3/2 Lift Tires?
Discussion in 'Wheels & Tires' started by Lupeflores09, May 18, 2020.
  1. May 18, 2020 at 3:48 AM
    Lupeflores09
    Lupeflores09 [OP] New Member
    Lupe
    3/2 Leveling Kit
    I'm newbie here. Tried searching and couldn't really understand a straight answer.
    I have a 2017 Tundra Crew Cab SR5. I got a 3/2 leveling kit installed. I have 285/55/R20 tires now. I want to get bigger tires. How big of tires can I go? Please explain if I have to mod any and if someone has same setup with pics so I can see if I'd rather get a bigger lift first.
  2. May 18, 2020 at 4:35 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    there is so much info about this on this site. do a little searching and you can find out how to fit larger tires. with a 3 inch lift, you can fit 35 inch tires, but (depending on your wheel offset) there will be various amounts of trimming and modifications that you will have to do.
  3. May 18, 2020 at 6:57 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    This is an ‘18 TRD Sport I once owned. These are pics with it having 295/60r18(33.9x11.6) Kanati Mud Hogs installed with Bilsteins set on top setting(2.28” lift) in the front. All I had to do was bend the skid plate a little. Hope this helps. FCBD7CAF-42FF-4AE6-B298-6E964FAADFD5.jpg2591F2BB-F3C0-4270-A99E-7D6E6ACAB34B.jpg FAA89696-4C9F-4BC8-BA51-CA5CF1653362.jpg
  4. May 18, 2020 at 10:01 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    34’s or 35’s...
  5. May 26, 2020 at 12:19 PM
    smalls_ADV78
    smalls_ADV78 New Member
    I have a 3/2 lift with 285/65/20 running a 1.25 spacer using OEM Vision +50 wheels from the XSP package. So this brings it to +18. Zero issues after I removed mud flaps and took a heat gun to the front inner lining.
