Octane question
Discussion in 'Performance and Tuning' started by iainh, Jun 25, 2020.
  1. Jun 25, 2020 at 2:20 PM
    iainh
    iainh [OP] New Member
    Took a long ski trip through Colorado, Utah, Montana and Wyoming back in February. Along the way I noticed gas stations selling 85 octane fuel at a good price. I live in Southern California and my user manual says to use 87 octane. If you purchase your Tundra in one of these states offering 85 octane does your instruction manual still specify 87 octane or are the engines adjusted for the lower octane?
  2. Jun 25, 2020 at 4:59 PM
    Stig
    Stig New Member
    Probably the few dollars you save filling up the tank is not worth losing the peace of mind. Gas is cheap in the US and even cheaper right now
    omgboost likes this.
  3. Jun 25, 2020 at 5:35 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Back in prehistoric times, when I was in collage, the internal combustion textbook I had said use the lowest octane that doesn't cause spark knock. I generally follow the manufacturer's recommendations, but if it's worth it to you to save a few bucks, have at it and see what happens.
  4. Jun 25, 2020 at 5:41 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Due to the elevation and thinner air, you are fine to run 85
    Wynnded and JMB like this.
  5. Jun 29, 2020 at 4:29 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    I burn it all the time in CO. You loose absolute compression in high altitude so lower octane burns without predetonation. Turbo engines need to stick with 87 though.
