New Brakes (pads and rotors)... now they squeak
Discussion in 'General Tundra Discussion' started by Maddog94, May 11, 2020.
  1. May 11, 2020 at 6:41 PM
    Maddog94
    Maddog94 [OP] New Member
    Ugh... had a local shop do brakes and now they squeak. Just at the very end of a stop, at slow speed with light pressure. Aside from bringing the truck back in, which I would really like to avoid, anything to try or will this just go away on its own as they wear in?
    I didn't notice it when I first picked it up after the brake job, about a week went by before it started.
  2. May 11, 2020 at 7:01 PM
    It possible that they used semi-metallic pads.
  3. May 11, 2020 at 7:14 PM
    Maddog94
    Okay well what was OEM then?
  4. May 11, 2020 at 7:17 PM
    Could it could be the clips on the pads?
  5. May 12, 2020 at 6:59 AM
    Maddog94
    Seems like it went away on its own today.
    Yesterday I did two things. First, I used the brakes hard for a few good stops. Then, I sprayed the brakes with copious amounts of water from a garden hose, figuring maybe brake dust shed from the bedding process was causing it. While it didn't go away completely yesterday, it did diminish a little bit.
    This morning I couldn't replicate the noise. I'm satisfied.
  6. May 12, 2020 at 7:32 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    New brakes need to be burnished....several good hard slowdowns from speed to about 5mph to get everything seated
    Tundyfundy likes this.
  7. May 12, 2020 at 7:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Yep, you've got to bed them in.
  8. May 12, 2020 at 7:43 AM
    Maddog94
    Well the thing is I thought I had bedded them in using a soft approach but I guess I was babying them too much. Yesterday I repeatedly panic stopped those MF'ers while speeding down a hill.
    But again, the squeak wasn't totally gone until this morning. I guess the brakes had a little discussion among themselves overnight knowing they were in for some more punishment today if they didn't STFU.
    WILLINH, jre5490 and Black Wolf like this.
  9. May 12, 2020 at 7:44 AM
    LMAO :rofl:
  10. May 12, 2020 at 12:10 PM
    Maddog94
    UPDATE:
    Nope I was wrong. Squeal is back and just as bad as ever. I wonder why I didn't hear it this morning. So frustrating.
  11. May 12, 2020 at 12:13 PM
    Put it up on Jack's and rotate it by hand and see if you can pin-point it. I'm wondering what pads they installed.....
  12. May 12, 2020 at 12:18 PM
    Maddog94
    Yeah gonna try and get to that within the next couple days. What a fucking pain in the ass. If I wanted to jack my own truck up and struggle with the wheels I would have just done my own brakes in the first place.
    Leo's first likes this.
  13. May 12, 2020 at 12:20 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Pull everything apart put anti seize on metal to metal contacts. Mainly where the pads sit in the caliper shoe and on the caliper fingers(outside pad) and caliper piston inside pad. Where the caliper touches the pad. Use whiz wheel and lightly resurface pad. Properly bed brakes. Before the anti seize brush all the above components with a wire brush to remove break dust build up then blow off with air. Make sure all springs are in place
    KNABORES and glowblue like this.
  14. May 12, 2020 at 12:30 PM
    Maddog94
    Thanks man, will do.
  15. May 12, 2020 at 2:14 PM
    Kanobi13
    Kanobi13 New Member
    Does the shop not stand by there work to fix problem for you?
  16. May 12, 2020 at 2:16 PM
    Maddog94
    Yes front and rear, pads and rotors
  17. May 12, 2020 at 2:17 PM
    Maddog94
    I could bring it back, of course.
    But it's a major pain in the ass because I have to leave it, get a ride back and forth, and be without my truck for a full day.
  18. May 12, 2020 at 2:22 PM
    Professional Hand Model
    Fred
    Hand Protectors
    You need this on your pins, contact points, and between/behind your shims.
    glowblue likes this.
  19. May 12, 2020 at 2:44 PM
    Kanobi13
    Kanobi13 New Member
    Hopefully your trouble shooting works.
  20. May 12, 2020 at 2:44 PM
    Kanobi13
    Kanobi13 New Member
    Lol brake job done!!!!
  21. May 12, 2020 at 3:41 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    This will do the same as anti seize. Either or will work. Should you decide to take care of this yourself
  22. May 12, 2020 at 3:42 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Ya it would pretty much be redoing what he already paid for. Sucks but they clearly didn't do something right.
  23. May 12, 2020 at 3:46 PM
    Trunk Monkey
    Trunk Monkey Truck's
    Steph
    2019 Tundra TRD PRO - VooDoo Blue
    Retrax One MX, NFab Predator Pro steps, Husky X-Contour mats
    This
  24. May 12, 2020 at 5:17 PM
    glowblue
    glowblue From time to time
    VA
    ^This, I have OCD when I do brakes and use this or some other anti squeal compound when I replace brakes ... use it on all contact surfaces, behind the shim, etc. use it liberally.
  25. May 12, 2020 at 5:42 PM
    Kanobi13
    Kanobi13 New Member
    Its frustrating hard to find a tech that is great at there job if you can find one stick with them.
  26. May 12, 2020 at 7:23 PM
    Maddog94
    NY. Yes the underneath of my truck has a lot of surface rust after 4 winters of that horrible liquid salt shit they use on the roads.
  27. May 12, 2020 at 7:28 PM
    Maddog94
    Okay, another update.
    I popped off the wheels and sprayed the living hell out of everything with brake cleaner and blew it out with air very well. A LOT of dirt / dust came out. I did not remove the calipers and pads because, well because I really wasn't in the mood and it was getting dark.
    Took it for a spin and really thought I had fixed it. I didn't want to jinx myself by saying anything but the noise was indeed gone.
    Couple hours later I was curious and just not took it out for a ride and oops... the squeal is back.
    Now it seems that if I work the brakes hard (heat them up), and then immediately try to get it to squeal I can't. Drive for a minute or so (I guess everything cools off) and here's the noise again if I brake just right. Again, it's only with very slight pressure on the pedal but it really cannot be avoided during delicate driving.
    So I'm getting more clues. Only when they are very heated up do they not squeak. Just a minute of driving it town speeds is long enough to get them to cool down enough to replicate the sound again.
  28. May 12, 2020 at 8:09 PM
    Maddog94
    Well I can't tell by looking but I was able to see through the back of the caliper and observe that they are very meaty! Lots of pad, very thick. They do appear dark gray, if that helps to figure out what material they are.
  29. May 17, 2020 at 3:28 PM
    Maddog94
    Okay, took everything apart (it was pretty easy). The pistons themselves looked like they had a little surface rust on them. Sprayed them down with brake cleaner and blew off with compressed air. Next, I used brake lube on the back of the pads where they contact the pistons.
    Problem seems to be solved.
    Now, a few of us here were curious as to what pads they put on. The back of the pads are stamped "TOYOTA" and "ADVICS" so it seems that they used the OEM parts that I requested. I think?
  30. May 17, 2020 at 3:39 PM
    glowblue
    VA
    Sorry you had to take everything apart. I would call the shop and let them have it.
