  1. Apr 25, 2020 at 5:46 PM
    #6871
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Please tell me all those locks are keyed the same.... Otherwise, that would drive me nuts.
  2. Apr 25, 2020 at 6:39 PM
    #6872
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    lol yes definitely keyed the same. Came in a four pack but now I think I want black locks :annoyed:
    HbbTundra08 likes this.
  3. Apr 25, 2020 at 7:57 PM
    #6873
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    I just kinda half ass taped it up, and it’s factory touch up paint. Comes in a little tube and the cap has a built in brush. Just did 3 coats split a half hour apart. Turned out alright.
  4. Apr 25, 2020 at 8:07 PM
    #6874
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Hahaha, didn't think of that. I want to paint mine TRD Red, if I can even paint match. Maybe Radiant Red is close. Gotta research :D. Thanks
  5. Apr 25, 2020 at 8:31 PM
    #6875
    Beau De gustibus non est disputandum
    2008 Sequoia with a 2022 style
    Welcome! Check out the sequoia builds page, but be ready to spend more money. We have a bunch of sequoias there with all sorts of mods.
  6. Apr 25, 2020 at 10:29 PM
    #6876
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Started fabbing a hybrid bumper.. should get to the tube work this week coming. Pretty stoked on it so far.. goal is to be the slimmest bumper possible that will accept a winch
  7. Apr 25, 2020 at 11:36 PM
    #6877
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Badass:headbang:
  8. Apr 26, 2020 at 6:18 AM
    #6878
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If all goes as planned, I will be outside working on my RCSB without a mask. The door panels are coming off so I can install new side mirrors, new courtesy light lenses with LED lights, and a new arm rest cover on the drivers side.
    Trooper2 and Mountun Goat like this.
  9. Apr 26, 2020 at 10:30 AM
    #6879
    Rex Kramer
    Georgia
    Done!
    The old courtesy lights still work, but they had discolored.
    One of my methods to prevent air whistling by the mirror bolts.
    The other is to make sure the mirrors have that thin weather strip you see pictured here.
    The cab is much quieter now.
  10. Apr 26, 2020 at 4:37 PM
    #6880
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Swapped my 08 round body taillights for a set of 10+. Looks better to me.
  11. Apr 26, 2020 at 5:49 PM
    #6881
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Got some maintenance parts installed. New brake bleeder caps, exhaust gaskets, exhaust bolts and carrier bearing drop kit.
    And some work around the yard, thanks to the Tundra. :D
  12. Apr 26, 2020 at 7:35 PM
    #6882
    SalsaTheTundra
    SalsaTheTundra New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    Tore down a deck today and hauled it off. Will post pics tomorrow. It’s above my cab and I dropped some on the interstate to see the Guy behind me in his prius slam on the brakes.
  13. Apr 26, 2020 at 10:08 PM
    #6883
    TheBeast
    TheBeast The Beach
    oil change time ! 8QT of mobil 1 0w-20 and switched to aluminium housing for the oil filter housing. man it's nice to have the RCI engine plate. no need to remove the skid plate anymore.
  14. Apr 27, 2020 at 4:59 AM
    #6884
    Sabata
    Sabata New Member
    Juan
    2008 Tundra 5.7L crew cab base model
    3"leveling kit ( front ) upgraded to 22" rims with 33x12.5x22 MT added 42"bar light and 2 fog lights tinted windows and tona cover
    Update on my led daytime running lights install
  15. Apr 27, 2020 at 5:15 AM
    #6885
    Sabata
    Sabata New Member
    Juan
    2008 Tundra LED daytime running lights install complete
    Zimms, Prostar 190, TheBeast and 3 others like this.
  16. Apr 27, 2020 at 7:42 AM
    #6886
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    @Sabata what is your wheel and tire set up? Thats a pretty nice offset considering the fender flares, very similar to mine since I think I have the same fender flares.
