Keep Tundra running after using remote start?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Javelin, May 19, 2020.
  1. May 19, 2020 at 6:06 AM
    Javelin
    Javelin [OP] New Member
    2021 Limited Cement
    Stock for now...
    Is it possible to keep the truck running after you use remote start with the fob once you open the door with keyless entry or unlock it? Seems kinda redundant that it turns off then I have to start it again. My 2013 raptor allowed for this wondering if there’s an option or something
    thanks!
  2. May 19, 2020 at 6:13 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nope.
    Unfortunately...
  3. May 19, 2020 at 6:56 AM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Mine stays on... but was aftermarket. As long as I don’t touch the brake before turning the key to the on position.
    1lowlife likes this.
  4. May 19, 2020 at 7:01 AM
    RobertD
    Robert
    DFW, Texas
    When I had mine added, I was informed that it's a safety feature. Incase someone jumps in before you get to your car, they can't leave without the keys.
    TTund16, Black Wolf and CH1NO like this.
  5. May 19, 2020 at 7:04 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Theres been a few threads on this over time. The stock remote start kills the ignition as a safety feature. Despite our hatred of it. Aftermarket systems will not do this due to how they're wired. No there is no way of disabling it. At least no one has came up with a way yet...
  6. May 19, 2020 at 7:19 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    This is a Toyota thing. I have had and still have other vehicles with factory remote start that do not do this. My 14 Tundra has an aftermarket remote start by Fortin that does not do this.
  7. May 19, 2020 at 8:18 AM
    Adam New Member
    This is a push button start thing. Not a Toyota thing. My wifes Pilot does that as well. Hes got a 2020 the dirty bastard.
    nasher75 and DeesCrewMax like this.
  8. May 19, 2020 at 8:20 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    No it's a Make/Model thing. My wife has a 2016 accord with push button start and factory remote start and hers doesnt shut off unless you push the brake pedal and try to shift out of park.
    Tundyfundy, 1lowlife and Rbohno like this.
  9. May 19, 2020 at 9:44 AM
    gdiep
    Syracuse, New York
    I have a 2017 Nissan Armada with push button start and factory remote that stays on when you enter the vehicle. I had a 2014 Dodge Durango with push button start and factory remote that stayed on when you enter the vehicle. Push Button Start is not the dependent factor.
    Tundyfundy likes this.
  10. May 19, 2020 at 9:46 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My 2016 SR5 shuts off when you unlock. It's a Toyota thing.
  11. May 19, 2020 at 9:55 AM
    Bronzeback
    Bronzeback New Member
    yup. Toyota factory remote start...not unique to push button start systems.
  12. May 19, 2020 at 10:08 AM
    Javelin
    2021 Limited Cement
    Stock for now...
    Ugh that’s so annoying. Haha
  13. May 19, 2020 at 10:35 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    My wife’s Pilot doesn’t.
  14. May 19, 2020 at 10:43 AM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
  15. May 19, 2020 at 10:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Doesn't bother me enough to spend $200 on something else lol ....yet
  16. May 20, 2020 at 2:44 PM
    Kanobi13
    Kanobi13 New Member
    Aftermarket 12 volt solutions plug and play 15 min install
    Tundyfundy and 1lowlife like this.
  17. May 20, 2020 at 2:53 PM
    Blue Thunder
    Washington
    Toyota soiled the bed on their remote start in a number of ways. First was the use of the app (or required service plan with Toyota to use the FOB) instead of just the FOB to start the truck. Second was the shutoff when the door opens. My F150 kept the doors locked until you arrive with the FOB (such witchcraft! crazy tech...just like Toyota does today with the door lock/unlock sensors) AND didn't let you shift out of park unless the FOB was present.
    Too bad all of it cannot be overridden...
    AggiePhil likes this.
  18. May 20, 2020 at 3:43 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What app/svc plan?
  19. May 20, 2020 at 7:54 PM
    Blue Thunder
    Washington
    Whatever the Toyota app is. And you get a few months free service when you buy the truck. Let’s you start the truck, track maintenance, emergency services, traffic, etc. It also enables the owner to use the FOB for remote start.
  20. May 20, 2020 at 8:04 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have not used an app. I had Toyota Care but it was only good for like 3 oil changes. My truck uses the original fob to remotely start.
  21. May 20, 2020 at 8:33 PM
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    The remote start from the fo has nothing to do with the app. The app does exactly what you said and when the free service runs out you loose only what that service offered.
    Unfortunately it’s a Toyota thing, none of my Rams with push button start did it and neither of my wife’s Honda’s stop like Toyota. Maybe it’s a good thing , my wife had an Accord with one of the first push button starts. Our plan is we go into town in her car I drop her off at the grocery store drive to the meat market and then come back and get her.
    Get in the car and because she had the the fob in her purse the car started no worries, I pull up to the grocery store drop her off. Go down to the meat market and buy our beef, pork etc.. go back out to the car and push the button and nothing happens. NO FRICKIN FOB, wife has it.
    ‘I call her at grocery store and she has to find a stranger that looks friendly to drive her about 5 miles down the road to the meat market.
  22. May 20, 2020 at 11:04 PM
    Blue Thunder
    Washington
    It is different on the 2020’s
    Does your FOB remote start still work for you and your Toyota Care has expired? Because there have been multiple posts here on the forum that talk about this same thing and it only seems to work with people that are either still within their trial period or have expended the coverage.
  23. May 20, 2020 at 11:41 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Is it the "MyCar" app?
  24. May 21, 2020 at 6:06 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    The app is literally just called "Toyota". Red icon with the Toyota logo in it.
    Blue Thunder likes this.
  25. Jun 16, 2020 at 5:37 PM
    cajunworm
    cajunworm New Member
    New York
    I went to a Compustar dealer and they said my 2020 TRD Pro will still shut off if i get a aftermarket too. This sucks ass. How do i just get a key ignition???
  26. Jun 16, 2020 at 10:45 PM
    HERnamesSandy
    HERnamesSandy New Member
    2020 4v6 SR5 Custom built
    Kemper kustom tow cap Cross rifles vinyl sticker
    I have remote start installed from factory and opted out of keyless entry for this reason. I use my actual key And the sequence to remote start on my key. I unlock to get in, stick the key in the ignition and turn it to KOEO (key on engine off) position, since the truck is already been cracked and running. I usually leave the A/C on level 1, or on a hot day on high and the truck stays locked while on. I unlock and jump in and it’s nice. But remember don’t touch the pedal till the key is in the KOEO or it will shut off.
    IlovemyTundra2×@home likes this.
  27. Jun 17, 2020 at 8:16 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    You need a Chevy LOL, my old Chevy 2016 Silverado started and did not DIE when I open the doors via remote start. Though you cant drive off without the key in the On position though :D My Subaru will die (both with push button start), obviously GM (for 2016 at least) doesn't care about safety.
  28. Jun 25, 2020 at 3:52 PM
    2planker
    2planker New Member
    Is yours a SLICE? I've been trying to figure out why mine will sometimes stay on but most times turns off right before I put the key in. I thought it was some weird vodoo $%*t and my truck was just messing with me.
  29. Feb 8, 2022 at 7:19 PM
    IlovemyTundra2×@home New Member
    2014 Trunda
    None
  30. Feb 8, 2022 at 7:30 PM
    2014 Trunda
    None
    Mine had been working fine until today in a store parking lot. I noticed a guy got out of his vehicle and it seemed we pushed our key fob's probably about the same time, him locking his and me trying to unlock my door to put my groceries in. My fob would not work, l had to unlock my door with my key. It worked fine at my next stop.. I'm still wondering why that happened.
