Icon
Discussion in 'Suspension' started by Part_time, May 27, 2020.
  1. May 27, 2020 at 8:34 AM
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
  2. May 27, 2020 at 12:42 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    6 inch pro comp lift, no spacers or blocks, OME rear springs with coachbuilder shackles, ICON UCA's with ICON coil overs, highly recommend the coachbuilder tie rod ends to re gain turning radius and good alignment
  3. May 27, 2020 at 12:48 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    They're the exact same process as any shock.
    LKTundra likes this.
  4. May 28, 2020 at 12:39 AM
    Part_time
    Oregon
    Nice rig what stage is that?
  5. May 28, 2020 at 4:56 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    Stage 4
  6. May 28, 2020 at 5:45 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I have the Pro Comp Stage 1, I plan to do the same thing. How's the ride and stuff? I want to get rid of my rear blocks too. Looks good
    What's the part # on the shocks, I haven't seen the resi fronts listed for the Pro Comp?
  7. May 28, 2020 at 6:46 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Nice looking ride
    beaver6713[QUOTED] likes this.
  8. May 28, 2020 at 8:45 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    I got the pro comp stage 1 lift for a reason, it was the cheapest of the pro comps line, I wanted it that way because I was and did eventually upgrade the front and rear shocks to ICON's. I would not personally use any pro comp shocks or coil overs, I am a huge ICON fan. Also, getting rid of the rear blocks and using the coach builder shackles improved the ride 100 times over (I used OME springs) Night and day difference. The bump stops I added just for looks. I am in Arizona so I got all my stuff thru www.state48overland.com. The coch builder tie rod ends are highly recommended, you will get rid of that screeching sound your tires make when you are turning in a parking lot and will also re gain 30% of your lost turning radius. I was skeptical when they told me that but I went for it and they was 100% correct.
    TXTundra2722 likes this.
  9. May 28, 2020 at 9:39 AM
    November Sun
    Huntsville, Alabama
    Good to know about the CB Steering Arms, my truck does screech a lot, I'm thinking a custom Deaver leaf pack for mine, my truck squats something awful with the slightest amount of weight in the back. Do you have alignment issues with the Pro Comp? My truck's alignment specs are right on for factory and still pulls to the right, is there any specific alignment specs for the lift that you know of?
  10. May 28, 2020 at 9:58 PM
    Part_time
    Oregon
    I am probably going to purchase the Icon stage one coil overs and get the 3” lift. Then build up from there.
  11. May 29, 2020 at 10:55 AM
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    My stage 1 just came in. Shop will install next Weds. I'll update after it is on.
  12. May 30, 2020 at 10:35 AM
    Part_time
    Oregon
    Would like to see, where Did you order from?
  13. May 30, 2020 at 10:50 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    My truck currently has the Stage 1.. Icon 2.0 coilovers and 2.0 rear both non reservoir with a 1” block in the rear.
    I’ll also be selling this set up and a bunch of other goodies I have been collecting soon: Camburg Uni ball UCAs (in need of a rebuild), Toytec adjustable shackles with new poly bushings, and a Deaver mini pack.. not sure if used stuff interests you...
    EDIT:
    Also will be selling some reservoir Fox 2.0 rear shocks.. they are off the truck and ready to go
  14. May 30, 2020 at 6:36 PM
    DUKFVR
    DUKFVR New Member
    Ordered it through my local shop in Houston Tx.
  15. Jun 5, 2020 at 6:05 AM
    DUKFVR
    DUKFVR New Member
    I had the Icon stage one installed Weds. Haven't driven the truck much yet, but no doubt it is much more controlled feeling. It definitely takes speed bumps RR tracks etc much better. I will have the truck at the ranch this weekend,so will get a good feeling for it. I have the same setup on my 2006 Taco & it is & has been great.
    TX_Battlewagon likes this.
