Plugging in 2018+ LED Headlights w/o harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by shhernandez74, May 31, 2020.
  1. May 31, 2020 at 11:02 PM
    shhernandez74
    shhernandez74 [OP] New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Someone gave me one of these headlights for free. Before I order the other one and the harness I wanted to make sure this one works. I have a 2017 SR5, if I were to directly plug this headlight in what would happen? Would it just not turn on or? I plan on getting the harness from @iHacker but I want to make sure this headlight works first. upload_2020-6-1_1-1-44.jpg
  2. Jun 1, 2020 at 2:00 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    As long its not broken, it should work with the correct iHacker harness.
    They're not plug and play with the stock harness, you will need to get the conversion harness to test it.
  3. Jun 1, 2020 at 6:12 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    You actually just need the adapters not the entire conversion harness like the older trucks without the LED DRLs.
