Tundra Winch Bed Install?
Discussion in '2.5 Gen Tundras (2014-2021)' started by EIRE1916, Jun 20, 2020.
  1. Jun 20, 2020 at 5:47 PM
    EIRE1916
    EIRE1916 [OP] New Member
    Hi
    I’m trying to install a winch in the bed of my Tundra 2018 year. The goal is to use it to assist in pulling heavy things up a ramp into the bed.
    Any of you guys do this?
    Is it a difficult install?
    Where do I get the parts etc, or should I have someone install it?
    I had a hard tonneau cover so I was planning to mount underneath it
    Is there any stores etc that sell and install them?
  2. Jun 20, 2020 at 6:18 PM
    EIRE1916
    I’d winch a max of probably 500 lbs.
    I have a genuine Toyota bed divider I just wonder if that would sustain the winch mount for that amount of weight? The bed divider is connected to the side rails
    I’m not planning on winching an ATV or anything into the back but if someone here tells me it can easily be done and not cost much more or something I’d probably do it and then not be limited in future
  3. Jun 21, 2020 at 7:34 AM
    EIRE1916
    I’d accept under 400 lbs if it worked...just gathering thoughts as that may work for what I’m doing right now
    any idea what the bed hooks are rated or considered limited at?
  4. Jun 21, 2020 at 7:45 AM
  5. Jun 21, 2020 at 7:47 AM
    EIRE1916
    yep I’ve seen this and it looks great but how would that work if I have the Toyota hard tonneau in the place where that needs to be? I don’t think it’s comparable or is it
  6. Jun 21, 2020 at 7:53 AM
    What exactly are you trying to do? are you handicapped? I’m just trying to imagine what you would need a winch in the back of the bed to then pull less than 400# of something up a ramp, and be under a cover?
    Friday post?
    @bmf4069
    Pinay and GODZILLA like this.
  7. Jun 21, 2020 at 7:54 AM
    What are you trying to winch up ramps into your bed that will fit under a bed cover? I would still prioritize the winch position being higher over the cover, but that is my preference. A winch mounted low is going to be applying a LOT more force forward into the ramps than it is upward to get it in. I would be concerned with collapsing the ramps, or ripping out anchor points, because your forces will be way more than 500 pounds in that situation.
    15whtrd, Mater, Pinay and 2 others like this.
  8. Jun 21, 2020 at 8:11 AM
    A cheap option that might work (we used it to get elk into the bed of an old ford before) is to hook a short chain or lifting strap between the anchor points at the front of the bed and use a come-along attached to the center to winch it in. Similar to how this guy got his quad into the bed.
    423798d1459459459-help-i-want-winch-my-m_48fb2befd96f72e4da22b224f662614472662b10.jpg
    15whtrd, Mater, Black Wolf and 2 others like this.
  9. Jun 21, 2020 at 8:21 AM
    If it has to fit under the cover, I'd mount a plate that used the front bed mounting bolts to secure it to the frame and then do something similar to what this guys has in his video. We don't have the bed tracks that he does in his Nissan, but it still illustrates the point and the anti-abrasion is important too.
    https://www.youtube.com/watch?v=zvDfoiDDh_k
    NewImprovedRon and Mater like this.
  10. Jun 21, 2020 at 8:36 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Exactly. If you want to keep it under the tonneau then you’re probably going to have to make a custom mount. Shouldn’t be too hard. If you’re not doing this winching every day I’d go with the chain and come-along approach. Did this with my atv a dozen or so times. Never a problem.
    GODZILLA[QUOTED] likes this.
  11. Jun 21, 2020 at 8:41 AM
    IIRC the bed hooks are rated for 400lbs, but 400lbs for load securing limit is a lot different than 400lbs working limit. Just look at lifting chains and load securing chains. Very different properties and cost.
    NewImprovedRon likes this.
  12. Jun 21, 2020 at 2:19 PM
    EIRE1916
    Hey guys
    thanks for the replies I didn’t get alerted to any of them.
    I’m not handicapped, I’ve a really bad bad and right now it’s even hard to walk. It’s a bad day today but I’m generally not like this and I try to go easy on my back because I’m aware of it.
    right now I’m trying to put a steamer into the bed, up the ramp, which I have and into the truck bed to drive it A to B. I can’t lift 200 lbs, and most things I’d be moving are under 500 lbs and I don’t know anyone on their own that can lift that even without a bad back.
    so I’m just asking for options. The cheap option you mentioned may work, with straps between the anchor points. Unfortunately I can’t put a winch on the steamer. But maybe put a winch in the middle of the straps on a pulley or something to then pull it up the ramp.
    I agree it would be nice to have the winch up the same height as the roof. I may do this only a couple of times a year however
    I’m just trying to see how you guys would do it. We’ve not got much help as we don’t have family etc around
  13. Jun 21, 2020 at 2:22 PM
    The image I posted of the cheap option was more to illustrate the concept. You can easily use a strap or chain up front and connect the come along or winch to the center with a clevis like in the picture. Doesn't really matter which end is pulling.
  14. Jun 21, 2020 at 2:29 PM
    Here is a video (audio is stupid quiet, but also irrelevant) that I think I have timed to show how you could rig up a come along to get the job done. You just need to watch a few seconds from where it should start to see what I am talking about.
    https://youtu.be/k3XzkiqanLs?t=138
  15. Jun 21, 2020 at 5:46 PM
    EIRE1916
    I was thinking of using something like the Warn portable electric winch
    there’s the truck bed anchor hooks, and then there’s the Toyota sliding rail hooks the new style ones, which would you suggest? This thing weighs about 200 lbs or so
    I was going to use the portable winch along with some straps and the ramps
  16. Jun 21, 2020 at 7:36 PM
    I would not use the rail system for anything but strapping down a static load. The bed anchors are rated significantly higher, so that would be my choice.
  17. Jun 23, 2020 at 4:18 PM
    iamkeith
    iamkeith New Member
    2001 --> 2018
    Our local game and fish trucks all have winches mounted on a headache rack. The elevated pull angle seems to be helpful when lifting an awkward carcass onto the tailgate. I'll try to take and post a picture next time I see one. They've been setting 'em up this way for so long, I'm inclined to think there must be an off-the-shelf option.
  18. Jun 24, 2020 at 9:11 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Slightly different application but the principle is right...My dad needed less effort to load elk or wood int he back of his truck so we built a truck headache rack that incorporated a winch into the equation...here are some photos of the effort put in...it's VERY strong and usable:
  19. Jun 24, 2020 at 12:42 PM
    HulkSmurf14
    2014 Tundra Limited
    ^^Thank you sir! I did the wiring and my fabricator brother did the welding...came out pretty well! Also functions to move the winch to the rear hitch and is wired in accordingly too...best part is, it works! Ha!
  20. Jun 26, 2020 at 12:18 AM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    Funny I came across this thread. My dad and I are looking to do the same thing with our trucks, he has a Colorado. We do a lot of hunting, usually averaging 4-5 deer each per year. We hunt alone and being able to quickly and easily load a deer into the bed without killing our backs is something we're after. I pulled my back out last year lifting a deer and cart into the back of the truck, missed a few days of work and took weeks to fully recover. Debating on using a hand which somehow hooked over the tailgate to a pulley at the front of the bed vs an electric winch mounted to the front of the bed somewhere
