What's your latest purchase?
Discussion in 'Marketplace' started by vl184009, Jul 27, 2017.
  1. Jun 4, 2020 at 5:37 PM
    #4741
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
  2. Jun 4, 2020 at 6:19 PM
    #4742
  3. Jun 4, 2020 at 6:43 PM
    #4743
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Nothing fancy here, deck boards. Sure love the roll down back window, snapped a pic before I ratcheted them down.
  4. Jun 4, 2020 at 7:00 PM
    #4744
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    My girlfriend and I bought a house. Pics to come in the next few days. Two car garage which will only fit her car, my Tundra in the driveway. But it's on a private street so we own the street in front of the house.
    Brown Bear, JoshuaA, JMB and 13 others like this.
  5. Jun 4, 2020 at 7:04 PM
    #4745
    Congratulations.
    Wallygator and Baja Mike[QUOTED] like this.
  6. Jun 4, 2020 at 7:20 PM
    #4746
    Slicetruck
    Slicetruck New Member
    Spokane Washington
    2007 Blue RCSB 5.7
    no mods yet...sway bar. Katzkin leather 20" Carved wheels
    My favorite way to burn money.
  7. Jun 4, 2020 at 7:40 PM
    #4747
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    Good to know if wasnt damaged. I watched an hour long video on how they build\ship and pack and I was impressed. How to you like your Diamondback? Any issues or things to watch out for?
    Thanks in advance!
  8. Jun 4, 2020 at 8:06 PM
    #4748
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Heart attacks, interesting....
  9. Jun 4, 2020 at 8:26 PM
    #4749
    Slicetruck
    Spokane Washington
    2007 Blue RCSB 5.7
    Just a little infarto
  10. Jun 4, 2020 at 8:47 PM
    #4750
    TundraGuy66
    TundraGuy66 New Member
    Mat
    2020 Cement Tundra TRD
    I wish the roll down window was an option for my dbl cab!
    TokerJoker and JoshuaA[QUOTED] like this.
  11. Jun 4, 2020 at 9:14 PM
    #4751
    Congratulations
  12. Jun 4, 2020 at 9:41 PM
    #4752
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Love it - after having it from now on it'll either bed a DB cover or no cover at all for me. Only issues I've had are the clamps backing off since they don't have second nuts to lock and the clamps aren't down super tight because of the rubber seals. Had it off for the last 2 weeks because of doing yard work and it comes off in 15 minutes and back on by myself in 15 minutes. If you want to put bed lights in don't put long ones that stick under the tie down rails since the locking pins slide under those to lock. Only thing I'd like them to add would be a u-bolt or something like that under the cover so when I have to crack it to have lumber over the tailgate hanging out I wouldn't have to use the lock to strap the cover down to the cargo.
    Sunnier likes this.
  13. Jun 4, 2020 at 11:05 PM
    #4753
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Bought a new peeping Tom thingy.
    I have my private helicopter license and I swear this thing has more regulations and requirements to fly! Haha
  14. Jun 4, 2020 at 11:20 PM
    #4754
    Wallygator
    So fun.
  15. Jun 5, 2020 at 4:37 AM
    #4755
    Sunnier
    Sunny
    San Diego, CA
    Congratulations, Mike!
    kparrow and Baja Mike[QUOTED] like this.
  16. Jun 5, 2020 at 4:59 AM
    #4756
    Rolodetective
    Rolodetective Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    In for the pics!
  17. Jun 5, 2020 at 7:09 AM
    #4757
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yeah I’m looking forward to finally flying it today. Had to setup and do a bunch of updates and battery charging yesterday when I got it
  18. Jun 5, 2020 at 7:14 AM
    #4758
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Here's how to set up a poor man's transfer switch using the 240V dryer receptacle (all natural gas users are probably out of luck for this method):
    1. Make sure you have a main breaker at the main power panel to your house - If you don't have a main breaker in your panel, STOP. Following the rest of these instructions could kill a utility worker!
    2. Establish a location for your generator that allows for external ventilation of the exhaust
    3. Obtain a cable (minimum 10 gauge, 8 gauge preferred) long enough to reach from your dryer outlet to your generator
    4. Attach a dryer plug that matches your dryer receptacle to one end of the cable
    5. Attach a 30A plug that matches the 240V 30A receptacle on your generator to the other end of the cable
    6. If your dryer receptacle is a 3-prong (older homes), attach a ground wire (12 gauge minimum) to your generator and connect it to something that is well grounded
    7. With the generator off, attach the cable at both ends
    8. CRITICAL: TURN MAIN POWER BREAKER OFF - This protects the electrical crews trying to restore power to your house by preventing backfeed from your generator to the local power grid
    9. Turn off high power breakers (Central A/C, stove/oven, etc.)
    10. Turn all lights in the house off
    11. Make sure the generator switch for the 30A feed is OFF
    12. Crank the generator and let it idle for a few seconds.
    13. Turn the 30A generator switch to ON.
    14. Start using your indoor lights and low power loads, including a small window A/C unit (best to limit to ONE of these), for GREATLY increased comfort during the power outage.
