Leveling kits on with the suspension lift?
Discussion in 'Suspension' started by therol03, Feb 3, 2015.
  1. Feb 3, 2015 at 8:59 PM
    therol03
    therol03 [OP] New Member
    roland
    black 2014 toyota tundra sr5 tss offroad
    3 inch level in the front 1 inch rear
    Whats going on guys, I am going to be getting a 6inch suspension lift on my tundra next week, I have seen a couple of pics where they are leaving there leveling kits on with the suspension lift, do any of you know about that and what would be the drawback? I would think the alignment. What do you think
  2. Feb 3, 2015 at 9:51 PM
    Welcome! Our resident expert, @csuviper will chime in shortly, I'm sure.
    However, what is the purpose of leaving the leveling kit with a full blown suspension lift? I would think suspension + shackles would be a better (safer) option..
  3. Feb 3, 2015 at 10:43 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Welcome
    Yes alignment, as well as accelerated wear on some components such as the CVs and ball joints do to over extension on suspension droop.
    If you go for an adjustable "stage 2" lift that includes preload adjustable coilovers then you wouldn't even need to use a leveling kit in conjunction to gain additional ride height in the front and then for the rear you could add some lift shackles as Sean mentioned. I would recommend staying away from lift blocks greater than 2" in the rear and using a combination of shackles or AALs to get the desired height back there
    T-Rex266 likes this.
  4. Feb 4, 2015 at 10:40 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    ^ Agree with Relentless.
    6" Lift kits come with either a spacer for the existing front struts:
    or you can upgrade and get the coilovers for added front adjustment
    These kits are designed for 6" lift and get close to factory alignment.
    Adding spacers on top of spacers is highly not recommended as it is dangerous and increases the chance of additional wear, alignment issues and blown shocks.
    New upper control arms are recommended if alignment is not to factory specs.
    For the rear, they typically come with blocks and add-a-leafs to keep the blocks under 2". As relentless said, keep the blocks under 2", you wont be happy with larger and larger is dangerous.
    FunkinTundra and scratchex like this.
  5. Feb 4, 2015 at 10:46 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i did 3" level and 3.5" spindle lift with blocks in the back
  6. Feb 4, 2015 at 3:03 PM
    therol03
    roland
    Thanks for the feedback, I am purchasing the rough country 6" suspension lift with 35 nitto grapplers, I just ran into some pics and saw that they were doing this. Didnt know the purpose...Thanks guys
  7. Mar 3, 2015 at 7:21 AM
    mako20
    mako20 New Member
    karl
    tundra crew 4x4
    Im new to this site. I will be doing basically the same. Would like to see pics when you get setup. Thanks.
