  1. May 22, 2020 at 10:43 AM
    #2581
    Professional Hand Model
    Fred
    Hand Protectors
    I’d love to be surprised like that! Stealer Manager stood his ground on all NAPA parts and the axle are most likely the problem. NAPA says their parts are made to spec and never have returns.
    TX-TRD1stGEN likes this.
  2. May 22, 2020 at 10:51 AM
    #2582
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    What parts were Napa? I don’t think the retainer is even available aftermarket. A lot of places try reusing it. Which sometimes works, most
    Of the time ends in leaks
  3. May 22, 2020 at 12:18 PM
    #2583
    Fred
    Hand Protectors
  4. May 22, 2020 at 12:20 PM
    #2584
    empty_lord
    05 rollover special
    Huh. Interesting
  5. May 22, 2020 at 12:29 PM
    #2585
    Fred
    Hand Protectors
    New info for ya?
  6. May 22, 2020 at 12:40 PM
    #2586
    empty_lord
    05 rollover special
    Yup. I bought a new one axle when I replaced my bent one.
    $500 later I had new axle, backing plate, bearing... everything
  7. May 22, 2020 at 2:46 PM
    #2587
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    @empty_lord thinking about changing my pcv valve, the thingy thing in the middle of it still rattles around and moves up and down.. would it be pointless to replace it then?
  8. May 22, 2020 at 3:41 PM
    #2588
    @Professional Hand Model is a PCV expert, nay, MASTER, and can answer any questions you have.
  9. May 22, 2020 at 3:49 PM
    #2589
    Fred
    Hand Protectors
    Nah. The the master is @FirstGenVol. He has a sticky about PCV, but not a sticky PCV. Read up as he is the Champ.
  10. May 22, 2020 at 5:57 PM
    #2590
    Pucks18
    How do i find that sticky? Lmao my b
  11. May 22, 2020 at 5:58 PM
    #2591
    empty_lord
    05 rollover special
    If it’s still moving it’s technically working. But it could be clogged up but not seized too. Really up to you, they’re cheap enough I replaced mine when I did the t belt
  12. May 22, 2020 at 5:59 PM
    #2592
    empty_lord
    05 rollover special
    Now this is a proper garage. 2 1/3 Toyota trucks!
    (my 01 taco is apparently a shelf these days)[​IMG]
  13. May 22, 2020 at 7:19 PM
    #2593
    When are we going to get the full story on these? Why do you have just a frame? You keep teasing us with a random pic for a year now.
  14. May 22, 2020 at 8:14 PM
    #2594
    This area needs some TLC. Maybe something like Ospho followed by white spray paint?
    NUDRAT[OP] and Darkness like this.
  15. May 22, 2020 at 8:19 PM
    #2595
    empty_lord
    05 rollover special
    The company i got my interior paint from sells toyota matched paint i was going to use for under the hood areas where i still have phantom grey
  16. May 22, 2020 at 8:23 PM
    #2596
    empty_lord
    05 rollover special
    that frame is for the green 2001 tacoma i have. my first vehicle. I bought the frame new 2 years ago. was going to get it done last year, but a tundra happened. right now im getting the spare engine cleaned up and re sealed (and the trans too) to put in the 01 which is currently on its other frame (i repaired damage caused by the idiot that installed the frame in 2012.. the reason i bought a new frame was because of multiple issues with the one he managed to mangle.)
    goal is to have the new frame for the 01 full assembled, with engine, trans, exhaust, suspension ETC, Just wait for the body to be married to it. Its driving into the body shop to get FULL body work (im talking underneath, under hood, rust repair, ETC) and it'll be leaving on a new chassis with a BUILT 3.4l supercharged, a Built a340F, Whole new suspension, cleaned up diffs and 4 wheel Disk brakes. The old frames then going to wait for a new body and bed to build into an offroad toy.. It'll be ready to run with the power train im putting in it. i have the whole engine harness and ECU from a 97 4runner to make the other frame a plug and play setup for w/e i can find body wise
  17. May 22, 2020 at 11:02 PM
    #2597
    empty_lord
    05 rollover special
    Got the head off the 97 4runner engine. At 252k she’s got some sludge, but internal wise the motor looks really healthy. So passenger side head will be in the parts washer to get as clean as I can get it, then stripped to replace all the valve seals. Camry cams will go in and I’ll set clearance all set. May even put shingles buckets in for less valve train mass
    [​IMG][​IMG][​IMG]
  18. May 23, 2020 at 5:29 AM
    #2598
    Fred
    Hand Protectors
    No on the Ospho due to there already been a sound paint job. Ospho ruins already painted surfaces. I’d clean up the rust dust with a rag. Sand the general area and wipe it again. Spray the black rusty metal primer and then spray a few coats of Bedliner (or your white match rattle can) over those.
    I used the Bedliner Black when I did this area and it looks good. I put a few layers of Butyl Liner on the frame, backside of the battery tray, and top side of tray before install battery for vibration resistance and padding.
    bmf4069 and FirstGenVol[QUOTED] like this.
  19. May 23, 2020 at 6:29 AM
    #2599
    Wow. 252k and you can still see the bore hash marks (I think that's what they're called). Its funny how old school SBC people will get ahold of these trucks or the 3.0 yamaha in the SHO and ask about full rebuilds, including boring and oversized bearings to turn the crank, just to realize how well built Japanese engines really are.
  20. May 23, 2020 at 6:56 AM
    #2600
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Michelin makes the Defender LTX in that size. Not the most impressive looking tire but gets great traction and wears like iron. Discount Tire is running some rebates right now.
  21. May 23, 2020 at 7:07 AM
    #2601
    Fred
    Hand Protectors
    That is a great tire, but @FirstGenVol had a bad experience as a child with this tire company and he doesn’t like them. The Michelin Man Image has messed him up after watching Barney all those years. Everyone else, including myself, love this brand. :D
  22. May 23, 2020 at 7:44 AM
    #2602
    When I buy a 70-80K mile top dollar tire I expect them to last longer than 40K. :notsure: Right now the tires on it are the Defender T+H with an 80K mile warranty. They are starting to dry rot at 40K miles, with 5/32".
    In fairness, I know the Defender LTX is supposed to be a great tire. I might consider it for her car. I just like the way all terrain tires look on SUV's and trucks.
  23. May 23, 2020 at 8:20 AM
    #2603
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    jpink, bmf4069 and NUDRAT[OP] like this.
  24. May 23, 2020 at 8:24 AM
    #2604
    @Darkness since you waxed your truck I will consider it. Paint Nazi is ashamed of this area under battery. It took a lot of courage for me to post that.
    bmf4069 and Darkness like this.
  25. May 23, 2020 at 9:10 AM
    #2605
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Careful - they may hire you as a service adviser.
  26. May 23, 2020 at 10:40 AM
    #2606
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Found headers for sale on Facebook.
    Can anyone tell what brand they are from the pictures?
  27. May 23, 2020 at 10:44 AM
    #2607
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Probably the knock off Amazon/ ebay headers. Assuming they don't want much for them?
  28. May 23, 2020 at 10:44 AM
    #2608
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Yeah cheap. Was hoping they were decent:fingerscrossed:
  29. May 23, 2020 at 10:52 AM
    #2609
    Someone torqued this axle nut down hard. My harbor freight breaker bar is no match. o_O
  30. May 23, 2020 at 11:07 AM
    #2610
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not JBA, Thorley, or Pace Setter. Probably some ebay specials. Welds look good and flanges are thick but hard to know what kind of steel they are and if it were me I would plan to check and possibly machine the flanges.