  16. Jul 7, 2020 at 1:47 AM
    celicacy
    celicacy New Member
    Cy
    Jacksonville, FL
    2014 Tundra Crewmax
    Icon 2.5 Coilovers, Icon UCA, Katzkin Leather, LED Headlight, Nitto Ridge Grappler 305/55/20, Fuel Wheels, Trd Rear Sway bar
    Do you have any pics?
  17. Jul 7, 2020 at 6:50 AM
    DUKFVR
    DUKFVR New Member
    celicacy likes this.
  18. Jul 7, 2020 at 6:52 AM
    DUKFVR
    DUKFVR New Member
  19. Jul 7, 2020 at 7:46 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    My tire rod ends or at the bottom yours are at the top is there any difference is there a right or wrong way
  20. Jul 7, 2020 at 12:10 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    Not real sure. Had mine installed by a custom shop, alignment is perfect so all is good. I am on a pro comp 6 inch lift front spindles if that makes a difference. I do know the factory ends was on top.
  21. Jul 7, 2020 at 12:26 PM
    Jrozzler
    Jrozzler New Member
    Jonathan
    Super White 2020 platinum tundra
    Nothing yet .
    I installed front and rear stage 3 icons on my Tacoma. I know it’s completely different than the tundra but you should know that icons are a digressive piston shock meaning the ride will be more harsh on small stuff and will get more cushiony on larger stuff. So on normal roads it will feel harsher than say Kings or fox shocks which are linear pistons. Those give the most consistent feel across all surfaces.
    all that being said I still loved my icons and thought they were great all around.
    matt kruckenberg likes this.
  22. Jul 7, 2020 at 1:43 PM
    matt kruckenberg
    slc ut
    Thanks for your input
  23. Dec 14, 2020 at 9:54 AM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    Did you see a loss in heigh with that front bumper? I'm about to get a Icon Stage 9 installed and worried I'm going to lose height with a DV8 front bumper. Thanks!
  24. Dec 15, 2020 at 7:33 AM
    Part_time
    Oregon
    Icon stage 1 2.5 front 2.0 rear
    RRR1C0 likes this.
  25. Mar 1, 2021 at 4:41 PM
    Trabs00
    Trabs00 Lifetime Social Distancer
    Travis
    Seattle, WA
    2012 Black Tundra CM
    7" BDS lift King 3.0 Performance series with RR and adjusters 37" Yoko Geo MT Front bumper Demello Offroad Rear Bumper Expedition 1 ATC canopy AMP power steps Alu-cab RTT Alu-cab shadow awning Alu-cab shower cube
    I also have the Icon Stage 4 like Beaver but with a BDS lift.
    Question, what are folks using for bump stops in their rear? I am about to add custom Alcan leaf springs and want to add bump stops at the same time.
    Beaver mentioned he added the Icon hydraulic bumps... for looks. I was wondering if anyone else has run these +/- other aftermarket leaf mounted bump stops?
    Icon said they should work if I play with the size of leaf-mounted Bumps by playing with suspension cycle
    The Icon hydraulic bumps are pricey ($750) so if they are only for looks I do not want to drop that kind of cash.
    I had air bags on until now so I have no more factory bumps, looking to add something to work with my shocks (travel of shocks is matched to lift on the truck)
    Would love to hear what other 6-7" lifted trucks are handling rear bumps.
  26. Mar 4, 2021 at 1:11 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  27. Mar 4, 2021 at 2:30 PM
    timsp8
    NY
  28. Mar 4, 2021 at 2:46 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    If you take a look at your leaf springs the bolts hand down towards the ground. By flipping it you they are no longer exposed to damage. Before I got the flip kit my U-bolts looked like crooked fingers because I dragged them over rocks. They had to be cut off.
    timsp8[QUOTED] likes this.
  29. Mar 4, 2021 at 2:50 PM
    timsp8
    NY
    Thanks. That makes sense. Every time I read about flip kits it seemed like it was to flip the leafs to lower the truck.
