6112 top setting rear 1 Toytec shackles 5100
Discussion in '1st Gen Tundras (2000-2006)' started by quinterora8, May 21, 2020.
  1. May 21, 2020 at 5:13 PM
    quinterora8
    quinterora8 [OP] New Member
    Ruben
    2020 CM TRD
    6112/5100 & UCA
    Hello everyone, )brand new to forum) I have a couple of questions I searched and couldn’t find an a clear answer. I have 20 crew max 4wd
    i ordered the Bilstein 6112 and 5100 for rear accompanied with Toytec shackles. I’m set on doing the top setting and wanted to know if one inch rear lift will be enough to have it leveled. 5100’s say they are good for 1inch lift if I go to the 1.5 setting will I need to replace rear shocks? Will I need to install carrier bearing drop? I don’t off road much other than a couple of dirt fire roads to get to campsites.
    Would love to see some pictures of this setup if you’re running it
  2. May 21, 2020 at 5:30 PM
    Professional Hand Model
    Fred
    Hand Protectors
  3. May 21, 2020 at 7:06 PM
    glowblue
    glowblue From time to time
    VA
    I put in the same combo. Stock set up had 2” I’d rake. My 6112s were set to 1.9”, and added 2 shims on driver side and 1 on passenger, and installed my Toytec shackles at the 1” setting and I have exactly 1” of rake Which is just what I wanted. If you set your 6112s to the highest setting, you might be very close to level, maybe need a shim.
    Rear shocks should be fine. If you go above 2.5” in the front you might need a diff drop installed.
  4. May 21, 2020 at 7:35 PM
    Ahem:
    noahrexion likes this.
