Switch pros wire thru firewall
Discussion in 'Lighting' started by fisherman951, Jun 18, 2020.
  1. Jun 18, 2020 at 7:45 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    Ok guys so I’m about to finally install this thing that I had for over a month but my last concern is how the hell to get these plugs thru the firewall? I see the nipple under the main harness but I don’t think this would go thru. So how is every one doing this?
  2. Jun 18, 2020 at 7:52 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I used a really long big screw driver and pushed on the side of that rubber boot. You can push it to the side. Pull the wires through and position them at the bottom of the boot and push the boot back on, never had any issues
  3. Jun 18, 2020 at 8:42 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  4. Jun 18, 2020 at 8:50 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    De-pin the white connector, feed them through, re-insert. just make sure you remember which wire goes where ;)
    Berdine likes this.
  5. Jun 18, 2020 at 8:54 PM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Zip tie then wrap in electrical tape, feed zip tie through first then pull like hell. I just did it w my Baja lights
    Berdine and fisherman951[OP] like this.
  6. Jun 18, 2020 at 8:57 PM
    fisherman951
    Tony
    2017 crewmax 4x4
  7. Jun 18, 2020 at 8:58 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Only if I knew how to de pin that thing lol
  8. Jun 18, 2020 at 9:22 PM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Just be careful if you use a screwdriver. I did it on my ‘03 and sparked something in the cab....lost my throttle...thankfully It was just a fuse, but certainly scared the crap out of me when I had no throttle.
  9. Jun 18, 2020 at 9:25 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    lube it up and then...
  10. Jun 18, 2020 at 9:26 PM
    GiantsFanDan
    Yes Sir.
  11. Jun 18, 2020 at 9:32 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Wait I thought I’m supposed to pull lol
  12. Jun 18, 2020 at 9:33 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Darn ok I’ll have to try it. Did u go from the inside out? Or engine side in to cab? Sorry for all these questions just get nervous I don’t wanna mess anything up lol
  13. Jun 18, 2020 at 9:36 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Rookie mistake, they never sing about pulling it real good o_O
    TXMiamiFan and Pudge like this.
  14. Jun 18, 2020 at 9:47 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    :popcorn:
    Pinay likes this.
  15. Jun 19, 2020 at 1:36 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You seem like more of a puller
  16. Jun 19, 2020 at 8:48 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    TXMiamiFan likes this.
  17. Jun 19, 2020 at 8:57 AM
    timsp8
    NY
    It’s in the instructions. Page 3. Even says it’s for putting the wire through tight spaces.
  18. Jun 19, 2020 at 9:14 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Yes but I don’t have a de pin tool and the paper clip they say to use i couldn’t unlock it. So that’s the problem.
  19. Jun 19, 2020 at 9:32 AM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Where are you going to mount the controller?
    fisherman951[OP] likes this.
  20. Jun 19, 2020 at 9:41 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Since mines a 6 seater it’s going up here. Hopefully the wires reach :anonymous:
  21. Jun 19, 2020 at 10:42 AM
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    Please record this so I can learn some new vulgar terms :popcorn:
    Good luck, man!
  22. Jun 19, 2020 at 11:22 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    dittothat[QUOTED] likes this.
  23. Jun 19, 2020 at 11:40 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    A dental pick and small flat micro screwdrivers are what I use often. They always work for me, especially on connectors like the white one.
    Best luck!
  24. Jun 19, 2020 at 11:41 AM
    nishibot
    Perris, CA.
  25. Jun 19, 2020 at 11:47 AM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    1. Get a large firewall grommet
    2. Drill hole in firewall accordingly
    3. Install grommet
    4. Push/pull wires through firewall with ease.
