2012 Tundra Bed lean
Discussion in 'Suspension' started by BretAry, Mar 24, 2020.
  1. Mar 24, 2020 at 4:21 PM
    rustytoys
    rustytoys New Member
    Yes, the passenger leaf spring is installed backward - facing the wrong direction - flip it; there is about a 1" length difference between each side of the leaf pack - so that is pushing you're rear wheel 1" farther to the rear of the truck too.
    I'm not totally sure flipping the leaf will raise you up the 1.5" you need - but it's a start!
    Adam and Tundyfundy like this.
  2. Mar 24, 2020 at 4:24 PM
    BretAry
    BretAry [OP] New Member
    2012 Tundra TRD
    Rusty
    you are correct sir. Went outside and my wheelbase is off by 1”
  3. Mar 24, 2020 at 4:24 PM
    BretAry
    2012 Tundra TRD
    Guess I’m done with that mechanic.
    Adam likes this.
  4. Mar 24, 2020 at 4:28 PM
    rustytoys
    Oh wow, you paid a mechanic for that! Jesus, thought it was a home job you did - thats insane...
    14burrito likes this.
  5. Mar 24, 2020 at 4:31 PM
    rustytoys
    Here is that Toytec 1/2" shim - I personally would be really hesitant to use anything bigger than this on one side alone, but if this can help you level the lean more its an option;
  6. Mar 24, 2020 at 4:33 PM
    BretAry
    2012 Tundra TRD
    I haven’t dealt with any dealer mechanics but I’m in a small town and they’re all (mechanic shops)either shady or do shotty work as you can see. The only reason I asked the guy to do it was because I’m tied up all week and the spring has been sitting on my porch for several days taking up space. The other two shops I have used have lied about replacing new parts or either tell you they fixed a problem and then you get the vehicle back and it still has the same issue.
    rustytoys likes this.
  7. Mar 24, 2020 at 4:34 PM
    BretAry
    2012 Tundra TRD
    I’m going to flip the leaf spring around as soon as I can and see if actually replacing it correctly fixes the sag
  8. Mar 24, 2020 at 6:24 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Hmmm.... Looking at your pictures, I don't think it's backwards... Take a look at this picture below of stock leaf springs. See how these have the "extra" metal curving around the end of the spring? That part should be in the forward position of your truck. I'm not seeing that in the pictures you posted. So you can rule out them being installed backwards. Is there any gap at all between the spring and axle?
    Edit: I am assuming all tundra stock springs have this extra curve. My 2013 did. You might crawl under and see if both of your springs do. If the passenger spring does not have this, it very well might be backwards still.
  9. Mar 24, 2020 at 6:30 PM
    TruckyTruck
    Gary
    I'd wait to blame the mechanic just yet. You said it was in a wreck? Wonder if the frame is tweaked. You might measure the distance between the spring and frame in the center of each. It really does look like your axle on that side is pushed back, but I wonder if it's something more going on.
    Read my edit in the above post.
  10. Mar 25, 2020 at 5:08 AM
    BretAry
    2012 Tundra TRD
    The leaf spring is 100% on backwards. It is the same spring but it is installed opposite of the other side, hence the wheelbase being off by about and inch. It will be fixed today. I don’t know if it will help the sag but a problem nonetheless that I didn’t even notice initially because I was pissed that it was still sagging.
  11. Mar 25, 2020 at 2:34 PM
    rustytoys
    Hope it works out for you; as mentioned I'd check out that Toytec shim if you need a smaller amount of correction after everything is all fixed. Good luck.
  12. Mar 25, 2020 at 2:36 PM
    rustytoys
    In the pictures of his you reposted you can clearly see in your first pic of the passenger side that the "curved" part is installed facing the rear of the truck - not the front - look closer.
  13. Mar 25, 2020 at 3:39 PM
    TruckyTruck
    Gary
    Guess zoom isn't working well for me anymore. Gonna have to break out the reading glasses. So I was right the first time. Thanks
  14. Apr 15, 2020 at 1:56 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    OP did reversing the leaf fix your sag?
  15. May 14, 2020 at 2:53 PM
    BretAry
    2012 Tundra TRD
    Just an update guys. I fixed my one side sag by installing a ToyTec 1-1.5” lift shackle on the sagging side. Evened things up and front and rear fender wells measure the same heights from the top of the tire.
  16. May 14, 2020 at 3:09 PM
    Tundyfundy
    Bay Area, CA
    This seems wrong. What was the original problem? Is the frame tweaked? The sag is a symptom. What was the cause?
    Black Wolf likes this.
  17. May 14, 2020 at 3:19 PM
    timsp8
    NY
    So now you have a longer shackle on one side. I don’t think that’s right either. What happened when you turned the leaf around? Will it even align that way?
    Tundra234 and Tundyfundy like this.
  18. May 14, 2020 at 3:20 PM
    Tundyfundy
    Bay Area, CA
    Seems like a perfect way to burn tires, bearings, and just about all
    Components on one side.
  19. May 14, 2020 at 3:42 PM
    That doesn't seem like a good remedy at all. You don't use a single longer shackle to level. Never.
    Tundra234, Tundyfundy and porkitt like this.
  20. May 14, 2020 at 3:49 PM
    #50
    TruckyTruck
    Gary
    Maybe a block better the axel and leaf spring would have made more sense. With my truck, I had to do that on the driver's side. The front was and is leveled perfectly. I took the leaf springs off and measured the the arch in them, both the same.
  21. May 14, 2020 at 3:49 PM
    #51
    TruckyTruck
    Gary
    I've wondered where you've been!
  22. May 14, 2020 at 3:54 PM
    #52
    In and out. Quite busy at work. Had a 30 day vacation too...:frusty:
  23. May 14, 2020 at 6:30 PM
    #53
    BretAry
    2012 Tundra TRD
    I haven’t found the problem. It’s been on the lift a couple times for oil changes and new tires and I can’t find the issue. Maybe a frame issue I can’t see. The new leaf springs helped a little bit I was still about an inch low on the passenger side. Can you guys educate me on why a leaf or two or a block may be better than the shackle. I ask on here because I don’t know.
  24. May 15, 2020 at 1:12 AM
    #54
    timsp8
    NY
    I don’t think a leaf or block on one side that’s not on the other is any better. Should be the same on both sides. As others said you are just putting a band aid on the symptom and not actually fixing the cause. Do you have a Toyota dealer nearby that you can take it to?
    Tundyfundy likes this.
  25. May 15, 2020 at 7:22 AM
    #55
    ckkone
    ckkone New Member
    SLC, UT
    There is nothing wrong with your truck, lean is normal in most if not all 4wd Toyota’s. Some have more than others, a shim in the front or the 1/2” toytec block is the best way to fix. You will not have uneven tire wear or cause any damage to your driveline with the shin or block. If it really bothers you sell that Tundra and buy another that has less lean. You are trying to fix a problem that isn’t a problem.
  26. May 15, 2020 at 8:15 AM
    #56
    TruckyTruck
    Gary
    It WAS a problem for my eyeballs... :laugh:
