tires with a maximum tire pressure rating of 65 psi and load rating of 3200 lbs. Learn something new every day.
    On to your next question about O'Keefe Music foundation. I have no affiliation with this great cause other than donating money. To me, I feel music should be a part of every child's life.
    Check it out:
    https://www.okmusicfoundation.org/
    I was floored what these skilled young people can do when they have the tools. Some of my favorites:
    One of my favorites. I in fact removed the Slipknot version from my playlist and added this one. THEY Kicked some ass!
  3. Jun 29, 2020 at 3:58 PM
    The pickup classes of 1/2 ton, 3/4 ton, and 1 ton have absolutely nothing to do with the trucks payload capacity or tow ratings in modern trucks. They are holdover class names from way back when the payload was 1/2, 3/4, and 1 ton, but modern trucks surpass these payloads. The classes were not updated to reflect this, so you are better off viewing the class as having nothing to do with actual payload.
    The Tundra is on the low end of the current payload numbers for most half ton trucks, and it is most certainly NOT anywhere near a 3/4 or 1 ton in capability. It's frame is a half ton frame. Period.
    ColoradoTJ and Cpl_Punishment like this.
  4. Jun 29, 2020 at 4:10 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Like @AzureNightmare said, the halfton, 3/4 ton and one ton designations are out of date. Probably better to just think of them as 1500, 2500 and 3500 series trucks. The highest payload you can get in a 4x2 Tundra SR is about 1700 lbs, which would be middle of the road for a 1500 from the big 3. A GM 1500 with max trailering package can have a payload over 2000 lbs. A Ford F-150 with their max payload package can have a value approaching 3000 lbs, I've been told.
    ColoradoTJ likes this.
  5. Jun 29, 2020 at 4:21 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Going to be honest even if they say it is rated at that I still wouldn't put 3k in the bed of a F150 or any other 1500 series truck for that matter.
  6. Jun 29, 2020 at 4:29 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Agreed but it would be nice not to have to worry about tongue weight when towing, say, a 7000 lb trailer
    Ace402, ColoradoTJ and Devcom[QUOTED] like this.
  7. Jun 29, 2020 at 6:27 PM
    FWD Tundra
    Washington
    Well I guess that got a good conversation going:rofl:
  8. Jun 29, 2020 at 7:54 PM
    This is a great conversation to have.
    I have always said the Tundra is one bad ass 1/2 ton. Sometimes people forget the 1/2 ton part.
    The reason I bated you for this conversation is when people start saying “towed the shuttle (actually pulled)” or “I towed a 15000 lb backhoe plus trailer (so that was probably 20000 lbs)” this gives people the idea that its ok.
    We have new members or even guests every day searching the forum for information. We owe it to them to be honest so they purchase the right truck or equipment for the long haul.
  9. Jun 29, 2020 at 10:08 PM
    FWD Tundra
    Washington
    I have done all the figuring from my owners manual for towing, trailer weight, tongue weight, axle weight, and all is well but it still leaves the 1/2, 3/4, and 1 ton labels a mystery. I wish there was more definite information as to how they come up with the different ratings. Thanks for the info. Still confused but will get over it.
    ColoradoTJ,
    That is a great mission for young and the old who enjoy playing music. You know sometimes all it takes is a chance to make a difference. Music has been a part of my children's school curriculum, and we thought that was a necessity. Good place for donations. Also that keeps kids off of the streets. Nice job!
  10. Jun 29, 2020 at 10:32 PM
    The 1/2 , 3/4, 1 ton designations are just outdated. When they were originally used, that was the payload of the truck. As time went on the payloads got bigger, but the designations stayed the same. It's so obsolete that @Cpl_Punishment is on the right track of just thinking of them as 1500, 2500, and 3500 series instead of associating any weight with them.
    Cpl_Punishment and ColoradoTJ like this.
  11. Jun 30, 2020 at 2:12 AM
    FWD Tundra
    Washington
    That is what I have come to the conclusion of, that they are as you say outdated. So ya agreed. The Tundra meets all my needs and is an awesome truck.
  12. Jun 30, 2020 at 4:28 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    I would be at the dealership as the rolled off the truck if they would make a 3/4 ton, gas or diesel with crewmax and 6ft bed, if it had lockers and winch, even better.
  13. Jun 30, 2020 at 6:53 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    New ford diesels Are to sexy tho ...hate ford but dam those things are badass
  14. Jun 30, 2020 at 6:55 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    Once upon a time, Toyota made 3/4 ton and 1 ton trucks.
    Back in high school, a friend of mine had an early 80s 3/4 ton truck similar to this one:
    It is funny, that little truck has a higher payload rating than the current Tundras.
    I also found a Toyota commercial for a 1 ton truck:
    https://www.youtube.com/watch?v=-1bVH2gT5Mo
    The 3/4 ton and 1 ton market would probably be a tough segment to get back into for Toyota, but if they did, I think they could eventually make a name for themselves in that space. It would probably take some time to convert the big 3 die hards, but once they realize the Toyota reliability, it is a no brainer.
    Terndrerrr, Jernik, GayFish and 8 others like this.
  15. Jun 30, 2020 at 7:39 AM
    don3032
    don3032 New Member
    don
    LOOKED AT AN F250 TREMOR THIS WEEKEND. THAT IS A BADASS F250 3/4 TON DIESEL WITH OVER 1000FT LBS TORQUE. ONLY THING DIDN'T LIKE IT IS A FORD, AND THAT UGLY, TINY, USELESS SLIDING REAR VIEW WINDOW THEY COME WITH.
