Clicks into 4wd just fine, but after about 10 feet the drive train or axles or something lock up
Discussion in '1st Gen Tundras (2000-2006)' started by arbucklejon1, Jun 10, 2020.
  1. Jun 10, 2020 at 8:32 PM
    arbucklejon1
    arbucklejon1 [OP] New Member
    2001 RC LB
    i put my truck into 4wd and it clicks in just fine, the 4HI lights up on the dash, everything seems fine but after a few seconds something locks up i guess and eventually (while i'm not touching anything) the truck will stop. if i press the gas it'll start jumping forward and squeal the front tires. I thought it might be something wrong with the CV axles, but those are spinning still when in 2wd and nothing gets locked up in 2wd. which makes me think its something wrong in the front diff, but i'm really hoping that's not the case.
    JimboSlice413 likes this.
  2. Jun 10, 2020 at 8:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Don't use 4WD in high traction situations.
    Rex Kramer and EDDO like this.
  3. Jun 10, 2020 at 9:23 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Are you turning when this happens?
    If not, did you just get this truck? Possible mismatched diff gear ratios? Or mismatched tires?
    arbucklejon1[OP] and Jack Burton like this.
  4. Jun 10, 2020 at 9:45 PM
    fighthedude
    fighthedude New Member
    You on concrete or asphalt?
  5. Jun 11, 2020 at 5:07 AM
    bmf4069 Yup, that's car parts in a dishwasher
    Yeah, what they said. Get on some dirt or gravel and try it. And say hi to Garfield for me.
  6. Jun 12, 2020 at 2:18 PM
    arbucklejon1
    2001 RC LB
    SON OF A..... @landphil thank you. i DO have mismatched tires. i put together a bigger set of tires for the truck, but they wont fit up front without spacers so i am waiting on spacers to ship. i already put them on in the back because i needed a load range E tire to tow a dump trailer. so the ones in the rear are 285/70/17, and the front tires are 265/70/16. thats a 2.7" difference in diameter. no wonder it was locking up on me.
    man im an idiot. thank you everybody.
  7. Jun 12, 2020 at 2:19 PM
    arbucklejon1
    2001 RC LB
    here this is the truck:IMG_1819.jpg
    Rex Kramer, landphil and Tundra2 like this.
  8. Jun 12, 2020 at 2:48 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sweet rig.
  9. Jun 12, 2020 at 5:05 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If your ABS is acting weird you can probably figure out why as well. ;)
  10. Jun 12, 2020 at 5:11 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    You gotta love the easy fixes.....
  11. Jun 12, 2020 at 5:23 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    And hate the self-inflicted misery. :rofl:
