Suggestions on Rear Sway Bars
Discussion in 'General Tundra Discussion' started by Crewmax Chris, Jan 31, 2017.
  1. Jan 31, 2017 at 12:19 PM
    Crewmax Chris
    Crewmax Chris [OP] Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    Hey all. I am looking at adding a sway bar to the rear of my 2017 Crewmax. The TRD version seems like my best bet, and a simple add on. I don't do much (if any) off-roading and would like a stiffer response while cornering. Are there any aftermarket versions that are worth looking at or shoudl I stick to the TRD rear sway bar?
    dannysmith604 likes this.
  2. Jan 31, 2017 at 12:46 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    I've seen a few members use Hellwig Sway Bars too.
    Crewmax Chris[OP] likes this.
  3. Jan 31, 2017 at 12:51 PM
    Crewmax Chris
    Lewiston, ME
    Thanks, Chuck. I think the price point if ordering from @Roman is about the same for the TRD or the Hellwig. If that's the case I will go with the TRD. If someone using the Hellwig could explain the benefit over the TRD I would appreciate it.
  4. Jan 31, 2017 at 12:58 PM
    Aurora CO
    I believe the Hellwigs are adjustable and slightly beefier.
    rons23 and Crewmax Chris[OP] like this.
  5. Jan 31, 2017 at 1:15 PM
    Crewmax Chris
    Lewiston, ME
    Thanks, Matt.
  6. Jan 31, 2017 at 1:20 PM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    trd!
  7. Jan 31, 2017 at 1:21 PM
    Crewmax Chris
    Lewiston, ME
    Did you notice a big difference, Rob?
  8. Jan 31, 2017 at 1:36 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    2017 Bad Barcelona TRD Pro
    TRD sway bar
    Cant speak about the Hellwig but my TRD sway bar really made the entire truck handle and feel better.
    It feels like its on rails.
  9. Jan 31, 2017 at 1:37 PM
    Crewmax Chris
    Lewiston, ME
    Awesome, that's what I'm looking for. Thank you, Joe. Especially with the added weight to the front when the plow is on the truck. It tends to shift a bit more.
  10. Jan 31, 2017 at 1:38 PM
    Rangers
    Rangers New Member
    Joe
    Oklahoma
    TRD sway bar
    Your welcome, I pull a heavy trailer all day and also a bass boat, the sway bar really helped while towing also.
    I bet it makes your plowing better also.
  11. Jan 31, 2017 at 1:40 PM
    Crewmax Chris
    Lewiston, ME
    Plowing in the winter and hauling a car trailer in the summer. So that sounds like a win-win to me. Very much appreciated.
    Rangers likes this.
  12. Jan 31, 2017 at 2:22 PM
    Tony'sToy
    Tony'sToy New Member
    Tony
    Savannah, MO
    2015 Toyota Tundra SR5 TRD OFF ROAD
    6" Rough Country lift kit 20" BMF Novakane Wheels 35"X12.50R20 Nitto Trail Grappler MT AIRAID Cold Air Intake Flowmaster Outlaw Exhaust System Bushwacker Pocket Style Fender Flares Recon Projector Headlights (Smoked) Recon 35 Watt Hid Headlights Recon 35 Watt Hid Foglights Recon LED Brake Lights (Smoked) Recon LED 3rd Brake Brake Light (Smoked) Recon LED Tailgate Light Bar(Smoked) Recon LED Big Rig Light Bar (Smoked) Recon LED Bulbs Every Bulb Location Rough Country 30" Bumper Mount Single Row Light Bar. Headlight Revolution LED Interior Light Kit Replaced Every Bulb Blue LED Bulbs Toyota TRD PRO Grille (Black) TRD Shift Knob All Windows Tinted 20% WeatherTech In Channel Window Deflectors WeatherTech Floor Liners Extant Encore Tonneau Cover
    Does anyone know if the TRD sway bar works on a 6" lifted truck with Dual exhaust pipes coming out behind rear tires ?? I'm interested in on but web sites say may not work with suspension lifts ????? Does anyone have sway Bar on 6" lifted truck??
    Les7311 and GNTundra like this.
  13. Jan 31, 2017 at 3:21 PM
    LML 3500HD
    An LT tire will be better than a sway bar in the rear. The P-Metric craptastic tires suck.
    CKNPRO, Crewmax Chris[OP] and Law323 like this.
  14. Jan 31, 2017 at 4:20 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Here is a photo of my front and rear sway bars after I had them powder coated to match my wheels. IMG_1842.jpg
    Here the two end links after they were extended and before I had them powder coated. Ekstrom designs does use a thicker and heavier steel when they are extended for a bigger lift.
  15. Jan 31, 2017 at 4:24 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Here is the rear sway bar installed with longer end links. If anyone is considering adding a swaybar to a lifted truck. I definitely like having it for cornering. IMG_4524.jpg
  16. Jan 31, 2017 at 4:37 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hey Chris, the rear swaybar made a very noticeable difference. It took away a lot of "lean" when cornering. I got the TRD.
  17. Jan 31, 2017 at 4:39 PM
    Tony'sToy
    Tony
    Savannah, MO
    That looks bad ass! Nice !!!
  18. Jan 31, 2017 at 4:57 PM
    Crewmax Chris
    Lewiston, ME
    Thanks, Warren. I think that's the route I'm going to go. Roman has then priced very well compared to local dealers so I'll be buying through him.
    Thank you all for your input. I really appreciate it.
    NewImprovedRon likes this.
  19. Jan 31, 2017 at 5:53 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  20. Jan 31, 2017 at 6:07 PM
    Crewmax Chris
    Lewiston, ME
    It's really pretty close. (That one you sent shows at $241 when I open the link with free shipping). This one isn't bad for shipping to me, plus it's supporting Roman. Worth a couple bucks for what he does for us.
  21. Jan 31, 2017 at 6:29 PM
    Motor71
    Rob
    New Jersey
    Definitely, it took alot of the sway away just feels tighter during turns
  22. Jan 31, 2017 at 6:55 PM
    hdfanatic
    hdfanatic New Member
    Kevin
    Pearland, TX
    2017 Barcelona Red Platinum Crewmax 4x4
    TRD Pro wheels, Nfab
  23. Jan 31, 2017 at 7:58 PM
    Ericsopa
    Ericsopa Old man and the sea
  24. Jan 31, 2017 at 9:02 PM
    TheBeast
    TheBeast The Beach
    I'm just waiting for @Roman to run his free shipping promo again :)
  25. Jan 31, 2017 at 9:42 PM
    geno0506
    geno0506 New Member
    Michael
    PM me when you find out, I'm in for a sway bar, TRD Grill/Bulge, Bed Rails, and more, I'll PM you if I hear as well, thanks
  26. Jan 31, 2017 at 9:48 PM
    TheBeast
    TheBeast The Beach
    he had it for thanksgiving for 2 or 3 weeks long.
    Crewmax Chris[OP] and geno0506 like this.
  27. Jan 31, 2017 at 10:49 PM
    geno0506
    geno0506 New Member
    Michael
    Yeah, I bought the TRD dual exhaust then free shipping, awesome!
    Crewmax Chris[OP] and MotoTundra like this.
  28. Feb 1, 2017 at 3:36 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    The TRD will either need extended or you can buy the hellwig for lifted trucks. That is what I did.
  29. Feb 1, 2017 at 9:13 AM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    In for a TRD sway bar group buy or something...
    @Roman
  30. Feb 1, 2017 at 9:41 AM
    TheBeast
    TheBeast The Beach
    that's a good idea :) I would be in.
    @Roman
    dannysmith604, Law323, khunk and 2 others like this.