  16. Jun 30, 2020 at 7:56 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is the Tremor the new gas engine or some kind of off road package? Ford never made that clear.
    I thought it was Ram that had 1000 ft-lbs in the new Cummins.
  17. Jun 30, 2020 at 8:37 AM
    don3032
    don3032 New Member
    don
  18. Aug 10, 2021 at 8:19 AM
    desertpirate
    desertpirate New Member
    Rand
    All these Ram drivers are sending their "end" dollars to France!
    FCUSA is Fiat/Chrysler U.S.A. That is a French Corp. doing business in the US. Chrysler is OWNED by Fiat. I bought a Tacoma for my light duty truck (car) and part of it was that it was #1 built by American workers and #2 made with a higher percentage of American made parts that ANY other truck in its class. Interestingly enough is that the Colorado/Sonoma GM made trucks are barely more American than Nissan and The Ranger is somewhere between the Tacoma and the GM made trucks. I also own a 1 ton dually Ram and would buy a competing Tundra in a heartbeat if available. Corporate dollars are multi-national regardless of branding. What matters more to me is 'how many American workers are earning a living building these trucks'?
    Terndrerrr likes this.
  19. Aug 10, 2021 at 8:57 AM
    Welcome to Tundras. Hell of a first post.
    Cygnus X-1 and Cpl_Punishment like this.
  20. Dec 6, 2021 at 8:25 PM
    #50
    Cygnus X-1
    Cygnus X-1 Gangster of Boats
    Timm
    STL
    2018 Taco Sport MT
    Z1 Off-road has a similar Titan build.
    Was doing unrelated research and ended up here soo.... Welcome to TW. I mean uh, Tundras.
    Stainlesst and BTBAKER[QUOTED] like this.
  21. Dec 7, 2021 at 3:54 AM
    #51
    CMikeB
    CMikeB New Member
    Back in 2010 when I BOUGHT my truck, there were rumors that Toyota was thinking about a heavy duty Tundra using a Caterpillar Diesel. Cat wasn't into playing the EPA's 'shake-down' games, for on-road engines, so it went nowhere. It was a good conversation topic but nothing else. Imagine a Tundra with that yellow "CAT" badge on the doors.:D
    DZ_ and Cygnus X-1 like this.
  22. Dec 7, 2021 at 5:17 AM
    #52
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    My personal observation is similar, but different.
    Yes, when I'm driving on the main roads of the western states the U.S. brands predominate.
    But, it seems more times than not when I pull into the trailhead parking lots, or the campgrounds near the rivers where I fish, Toyotas are everywhere, and the U.S. brands are in the minority.
  23. Dec 7, 2021 at 5:35 AM
    #53
    Cygnus X-1
    Timm
    STL
    2018 Taco Sport MT
    Edit boils down to what comes in and out of the shops all the time. Granted with a massive numbers advantage you are going to see more US brands in the shops but if you look at percentages of vehicles on the road versus vehicles down for repairs etc, that's where the real story is told. And there is definitely something to be said about the sheer robustness of the Tundra versus its US counterparts. Especially in recent years.
    Granted, no vehicle is perfect, and of course any forum group you're going to have people nitpicking even more than the usual truck driver / fan / owner, like my buddies 2019 Tundra, we've got a list of about 74 things that could be better about it but overall he loves the dang thing and he grew up as Mr Chevrolet
  24. Dec 7, 2021 at 5:49 AM
    #54
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    One ranch I worked for actually used most 3/4 ton trucks (most ranches), a couple tundras, and a land cruiser.
    Trooper2 and Cygnus X-1 like this.
  25. Dec 7, 2021 at 5:54 AM
    #55
    Cygnus X-1
    Timm
    STL
    2018 Taco Sport MT
    Gotta have something to take to church
    DZ_, Lake.Life24 and Trooper2 like this.
  26. Dec 7, 2021 at 6:20 AM
    #56
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    That’s an interesting theory but this past weekend I went on a 400 mile trip and decided to count the number of Tundras I saw on the road as compared to the number of Rams I seen . I counted 18 Tundras ( not too bad ) there used to be a lot less . 323 Rams , one thing they all had in common was none of them were on the side of the road .
    Cygnus X-1[QUOTED] likes this.
  27. Dec 7, 2021 at 6:28 AM
    #57
    Cygnus X-1
    Timm
    STL
    2018 Taco Sport MT
    I too count truck sometimes. Because I'm still 8 years old inside lol (and I still collect Hot Wheels....) :anonymous:
    Curious, where were you driving?
    GODZILLA likes this.
  28. Dec 7, 2021 at 7:00 AM
    #58
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Highway 400 up north from Hamilton. I completely understand about being 8 on the inside .
    One of my kids asked me recently when they can expect to mature , I told them that I’d have to let them know .
  29. Dec 7, 2021 at 7:24 AM
    #59
    Cygnus X-1
    Timm
    STL
    2018 Taco Sport MT
    Have a sticker on one of my.bass guitar cases that says "All Grown Up and Still Waiting to Become a Rock Star"
  30. Dec 7, 2021 at 8:29 AM
    #60
    bwh
    bwh New Member
    I wouldn't want anything to do with CAT at this point. Their stance on right to repair is appalling. Better than Deere, but that's not saying much.
    Cpl_Punishment, Cygnus X-1 and DZ_ like this.
