I just want my stance and wheels right!!!
Discussion in 'Wheels & Tires' started by Hannabl, Feb 9, 2017.
  1. Feb 9, 2017 at 9:55 AM
    Hannabl
    Hannabl [OP] New Member
    Apollo Beach FL
    2015 Toyota Tundra XSPX CrewMax
    Optima yellow top, K&N complete cold air intake, ANZO USA full light package(headlights,tail lights, 3rd brake light, Light bar) Gibson full stainles cat back exhaust, Bak flip G4 bed cover, Taco tunes 12" sub box w/kicker sub and Mono block D Soundstream amp, Lumar 15% window tint, PowerStop Big brake upgrade all four corners, ..... Very soon 3/1 Toytec Boss lift
    I have a 2015 crew max and am putting on a 3/1 Toytec lift. I want to run at least a 20x10 rim with 33 tires the offset is -25 on the set im looking at. I would love the tire to poke out a little from my fender flairs. Do i need to run a spacer if so what size and how much massaging of the wheel well is there?
  2. Feb 9, 2017 at 9:57 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    +25 or -25? -25 is way out there
    15whtrd and Backslider like this.
  3. Feb 9, 2017 at 10:00 AM
    Hannabl
    Apollo Beach FL
    You think -25 will poke them out to much? Like I said i am running flairs.
  4. Feb 9, 2017 at 10:10 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here's +25. -25 will be 2 inches out further. Unless you want them way past your flares, I'd stick to 0 offset at most.
  5. Feb 9, 2017 at 10:13 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here's Emily's -12, it would be another half inch out from this.
    Hannabl[OP] likes this.
  6. Feb 9, 2017 at 10:18 AM
    Hannabl
    Apollo Beach FL
    -12 Looks like the way to go. Did you guys get much rub?
  7. Feb 9, 2017 at 10:22 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I have bigger tires but much less offset. I have no idea on -12's, but atleast you're only going to run 33's. And Emily has bigger tires too, but she has a 6" lift.
    GNTundra and Hannabl[OP] like this.
  8. Feb 9, 2017 at 10:32 AM
    Hannabl
    Apollo Beach FL
    Do you remember how wide of a wheel your running?
  9. Feb 9, 2017 at 10:44 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I'm running +12 and it sticks out past the fender the perfect amount in my opinion
  10. Feb 9, 2017 at 10:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Mines an 18x9 295/70. The further your wheels go out, the more rubbing issues you'll have.
    GNTundra and Hannabl[QUOTED][OP] like this.
  11. Feb 9, 2017 at 10:51 AM
    Hannabl
    Apollo Beach FL
    The only reason i was looking at a 10" wide wheel was because with a lift i didn't want the tires to look to narrow. With that said joonbug yours looks killer.
    joonbug likes this.
  12. Feb 9, 2017 at 10:56 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Here's my +18 mounted on 295s.
  13. Feb 9, 2017 at 11:17 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Toytec boss with +18 on wheels. Running 35x12.5x18. I don't think tires look too narrow. But for you they might. But here is a pic of mine with a different angle so you can check it out.
    Hannabl[OP] and zcarpenter92 like this.
  14. Feb 9, 2017 at 11:58 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    Stock offset, stuffed 35 12.5's.
  15. Feb 9, 2017 at 12:07 PM
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    0 offset/ 33's/ wheel 18x9's
  16. Feb 9, 2017 at 12:39 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  17. Feb 9, 2017 at 1:00 PM
    Hannabl
    Apollo Beach FL
    How much wheel well/ rear bumper plastic is anyone shaving?
  18. Feb 9, 2017 at 1:56 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I am running a Toytec 3/1 level with 20"×9" wheels +20 offset and 34" tires. Just my opinion, but I think if your going with 10" wheels a +0 to -12 offset would work perfectly with flares.
    Hannabl[OP] and GNTundra like this.
  19. Feb 9, 2017 at 2:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Most have to remove the mudflap and trim a little off the front liner and push forward and drill a new hole. Just need to trim a little off the bottom of the liner where it juts out.
  20. Jan 27, 2020 at 7:29 AM
    Toshito
    Toshito New Member
    2017 Red Tundra Limited
    About how much is it sticking out as is?
  21. Jan 27, 2020 at 7:35 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    295s and 0 offset
  22. Jan 27, 2020 at 7:36 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    This is +25 with 18x9 305/65-18s.. As mentioned above, -25 will be way out there.
    J&ATundra and drobb like this.
  23. Jan 27, 2020 at 7:30 PM
    salmonfacesalad
    salmonfacesalad New Member
    FAD5C4D3-C60E-473C-9A53-986FFBBA1FD8.jpg 91C1F407-5173-4ECC-9247-C90B24805E76.jpg 0 offset
    J&ATundra and TXMiamiFan like this.