  17. Apr 27, 2020 at 7:45 AM
    #6887
    f.pecan
    f.pecan New Member
    Forest
    2007 Tundra DC 5.7L
    Eibach COs and rear AAL., Morimoto XBs, Rough Country 20" Light Bar, Rough County Ditch Lights, CBI ditch brackets, rock lights,
    I did this a while back when I first got my hands on the truck. It's just a simple sleeping platform that has three sets of lights controlled by the switch panel on the left. There's also a dual USB charging port and a 12V cig lighter socket on the same switch panel. Lights on the lid are just simple Amazon LEDs, same as the under platform lights. The shell top lights are an LED light strip with a dimmer control on the left for getting the lights lower when I sleep in the back. This was my first wiring project and I think it went well!
    myt1, tnbndr, Prostar 190 and 5 others like this.
  18. Apr 27, 2020 at 7:51 AM
    #6888
    Trooper2
    JR
    Houston, TX (Suburban South)
    I guess I didn't realize they changed the rear lenses at some point. They look "Fresher" :thumbsup:
  19. Apr 27, 2020 at 7:53 AM
    #6889
    Trooper2
    JR
    It looks like you painted black to match some of the grill surround. Looks great :thumbsup:
    Sabata[QUOTED] and Mountun Goat like this.
  20. Apr 27, 2020 at 9:45 AM
    #6890
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    So what’s your opinions should I color match the new grille or leave it black ?
    it’s kind of cool the pearl that is in the factory black matches the blue of the truck what y’all think C38A1C3E-3EB4-49F1-A52B-E69A212A373B.jpg 92D9039E-B09A-411B-9AEC-D1B57E52F7DB.jpg
    D4x4TRD, tdawson05, tnbndr and 8 others like this.
  21. Apr 27, 2020 at 9:47 AM
    #6891
    TheBeast
    TheBeast The Beach
    looks great. freshen up the front for sure. I would leave it as is. You can always paint it later if you wanted it.
    where did you order the grille ?
    Mountun Goat and BashFab like this.
  22. Apr 27, 2020 at 10:09 AM
    #6892
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    I like the color match meself.
    O.S.T.
  23. Apr 27, 2020 at 11:18 AM
    #6893
    Sabata
    Sabata New Member
    Juan
    Hey! how's it going ? my tire setup is 33x12.5R22 with 1.5" offset. There mud tires with 3" leveling kit in the front.
  24. Apr 27, 2020 at 11:49 AM
    #6894
    Theyfzman
    Pa
    08 TRD
    I my try red overlay on the Toyota Letters or at least maybe red outline
    Mountun Goat likes this.
  25. Apr 27, 2020 at 11:53 AM
    #6895
    Billy I
    Billy I AKA Storm Shadow
    2013 Tundra TRD Off Road White
    No today, but yesterday....ordered the 18" RCI bed rack. Stoked! Mostly will be used for canoe transport but so many other options....will end up getting the mountain bike tray that goes with the rack as well.
    HbbTundra08 and Mountun Goat like this.
  26. Apr 27, 2020 at 1:18 PM
    #6896
    TheBeast
    TheBeast The Beach
    looks really nice. post progress pictures . thx
    BashFab[QUOTED] likes this.
  27. Apr 27, 2020 at 2:08 PM
    #6897
    HbbTundra08
    HbbTundra08 Epstein Didn't Kill Himself
    Brad
    2008 Toyota Tundra Crewmax SR5 2wd 5.7L
    TAC Stainless Steel Bull Bar RCI Steel Engine Skid Plate Two Stainless Steel 100w KC Daylighters Black Husky Weatherbeater Floor Liners front and rear. Kenwood Media System with Rear License plate backup camera integrated.
    I loved switching over to the aluminum oil housing and RCI skit plate. Makes everything so much more sturdy!
    TheBeast[QUOTED] likes this.
  28. Apr 27, 2020 at 3:11 PM
    #6898
    SalsaTheTundra
    jd
    Birmingham, Alabama
    Here are pics from the deck... I tore down. and also got some cleaners to clean up the new wheels.
  29. Apr 27, 2020 at 5:45 PM
    #6899
    BashFab
    BashFab New Member
    Chad
    Columbia, SC
    07 DBLC mobile rig
    Thank you sir! Will be working on this one in spare time as @WhooaaBlackBetty has the time
  30. Apr 27, 2020 at 5:56 PM
    #6900
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    Installed a TRD rear sway bar.
    georgiey22, SC_TRD, MikeBeach and 6 others like this.
