Tundra led headlight adjust?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Handbanana, Jun 27, 2020.
  1. Jun 27, 2020 at 11:49 AM
    Handbanana
    Handbanana [OP] New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    I have the new led trd pro headlights on the wife’s tundra and one of them is aimed way too high. I installed them straight out of the box so I was hoping they were close to what I need. Has anyone adjusted these or know how to adjust them. Sorry for the dumb question. I’m also aware of the adjuster button inside the truck but one light is good the other is to high.
  2. Jun 27, 2020 at 11:53 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    panicman and Handbanana[OP] like this.
  3. Jun 27, 2020 at 3:18 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    @Makoy339 has it right...way down deep in @iHacker thread, look for this:
    One more thing...
    Some users noticed their headlights arrived aimed incorrectly, compare your new headlights heigh with the marks we placed in the wall in step 1, keep your leveling system in 0 and do the required adjustments,
    Each headlight have a channel reaching the leveling system motor gears, and you can rotate the gears as needed UP/DOWN just turning gears with a long Phillips screw driver.
    [Photograph of adjustment]
    Then this:
    If for any reason you forgot to mark your stock headlights heigh follow this video to correctly AIM your headlights from scratch.
    https://www.youtube.com/watch?v=GWvSWBlAwnI
  4. Jun 27, 2020 at 3:25 PM
    Handbanana
    2018 TSS CM 4x4
    Thanks I’m going to fix it tonight when it’s dark
