KO2's not balancing
Discussion in 'Wheels & Tires' started by Highsierraguy, May 12, 2020.
  1. May 12, 2020 at 9:27 PM
    Highsierraguy
    Highsierraguy [OP] New Member
    Nor Cal
    Went to the tire shop (America's Tire) for the third time today to try and get my tires balanced. I've been running 285/70/17 KO2's, C rated, for a few thousand miles now and can't seem to get them balanced. They just did a road force balance and said that the rear left tire required 8 ounces of weights. I haven't had enough time to see if the road force balance did the trick, but am I right that a half pound of weights to balance a tire is extreme? Even if it appears balanced right now, to me it sounds like this tire is defected to require this much weight. Has anyone else run into this or had to use this much to get them balanced?
  2. May 12, 2020 at 10:03 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Stock or aftermarket wheels?
    No issues balancing my KO2s on stock TSS wheels.
    Never did get them to balance correctly on after market Anthem wheels..
    Running 17" wheels, that is a lot of rubber to balance out.
    Tundyfundy likes this.
  3. May 12, 2020 at 10:23 PM
    18" TRD Off Road Wheels
    I've heard tell of the KO2 being a bear to balance. I think it was @Scuba (our discount tire guru) that said it. I might be remembering wrong.
  4. May 12, 2020 at 11:58 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    My KO2’s took a few try’s to get balanced correctly. They are notorious for being hard to balance, although if it’s just one I’d check your wheels not the tires. I’ve heard of guys getting them replaced under warranty due to them not being able to balance them.
  5. May 13, 2020 at 3:41 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Yup. Hard to balance. The guys at Midas had weights stacked three tall on one of my wheels. Discount Tire has had no problem balancing with my new set of KO2.
  6. May 13, 2020 at 6:27 AM
    Highsierraguy
    Nor Cal
    they’re on Method 313, which is forged and high quality so I can’t imagine it’s the wheel. They said if it doesn’t work this time they’ll either replace them or allow me to choose a different tire. Not sure which route I’ll go since I’ve wasted so many hours already at the tire shop with these.
    1lowlife[QUOTED] likes this.
  7. May 13, 2020 at 6:31 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Same thing happened to me a couple of years ago on my KO2's. The fourth Discount Tire got it right. I'm thinking there machines were out of whack..
  8. May 13, 2020 at 6:34 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Ditto, Taco balanced up in two tries. The 31" on my Jeep took 3 tries and two shops. Putting BFGs on my Tundra this month and will see how many tries this one takes. Friend's Tundra took two tries, husband's Tundra took two tries. Notorious for being a pita, they're heavy.
    But they look sexy, totally worth the hassle personally.
  9. May 13, 2020 at 6:57 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Honestly I would just go with another tire if they are offering it. Why worry all the time. Discount tire or American Tire same company stand behind their work and if they say it can't be balanced it can't be they are not trying to lie. Those tires do have issues and a lot get sent back for this reason. grab some Nittos and drive with zero worry
