So who's lowered their Gen 2 Tundra's?
Discussion in 'Canada' started by YYCDCLTD, Jun 4, 2020.
  1. Jun 4, 2020 at 8:19 AM
    YYCDCLTD
    YYCDCLTD [OP] New Member
    '07 DC LTD Tundra
    I bought the '07 DC 4x4 Tundra to do some hauling as well as carrying loads that wouldn't fit in a station wagon or minivan.
    So far, I like the space of the Tundra, but I can't stand the handling and ride characteristics (I come from a background of modified Subarus, and used to complete in several different motorsports).
    I'm looking at lowering the Tundra by changing out the control arms (changing out the mounting point of the shock/spring combo) and doing a flip kit and Firestone airbags in the back. I will be upgrading the shocks to Bilsteins or Eibachs or perhaps a more performance-oriented shock. Going to also swap out the current AT's for more of a high-way oriented tire and hopefully find a set of much lighter wheels than the factory 20" alloys.
    Considering -> https://djmsuspension.com/product/djm2808-35/ or
    https://sosperformance.com/products/lowering-kit-fits-2007-16-tundra
    Just curious what are other fellow Canadians doing to lower their Tundra (if you're lowering them at all).
  2. Jun 4, 2020 at 8:27 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    :popcorn:
    I might be interested in lowering my truck just so it's easier to scrape the windshield in winter.
  3. Jun 4, 2020 at 9:50 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    pfft. you're a canuck. solve it like a canuck.
  4. Jun 4, 2020 at 9:58 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I lowered my 2012 Crewmax with the TRD lowering kit
    Cpl_Punishment likes this.
  5. Jun 4, 2020 at 10:01 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I lowered the rear of my 2007 3.25" using the full kit from SOS performance... I left the front end stock, so the truck sits level and I didn't give up any ground clearance. Ride and handling are greatly improved, and I get sport truck firmness & handling when I run my 285/60-18 Summer performance tires.
    Cruiserpilot likes this.
  6. Jun 4, 2020 at 10:05 AM
    YYCDCLTD
    '07 DC LTD Tundra
    RitcheyRch - how much does the TRD kit lower by? Is it similar to the DJM where the fronts replace the control arm?
  7. Jun 4, 2020 at 10:34 AM
    Rex Kramer
    Georgia
    SOS Performance flip kit, Firestone airbags, TRD anti-roll bar with short end links and Bilstein 4600 shocks that are 3.25" shorter than stock. You will need to shorten your tail pipe by cutting it right after the last hanger.
  8. Jun 4, 2020 at 10:48 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
    The TRD kit lowers it 2" in front and 4" in the rear. The front kit consists of new springs, struts and bump stops. The TRD kit does not change the control arms. I also believe the TRD kit will not work on a 4 wheel drive.
  9. Jun 4, 2020 at 10:55 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is there a kit that will lower it but keep the rake?
  10. Jun 4, 2020 at 11:03 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
    I'm not sure. Can check the Toyota TRD website.
  11. Jun 5, 2020 at 4:27 PM
    YYCDCLTD
    '07 DC LTD Tundra
    Rex Kramer - is your's a 4x4 Tundra or the 4x2? I'm guessing with the SOS flip kit, it was not enough space for the rear section of the tailpipe? Would you happen to have a picture of the airbags from the opposite side? Just trying to determine the relative orientation compared to the axle with the flip kit installed. Was your rear swaybar installed before or after the lowering in the back? What did you use for the front to lower? What was the part number on those Bilstein 4600's? Thanks!
    Cpl_Punishment - I believe if you want to keep the slight rake, you would just lower the rears less than any lowering in the front. I'm going to be doing the control arms in the front to get the 3" lowering. I want the truck to be totally flat/level, so I believe it needs a 5" lowering in the rear.
  12. Jun 5, 2020 at 5:55 PM
    Rex Kramer
    Georgia
    4X2... when the leaf pack is hung below the axle it block the tailpipes original path. The sway bar was installed with the flip kit, and the front suspension is all stock - I didn't lower the front. Check out my rescue thread, the part# for the shocks is on page #3 I think. Here are the pictures you requested.
  13. Jun 5, 2020 at 8:14 PM
    YYCDCLTD
    '07 DC LTD Tundra
    Rex Kramer - thanks! Which Firestone airbag kit did you use? Per the kit for the Tundra's the lower bracket for the airbag is supposed to sit on the cut bump stop isn't it?
  14. Jun 6, 2020 at 4:22 AM
    Rex Kramer
    Georgia
    It the kit SOS Performance sells, the brackets are made specifically for the lowered Tundra.
  15. Jun 6, 2020 at 4:32 PM
    YYCDCLTD
    '07 DC LTD Tundra
  16. Jun 24, 2024 at 8:49 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    If anyone reads this 4 yrs later. I installed identical kit as Rex Kramer did on my '07 2WD SR5 RCLB. I cut the
    exhaust right at the racket and used fab skills to reconnect and exit as factory, Not a big deal.
    Rex Kramer is right, it handles like a car. Really nice and stable. I can haul 2 yds easy of wet mulch - 2000 lbs with
    35 lbs of air in the bags.
    Since that was 3 yrs ago I've got a 2010 RCSB and I will be installing the identical kits. As Rex said, no loss of
    ground clearance but in winter I expect to have far better slick road handling and flat ride. worth every penny.
    SOS Lowering kit and SOS airbag kit. Easy 1/2 day job for anyone with tools.
  17. Dec 9, 2024 at 11:31 AM
    Hawk373
    Hawk373 New Member
    2020 Tundra SR5 Cavalry Blue
    SOS 2.5/4.5” lowered (pending 3UR-FZE)
    Curious if you tacked in a union or just cut and rotated/pointed to a new position. I’m only going to have very light contact fully extended.
  18. Dec 9, 2024 at 1:53 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I cut it right at the welded piece that has the rubber hanger pin attached. So I ground the weld, cut the pipe and rotated it
    after cutting out a section. I might have saved a pic of that from below on my ipad. I'll look and if I find it I'll post it up.
    It would be nice if it didn't touch in a factory form, but close might work for you. It also might rattle on occasion, there is
    a fair amount of movement on yours but try it. Nicer to not have to cut and weld!
    Hawk373[QUOTED] likes this.
  19. Dec 9, 2024 at 2:52 PM
    Hawk373
    Hawk373 New Member
    Much appreciated.
    Yeah, I found some 2.75” just incase I have to splice in a little. Might try bending the hangar down a bit, but concerned about rear end clearance at full compression as well.
    My shackles are set at the highest hole (lowest setting) and the Dirty Deeds may have pushed the tail pipe into a slightly better position which may account for the decent amount of clearance I have.
    Also waiting to see if the shorter shocks limit some down travel. They’re still enroute.
  20. Dec 9, 2024 at 4:03 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I don't recall the travel of the shorter shocks. You have Bilsteins enroute? They are far stiffer than the factory shocks.
    The dirty deeds tailpipe I'm not familiar with. I have a new stock muffler enroute too, and will keep stock pipes. I like quiet.
    I'm sitting here being lazy, I should get to that. When I do I'll put up pics.
    I did a thread called Pound Puppy you can search for. It has all the pics of the full process.
    Hawk373 likes this.
  21. Dec 9, 2024 at 4:20 PM
    Hawk373
    Hawk373 New Member
    Yeah the 4600 24-024782 F-150 shocks. Calvert makes some adjustable twin tube I may end up trying if I don’t like these, but I assume they’ll be fine.
    The dirty deeds just sounds good, not loud at all, very mellow. Just lets you know your driving a V8. The system retains the stock tail pipe.
  22. Apr 28, 2025 at 5:42 PM
    Hawk373
    Hawk373 New Member
    Thanks for all the clues that got me to this point guys.
