How can i use this switch?
Discussion in '1st Gen Tundras (2000-2006)' started by 04DCTundraMan, Jun 22, 2020.
  1. Jun 22, 2020 at 12:36 PM
    04DCTundraMan
    04DCTundraMan [OP] Crimedog McGriff
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    I want to add some additional lighting to my truck, but dont want to add any aftermarket buttons if i dont have to. if i do im thinking switch panel in the center consol, out of sight.
    I was thinking i could tap into a set of lights already in use, but then was wondering if maybe i could use one of the blanks in my dash. One of the ones im thinking is the blank below, i think it would normally be a 4WD button? for me it does nothing and says tundra on it. I want to make this button work again...anyone done that, for anything? Doesnt have to be a light.
    I have another by the mirror adjustment buttons i was thinking i could do the same thing with, but would really like to bring this blank to life.
    Also having a hard time finding what would normally go here to buy to try this idea. was going to ask the dealership when i go in next.
  2. Jun 23, 2020 at 6:20 AM
    chester
    chester best member
    2005 Double Cab SR5
    On my truck, that switch says "SWITCH L". It puts the transmission in 1st gear.
  3. Jun 23, 2020 at 6:39 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Yes, that is for the 5 speed AT in the 05/06 Tundras.
    You could always drill that blank out and add a switch OR buy an OEM "shift L" switch and use that too. What sort of AUX light setup do you have to run?
  4. Jun 23, 2020 at 7:06 AM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Would be super cool to get a switch there that looked factory. Wonder if I can get a replacement cargo light switch and convert it? hum.
  5. Jun 23, 2020 at 7:47 AM
    04DCTundraMan
    Ok interesting. I’ll try and find that if I can’t figure out how to use it. Thanks!
  6. Jun 23, 2020 at 7:49 AM
    04DCTundraMan
    Yea I like the idea of trying to drill out and use it. Not sure how to “make” a button, but I’ll do some research.
    I don’t have a light yet, more so planning how to hook it all up before buying. I have a Bull bar so I was thinking about an off road light or something, but didn’t want to wire it into my headlights. Was planning on getting a bright one for when we go camping so I don’t want to blind people.
  7. Jun 23, 2020 at 7:50 AM
    04DCTundraMan
    Yea I was going to run led bed lights and try and tap into the cargo light so when I turn it on they all come on. Was thinking I could use that button for the other lights, but light be weird to have my cargo light on if I’m driving down a camp trail....but I guess who cares. Just think it would be sweet to have the blanks in my truck working.
  8. Jun 23, 2020 at 10:34 AM
    There's quite a selection of random buttons and switches you can get that would fit in there. You just gotta get the right drill bit size. I think mine says cargo light so maybe you could hunt around and find that one.
  9. Jun 23, 2020 at 10:57 AM
    04DCTundraMan
    yea that's what ive been trying to find, but the 2 oval buttons are connected on my truck, not independent. So i need a hazard light on bottom with a different button on top.
    Thinking this side may be a better option. The RSCA Off button is a blank on my truck. if i could do that one, it's independent of the other lights. Just need to figure out how to rewire it.
  10. Jun 23, 2020 at 11:01 AM
    04DCTundraMan[OP] likes this.
  11. Jun 23, 2020 at 11:33 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Yeah, I just pushed out the blank on my 2002 and put in a rocker switch from here:
    https://www.keepitcleanwiring.com/catalog/Switches/Toggle-and-Rocker-Switches
    (SW17R for the red) It just slides in and holds due to friction/expanding clips, very nice! No drilling needed and can be removed and replaced by the blank again easily.
    The switch has three contacts. I suggest using a DMM to test. I ran a continuity test to see which two were connected when the button was in the "on" position and the other contact (which is a gold color as opposed to silver) was the ground, which will allow the light on the switch to work when it is all connected. I wired the switch to a fuse in the box to the left of the brake pedal and the other side to my reverse camera. I also ran the ground to a bolt in that same area as the fuse box which is being used as a ground for something else (OEM).
    @Darkness gave me a great set of photos to remove the panels and pointed me to the url above.
  12. Jun 23, 2020 at 12:26 PM
    04DCTundraMan
    Awesome! Thanks for the links and info! That helps a ton and definitely looks like the best route to take. Now to find the light and start ordering switches. ill post up when i get going
    robabeatle[QUOTED] likes this.
  13. Jun 23, 2020 at 12:37 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    +1 thanks for the info. I had no intention to add any lighting to my truck but this makes it very easy to do so, I think I want to add a couple of switched aux lights to the rear bumper area just because. :thumbsup:
    robabeatle and 04DCTundraMan[OP] like this.
