2018 CM u-joint
Discussion in '2.5 Gen Tundras (2014-2021)' started by cologw7, May 27, 2020.
  1. May 27, 2020 at 12:15 PM
    cologw7
    cologw7 [OP] New Member
    2018 limited CM cement
    Spray in liner, tow mirror, color match front end caps
    I have a 2018 CM I bought off the lot brand new. it has 16000 miles on it. I was feeling a vibration, and brought it in to see what the issue was. I was told it was a ujoint and they had to order parts. ( I question why a u joint would go out in 16k) now I'm setting here and they tell me that there are after market parts (clips, and ujoint), and have to send everything off. Also they are bring up that it might not be covered since they are after market parts. Can anyone help me out with this. the truck is pretty much stock, new rims about it. I did crawl under last night and took picks of the joint. Thanks for any Help. I have a call into the sales rep where I bought it
  2. May 27, 2020 at 3:22 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    That looks like an OEM part (but made by spicer). You can see the paint on the bearing cups. If they claim it's aftermarket then crawl under another tundra and look for yourself for the spicer marks.
  3. May 27, 2020 at 3:35 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    I just looked under my 2020 purchased new by me last Nov.
    Tundyfundy likes this.
  4. May 27, 2020 at 3:50 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Look identical to what’s on my 11 and still original at 222k. Sounds like they’re trying to give you the shaft
  5. May 27, 2020 at 4:06 PM
    TTund16
    TTund16 New Member
    If you bought it brand new and haven't changed anything except upgrading the rims, how can it have after market u-joints?
    Repeat it very slowly to them:
    I bought it brand new and only changed the rims.
    unless the rim size can impact the funtionality. Does it? It can impact cv joints but not the u-joints as far as I know.
    Also maintenance (lube) could come into question. But being an '18 is unlikely. I recall seeing something with my truck to bring it back in 6 months to lube or check the lube ...
  6. May 27, 2020 at 10:35 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Rims wouldn't affect the u joint. I'm assuming he went no larger then 20" which is a size Toyota offers stock I thought so no argument there. OP dealer has to prove the MOD caused the failure, which they cant. Go back in there and give them hell.
  7. May 28, 2020 at 4:02 AM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Do you have a lift?
  8. May 28, 2020 at 5:37 AM
    blanchard7684
    blanchard7684 New Member
    Spicer makes the whole driveshaft assembly, yokes, and u joints.
  9. May 28, 2020 at 6:10 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    I see what you did there. I like it.
  10. May 28, 2020 at 10:35 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    I've heard stories on Tacomaworld of the dealer just swapping the driveshaft and not the faulty u-joint. Something about throwing off the balance of the 2-piece unit if it's not assembled the same or rebalanced after rebuild. $$$. But claiming the OEM driveshaft is aftermarket... that's a new one.
    I finally found the page I was looking for so I'll leave it here for reference in case someone else out of warranty wants it. Here's Dana Spicer's data page for my 4WD rear shaft. You type in the model# printed on the sticker that's by your pinion u-joint to get any part number you need. Looks if it's the non-greaseable u-joint it's the 5-1350X; if it's greaseable, 5-1350-1X. How fancy, they're identical in size so you can swap if ya want.
    TTund16 likes this.
  11. May 29, 2020 at 2:58 PM
    cologw7
    Thanks for the help. They replaced it, and it was under warranty. Vibration is gone. makes me think it has been bad for some time.