    When you notice other lights in your neighborhood have come back on, turn the generator off, remove the cable, plug your dryer back in, turn all your breakers back on, including the Main.
    I have used this setup to run my freezer during the day, and the A/C at night to help us sleep better.
    NOTE: Depending on your generator, the power provided may damage or decrease the life of some electronic equipment. It is best not to use sensitive electronics any more than necessary with this setup. LED lights may also be damaged by the power output of your generator.
    Hope this helps you Florida guys! I used this setup for a couple of weeks after Katrina when I lived in South Mississippi.
    Sunnier, TomC843 and Wallygator like this.
  19. Jun 5, 2020 at 7:22 AM
    #4759
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
  20. Jun 5, 2020 at 7:29 AM
    #4760
    Bet Jose @COMiamiFan would love that bike.
  21. Jun 5, 2020 at 8:03 AM
    #4761
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Beautiful color combo for sure :fistbump:
    Prostar 190 likes this.
  22. Jun 5, 2020 at 8:16 AM
    #4762
    Yup it's not white! :D
    Sunnier and TXMiamiFan[QUOTED] like this.
  23. Jun 5, 2020 at 11:03 AM
    #4763
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    New to me (ebay) Snap-on IM5100.
  24. Jun 5, 2020 at 11:31 AM
    #4764
    Kung
    KG, VA
    I personally prefer to out my fartos.
    (Sorry, it’s Friday and I haven’t told a dad joke in a good three hours or so. :notsure:)
    BigSkyTaco, Wallygator and JMB like this.
  25. Jun 5, 2020 at 11:48 AM
    #4765
    Kung
    KG, VA
    Excellent post. My mom lost power @ the house a few months after my dad passed away in Jan 2019; and she called a local friend who worked for the electrical department. He about lost his mind when she told him this is what her husband always did.
    What many don't realize is that - SO LONG AS one takes the proper precautions (turning off the main breaker/high power breakers/lights), this will never harm a soul, and is essentially the exact same thing as a transfer switch, except far cheaper.
    In our case, we kinda lucked out, because we built a new extension a few years ago; so our washer/dryer got relocated, leaving a 240V dryer receptacle open for just this use if needed.
  26. Jun 5, 2020 at 12:02 PM
    #4766
    RobertD
    Robert
    DFW, Texas
    Received my console organizer and wireless charger. Need to add something on the sides of the organizer so it doesn't move too easily. It easily slides around when the top is open.20200605_132644.jpg
  27. Jun 5, 2020 at 1:05 PM
    #4767
    DoubleJackOnTap
    DoubleJackOnTap New Member
    SW Washington
    2018 Super White TRD Sport
    CoverKing Neoprene Seat Covers, UltraFlex
    Dont forget to register it. $5 and takes about 5 minutes. Will save you a bunch of headaches if someone reports you. I doubt that would happen in Idaho, but you never know anymore.
    CodyP[QUOTED] likes this.
  28. Jun 5, 2020 at 1:15 PM
    #4768
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Did it last night. Was pretty painless. I’m about 7-8 miles from a little airport so I wouldn’t be surprised if someone reported me regardless
  29. Jun 5, 2020 at 3:16 PM
    #4769
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Oh lord, I will never try to explain this to anyone on the internet ever again. Got sceamed at on another forum years ago by wire pullers that have no clue. I had a "general contractor" tell me that I should not send power down lines that have always had power flowing the other way. After standing up for my self and showing I understand and Troubleshot Complicated elec issues every day and there no problem feeding my panel from a side breaker he says that someone else in the house could turn on the main. I know in my house that is not even a possibility cause the wife is scared to death of the Breakers but I just quit responding.
    Kung, Wallygator and BLONGTX like this.
  30. Jun 5, 2020 at 3:58 PM
    #4770
    Cody,
    I would recommend joining the DJI forum. I have a Mavic Pro and haven't flown it in months. The DJI Go app had some software issues so alot of us went back to older versions until the can figure it out. I haven't been on the forum in a while to follow up on it, but just wanted to put that bug in your ear in case you have any issues. We had issues like garbled video on the display once you got about 150 feet away.
